Itch for a new build.... ES Les Paul-ish Semi-Hollow
Discussion in 'Tele Home Depot' started by rscalzi, Sep 20, 2018.
  1. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    Been poking around on the site off and on for that last year or so. Outside of fixing my LP bolt on Japan copy, I have not built anything. I was hoping for a challenge to pop up to maybe spur me on, but that's not gonna happen.
    But, things change/happen and now I feel the urge to start a new build (I'll tell you about that as we go).
    I love the LP I built a couple years ago, but it does get heavy playing it at practice so,
    the plan is to build. A semi-hollow ES LP :)
    Something like this….
    I don’t think there will anything new happening here you guys have not seen before, but starting a thread
    seems to help me stay focused on progress.
    Basically all the techniques I will use will be found in 2 of my other build threads, one for an ES 335 ish and the other the LP
    http://www.tdpri.com/threads/my-own...-335-casino-ish-build-by-end-of-april.549672/
    http://www.tdpri.com/threads/les-paul-more-rick.618287/
    I have it worked out in my head, and will start documenting it here as I go.
    The only wood I have so far is the Ebony fret board. The sides/top/back will be maple and the neck and the inner structure will be mahogany.
    I will be bending the sides so the first thing I’m going to do is build the molds to shape and hold the sides.
    More to follow. ( Maybe I'll even finish before Jupiter finishes that ES 335 :) )
  2. Old Tele man
    Old Tele man Friend of Leo's
    May 10, 2017
    Tucson, AZ
    I kinda get the itch for something like this ES + LP combination:
    trancedental, Zepfan and rscalzi like this.
  3. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    First things first... clean the shop that is a complete mess....
    Gather up some templates I might need.
    telestratosonic and DarkshipDan like this.
  4. LPTyler
    LPTyler Tele-Meister
    142
    Nov 29, 2016
    Rock Springs, WY
    I cant help with the build, but I have an ES-Les Paul, and I really like it. So light, and it sounds great!
    rscalzi likes this.
  5. mangus
    mangus Tele-Meister
    396
    Nov 2, 2016
    Portugal
    I must ask and I almost hope you say no so another plan doesn't start in my head.. Is there a flat version of that beautiful guitar?
    rscalzi likes this.
  6. LPTyler
    142
    Nov 29, 2016
    Rock Springs, WY
    They made the ES-Les Paul Special, which had a flat top, and a little less bling.
    rscalzi likes this.
  7. mangus
    mangus Tele-Meister
    396
    Nov 2, 2016
    Portugal
    I feared this... Challenge accepted
    DrASATele likes this.
  8. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    Still clearing my shop and other work space before I can dive into this project.
    I did get plywood for the mold. I think the curve in the pic is just an optical illusion. Board is straight.
  9. Freeman Keller
    Freeman Keller Tele-Holic
    636
    Aug 22, 2018
    Are you going to do an ES style laminated top and back? If so I'll be watching carefully.
  10. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    I'd love to try a laminated top and bottom, but unfortunately I don't have right equipment to attempt it.
    I will be carving the top. The bottom will be flat.
  11. Freeman Keller
    636
    Aug 22, 2018
    Yeah, unfortunately it is nearly impossible for a home builder to put together either the press or the vacuum system to make the plates. If you do you'd better turn around and sell a bunch of them on evil bay to amortize the investment. I was lucky a few years ago and score two sets of double cut backs, sides and tops and on of single cuts. The guy was going out of business, this was the last of his inventory. He offered me the molds and tooling, in retrospect I should have taken it.
    I'll still follow your thread
  12. tdoty
    tdoty Tele-Meister
    190
    Oct 17, 2011
    Albuquerque, NM
    For me, the vac system would be easy enough. Justifying the cost of the veneers might be a bit tougher nut to crack though................
    I have a number of venturi vacuum generators and a couple of vacuum pumps - leftover industrial stuff that got outdated.
    Tim D.
    R. Stratenstein and rscalzi like this.
  13. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    Those look real nice. Yea, i would have taken those molds and tooling :)
  14. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    Slow going here. Working on the body mold. Also got some sides ready to be bent once I get my bending mold made.
    LPTyler likes this.
  15. Freeman Keller
    636
    Aug 22, 2018
    I'm not sure how you bend your sides but I learned that when I cut out my outside building mold to keep the "innies" which become the bending mold for my Fox bender. It would work fine for a hot pipe too - I find in difficult to fit sides into the outside mold.
  16. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    I usually ( the 2 times i have bend sides ). just make a MDF mold. like this. I soak and heat the sides with water and a carpet iron and when its
    good and "bendy". I clamp it in the mold. A little unconventional but it works for me.
  17. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    Mold is almost ready....
    telestratosonic and LPTyler like this.
  18. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    Minor update.... Have my bending/laminating molds for the sides just about done.
    Might start bending some sides tomorrow. Will add pictures then.
  19. rscalzi
    rscalzi Tele-Holic
    935
    Jun 7, 2010
    Macomb MI
    No bending today, but the molds are done.
  20. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    Always a treat to see you in the shop again, Rick.
    I found I’m too much of a klutz to use a heat pipe effectively, but luckily was able to find a relatively cheap silicone heat blanket, and cobbled together a Fox-based bending jig. You’re kind of giving me the bug again . .
    DrASATele and rscalzi like this.
