Jazzmaster Pickup Height?
Discussion in 'Just Pickups' started by SonicDiveBomb, Feb 10, 2019.
  1. SonicDiveBomb
    SonicDiveBomb Tele-Meister
    Philadelphia
    I just purchased a 2019 left handed jazzmaster and I’m wondering what some of you guys have your pickup heights at? This is my first JM and it seems like people set their pickups on these a lot differently than on standard single coil guitars
    24 track likes this.
  2. strat a various
    My rule of thumb on all Fender single coils ... look up factory spec, then double that. So if the factory sets the PU at 2mm from the string fretting the last fret, go 4. This avoids undue magnetic pull on the vibrating string. IMO.
  3. Tele Fan
    Tele Fan Friend of Leo's
    Louisville, Ky
    I haven't had one in a while, but I want to say I had it set at 3/32 on either side of the bridge pickup and about 4 & 1/2 32 on the bass side of the neck and 3/32 on the treble side.
  4. SonicDiveBomb
    Philadelphia
    I actually was just experimenting! I removed my standard bridge single coil in place for a Novak Wide Range Humbucker.
    I set the neck to about 4/32 on both sides. The bridge humbucker I set a little lower, to 5/32 on both sides. Does this sound about right?
    To my ears, the lower neck pickup sounds MUCH better than when I had it close to the strings to try to match it to the bridge in volume. So instead, I set the neck where I want it and then matched the bridge at that point
  5. nic'o'caster
    nic'o'caster Tele-Afflicted
    Middle Earth
    I'll tell you what my ears hear but some might have the exact opposite view, so take it with a grain of salt ;)
    If I want loud, aggressive and punchy tones, I set the pickups closer to the strings, if I want soft, woody and balanced, I set them far from them...
    Generally it's a compromise between those two extremes !
    General rule : set them according to the factory spec then use your ears to fine tune
  6. BorderRadio
    Phoenix, AZ
    Are they traditional JM pickups? If so, they’ll have the same resistance on both coils, bridge and neck positions. I’ve always used my ears to adjust these, and that means the bridge pickup comes up pretty high to fit my preference, and the neck pickup is lowered down to balance with it, usually the bass side down a little more.
    I have a ‘65AV Thinskin with reissue pickups. The bridge pickup magnets to string distance is between 4/32” and 5/32”. The neck pickup is just over 6/32”.
    [Edit: I see what you did there ;)]
    howardlo likes this.
  7. SonicDiveBomb
    Philadelphia
    No sir! They’re the Vmod pickups in the new American professional guitars. They’re marketed as “hotter”. I think the bridge is around 8k dc and the neck is 7.3k dc
  8. BorderRadio
    Phoenix, AZ
    Good to know. Treat those like Strat pickups :)
  9. Tele Fan
    Louisville, Ky
    If it sounds good to you it's right as far as I'm concerned.
  10. SonicDiveBomb
    Philadelphia
    Ahh I see! So basically it’s ok to put them around that 2mm mark and get good results?
  11. MadJack
    MadJack Friend of Leo's Silver Supporter
    ꓶꓞ ʻɹǝๅpuɐꓛ
    This weekend I finished up the conversion of my Douglas Corvus from Humbuckers to Jazzmasters.
    Before:
    After:
    I installed a set of Bootstrap Lake Surfer Jazzmaster Pickups. The cutouts on the pickguard were free handed and didn't turn out as good as some of my other PG work. :(
    It started with the 500KΩ pots and .022µF cap, but that was Icepick, even after adjusting the pickup height. After all that I installed a set of A250KΩ pots and a .047µF cap. It still starts bright, but I can dial it down nicely.
    As for pickup height, my neck is at 5/32" and the bridge is at 6/32", fretted on the last fret and measured from the pole pieces.
  12. SonicDiveBomb
    Philadelphia
    Wow ok! So your are cranked down fairly low hm? I tried mine today cranked lower and it worked good. Interesting your bridge pickup is lower than your neck. Any reason for that?
  13. MadJack
    ꓶꓞ ʻɹǝๅpuɐꓛ
    With the neck angle needed to get decent action, the angle to the bridge is a bit steep. I need some wood veneer to shim the bridge up. I do like the tone and balance between the pups is pretty close, even if the signal is a bit weak.
  14. 24 track
    kamloops bc
  15. SonicDiveBomb
    Philadelphia
    Behold!!!
    Also, because of the user above advice to treat the vmod like a strat pickup, I have it about 5/64’s close to the string, last fret depressed. So about 2mm. Is this too close for magnetic pull?
    Southpaw Tele and 24 track like this.
  16. 24 track
    kamloops bc
    pics did not show up sorry
  17. SonicDiveBomb
    Philadelphia
    Just fixed it!
  18. 24 track
    kamloops bc
    that is goreous! seriously enjoy!:D:D:D:D:D
    SonicDiveBomb likes this.
  19. 24 track
    kamloops bc
    you will know if the E-1 string sounds deadend ( the pole magnet pulling on the string, kiils the vibration)
  20. SonicDiveBomb
    Philadelphia
    That stewmac video you posted on the other thread was very helpful, but I assume my method will be a tad different considering I have a humbucker in the bridge
    EDIT:
    Also, I do believe it’s fine, my high E only has lame sustain at the final fret, but I’m guessing it’s due to the mustang bridge. These guitars definitely have improved as far as sustain, but I’m guessing until I have a mastery, it’ll remain a little bit lackluster. I put a mastery in my jaguar and I love it
