Jazz box with overdrive - how would it sound?
Discussion in 'Other Guitars, other instruments' started by perttime, Mar 3, 2018.
  1. lammie200
    lammie200 Tele-Afflicted
    San Francisco
    One way to tell is to look at the tail piece. In most cases a trapeze tail piece will be on a hollow body and a stop tail piece will be on a semi-hollow body. Some semis might have a trapeze, but no hollows (that I know of) will have a stop tailpiece. What is impossible to tell until you really study a guitar in hand is if a guitar is truly hollow or has a sound post under the bridge area that reinforces the top underneath the bridge. Deep hollows - probably not. 2"/2.25"/2.5" depth guitars - maybe. My Gibson ES-390 and Epi Casino Coupe are thin bodies that are fully hollow.
    bottlenecker likes this.
  2. bottlenecker
    bottlenecker Friend of Leo's
    Wisconsin
    One is a tail stop. A bolted in tail stop has to have more than a thin top to hold the string tension, so if there's no trapeze then it's a semi hollow. Most fully hollow archtops also have a bridge that sits on an archtop base, usually wood, that is held on only by string pressure, friction, and the arch of the top. Like a violin. A notable exception is the gibson 330. The bridge, but not the tailpiece, is bolted down. I assume it has some kind of "sound posts", or maybe just some reinforcement under the bridge. Either way, it's not a traditional archtop. It's kind of an odd ball.
    Some guitars are kind of confusing, but the 335 is the most famous semi hollow, with a big solid slab in the middle where it makes the most difference. It's kind of surprising to me when people don't get that.
  3. You-Tele-Me
    You-Tele-Me Tele-Meister
    Vancouver Island
    The easiest way to tell from a picture is to look at the bridge and tailpiece. If they are stud mounted, there's a block under the top to hold the tension. It may just be a block or it more likely runs all the way from heel to tail. That'll be a semi-hollow.
    If the tailpiece is a trapeze style (ie. runs back to the end pin) and the bridge has a flat wooden base, then the guitar is almost certainly fully hollow.
    A 335 and the like falls into the former category, while a Byrdland and its ilk fall in the latter category. There are of course some oddball exceptions like the first goldtop Les Pauls with the 'trapeze on studs', but that was Gibson coming to grips with the whole solidbody concept back then.
    F-holes are not a clear indicator on their own. in a thinline Tele, the f-hole indicates a hollow part on one side of the guitar, which in this case is mostly solid. I have a hollowbody which has no f-holes as a way to combat feedback. So look to the bridge and tailpiece and you'll nail it most of the time.
    Edit: it appears a couple of great minds were typing faster than me.
    3-Chord-Genius likes this.
  4. Ebidis
    Ebidis Tele-Afflicted
    Alabama
    My Gretsch sounds fantastic with overdrive, and I haven't had any feedback problems, even at high volumes.
  5. ac15
    ac15 Poster Extraordinaire Ad Free Member
    CHICAGO, IL.
    Yes I see that a lot in general on these threads.
    Having said that, and as an owner of full-size jazz boxes and a thin, fully hollow “jazz box”, thin guitars that are completely hollow do indeed deserve to be considered in the same way as full depth jazz boxes.
    I have one, and it is more “live” and “jazz” sounding than some of my full depth guitars.
    But yeah, 335’s do not count.
    screamin eagle and bottlenecker like this.
  6. screamin eagle
    screamin eagle Poster Extraordinaire
    S. CA
    Actually JB was much more inventive than that. He had Leo himself install a lap steel pickup and controls on his Epiphone. He used that in conjunction with his DeArmond pickup. He also used a volume pedal to goose up his solos. This was all in the early to mid 40s.
    RadioFM74 likes this.
  7. bottlenecker
    Wisconsin
    Why would the bridge be a nuisance? That eastman the op posted is absolutely a jazz box. It even has a solid spruce top! This is a much more serious jazz guitar than a full depth archtop with a bridge pickup. Bennedetto and D'Aquisto both make thin, solid top jazz guitars like this.
    This will sound nothing like a 335, or a casino, which is based on a 330 and is nothing like a 335.
  8. cabra velha
    cabra velha Tele-Afflicted Ad Free Member
    estados unidos
    I think one of the(possibly the) greatest overdriven tones of all time was PT's full hollow Gretsch 6120, I've never played a Byrdland a-la-Nugent but I have played a 6120 into a very loud Fender Brown Pro and it was a handful, so hats off to Pete and Ted.
    I've read that the Rudy Gelder/Burrell/Green guitar tone was at least in part related to a tweed deluxe that was a Gelder studio fixture, but thats more of a crunch tone to me.
  9. screamin eagle
    S. CA
    We are getting stuck in symantics here it looks like. The OP was asking about full hollow jazz boxes and mild overdrive and feedback.
    There are plenty of recorded and live examples of full hollow jazz boxes playing with overdrive and not having feedback issues. Of course Jimi coaxed lots of feedback out of a solid body. My point in saying that is we don’t need to site the extremes. It’s not really addressing the OP.
    A jazz box with mild overdrive can be a great thing
  10. Chicago Matt
    Chicago Matt Friend of Leo's
    Woodstock
    Well, this overdrive isn't mild, but I wouldn't have thought of this guitar for this.
    start at 1:00:
    perttime likes this.
  11. screamin eagle
    S. CA
    Gretsches are kind of a different beast. Kind of. Modern ones mostly use trestle bracing and/hav sound posts (some guilds have sound posts). They are designed to combat feedback a little more than gibson’s.
  12. Ro_S
    Ro_S Tele-Meister
    England
    it cant be intonated
    It's very thin for a jazz box.
    I never said or suggested a Casino was the same as a ES335.
  13. Ro_S
    Ro_S Tele-Meister
    England
    i concur
  14. bottlenecker
    Wisconsin
    Sure it can. The whole bridge moves. Saddles are probably compensated for an unwound 3rd string. Bridges can be carved with any intonation you want.
  15. Ro_S
    Ro_S Tele-Meister
    England
    you cant intonate it per string, that's what i meant. nor can you adjust the height by string.
  16. bottlenecker
    Wisconsin
    Just in case anyone wants to hear an archtop really fuzzed out. He turns on even more on the ending.
  17. bottlenecker
    Wisconsin
    It's not important. The fretboard radius and scale aren't going to change. It just needs to be done right once. It's worth it for the sound.
  18. RadioFM74
    RadioFM74 Tele-Afflicted
    Italy and Switzerland
    I did not want to be too particular :D … He called his rig his "radio station"! Totally OT, but what an amazing guitarist he was! But to get that sound you need the right AMP. A DeA and steel guitar pickup are not enough. Just like for the Charlie Christian sound. You need an ES-150 and something close to an EH-150 amp.
    Re: what has been said, just three things
    - Thin full hollow can make for legit, excellent jazzboxes… I've played ES-125Ts that were as jazzy as full ES-125s (I actually want a 125, and am still debating which one). They have less acoustic volume, but even full hollowbodies with set pickups are not good acoustic archtops, especially those with a lam top. So if you ask me that Eastman IS a jazzbox under any possible definition of the word;
    - IME (which is limited) 335s and semi-hollows are closer to solid bodies than to hollows
    - the best way to tell if a model is full hollow or semi is … to look at the specs :D
  19. El Marin
    El Marin Tele-Holic
    Madrid, Spain, EU
    Have you listen to George Thorogood? That's the answer
    Actually, I am using this right now, a Pat Metheny and it Rocks albeit I am seriously thinking in installing a bridge P90
  20. cyclopean
    cyclopean Friend of Leo's
    innsmouth, MA
    isn't jazz with OD on it just fusion?
