Is it worth it to dress your own frets?
Discussion in 'Tele-Technical' started by thechad, May 26, 2019.
  1. thechad
    thechad Tele-Meister
    Kamloops
    Hey everyone, I recently got a player Tele for my birthday.
    I really like the guitar so far, the only downside to it for me is when I go from playing my USA Strat to playing the Tele, I can really feel the roughness of the frets on the neck.
    There is a luthier in town that's really good but he is generally hard pressed to find time to take on more work. I tried scheduling an appointment for him to wax pot some pickups I have in an old 60's Japanese guitar. It went on for so long trying to take it to him, I just decided to buy some wax and do it myself. It went well and was a nice little project for me.
    So the question I need to ask: If someone is inclined to learn and do it themselves, is it worth it to dress your own frets?
    I am guessing I would need to at least buy some files, which may be as much as a luthier would charge to do it?
    This is the only guitar I currently own that would need done, so barring any future purchases, I wouldn't see much return on investment in files because of repeated application.
    If it makes any difference, it is only the finishing on the ends of the frets, specifically on the bottom of the board, that I would want to smooth out.
  2. ppg677
    ppg677 Tele-Meister
    WI
    If you're not doing a full level/crown, you dont need to buy files. Do you just need to polish with a progression of sandpaper from 500 grit up to 2000 grit?
    thechad likes this.
  3. ElectricKaibutsu
    ElectricKaibutsu TDPRI Member
    Philadelphia, PA
    If it's just fret roughness, you probably just need to get something like the D'Addario Fret Polishing System. I've used it before. It's cheap and works well.
    thechad likes this.
  4. Steve Holt
    Steve Holt Tele-Afflicted
    Kansas
    http://www.tdpri.com/threads/fret-leveling-yer-tele-101.201556/
    I think it's absolutely worth it! It tends to be a fairly expensive guitar that doesn't require a y fret leveling or dressing brand new, and then after a few months and some humidity changes they might need to be dressed anyway.
    I did invest in a few tools. A leveling beam and a roll off 180 grit adhesive backed sandpaper. A crowning file, and a fret end file. Also the stewmac fret erasers Probably $150 total and I can do all my guitars, but you can find cheaper tools and other alternatives as well. And the link I posted discusses that. I'm also a sucker for stewmac tools.
    simoncroft likes this.
  5. fendrguitplayr
    fendrguitplayr Poster Extraordinaire
    Greater Boston
  6. Papa Joe
    Papa Joe Friend of Leo's
    Swanton Ohio
    I think thechad is talking about fret sprout..If so all you need is one small mill file..Three corner is best but a flat file can be used..You would want to grind the teeth off the edges so as to not damage the fret board..
    Then after removing most of the metal, finish up using a finger nail dressing board..
    Total outlay would be $20 or less..
    Geo, DugT and simoncroft like this.
  7. thechad
    Kamloops
    Yeah, sorry. I guess my wording wasn't the best choice for what my problem is. Since the guitar is new, the frets are fine and don't need "dressing" as such. It is just the rough ends of the frets poking out of the fingerboard that are rougher then I would like as I slide my hand up/down the neck. Fret sprout would be a better term. Getting some good info though, thanks!
    telemnemonics likes this.
  8. simoncroft
    simoncroft TDPRI Member
    Worthing, SE England
    I've been using an old-fashioned oil stone, such as you might sharpen a chisel on, for 40+ years to dress frets. That includes levelling the tops, and making sure they don't stick out at the sides. If you've taken much off the tops, you'll probably want to use a fret file to restore the profile of the crowns. After that, you can get the frets nice and smooth with a couple of grades of Wet & Dry paper, followed by some Brasso Cloth. Ron Kirn wrote a very good manual on this subject, which I think I still have as pdf.
  9. simoncroft
    Is the board maple or rosewood? If it's rosewood, you can work along the sides of the board with some fine abrasive paper, rounding off the edges of the board a little and taking any sharp edges off frets. When the fret 'tangs' stick out of the side of the neck, that's best adressed with a leveling beam, or oil stone, so you're trimming the ends of the frets, not cutting into the neck finish. :)
    EDIT: Best you don't go rounding off the edges of a maple board, because you'll cut through the finish.
  10. thechad
    Kamloops
    The board is maple. I definitely don’t want to ruin the finish on it. I think I have an oil stone in my tool box so might be worth a try.
  11. TimTam
    TimTam Tele-Holic
    Melbourne
    It depends somewhat on the extent of the sprout, but as it sounds like it's the type that you can still play but just catches sometimes, a fret end dressing file should be enough to do the job properly ..
    https://www.stewmac.com/How-To/Onli..._fret_ends_that_stick_out_in_dry_weather.html
    https://www.stewmac.com/Fretting_supplies/Shaping_and_crowning/Fret_End_Dressing_File.html
    https://www.amazon.com/dp/B013ZHK4DM/?tag=tdpri-20
    Those special files have 'safe edges' to protect the board. But since you haven't done it before and it's a maple board, I would recommend taping the board on each side of the frets you need to file, to protect it some more.
    Piggy Stu likes this.
  12. jrblue
    jrblue Tele-Afflicted
    Santa Barbara
    It's easy to find information about how to do this kind of maintenance/repair work. I find that the real question is whether you do or do not have the patience and focus to do a good job. Most people do not, and most home repairs are cruddy -- not because the work is all that hard, but because a lot of people just do fast, crappy work. Being able to do excellent fret work, including fixing protruding ends, is very, very valuable -- it's not as though there are loads of good techs out there -- and I totally recommend learning to do this stuff -- only if you have the restraint and patience to do it well. If you're someone who rushes or can't follow procedures carefully, that's too bad.
    Piggy Stu and thechad like this.
  13. trev333
    Coolum Beach,Australia
    You could buy a cheap pawn shop guitar and practice a fret job on that.... if you're not confident working on your own neck yet... :)
    simoncroft and Piggy Stu like this.
  14. mtjo62
    mtjo62 Tele-Holic
    StatesVegas, NC
    I bought a similar bag of these nail dressing files. They work great for basic fret dressing when you don't need to take material off, just tough up. I have some of the fret erasers and they work well, but you can flatten the frets if not careful.
    https://www.amazon.com/dp/B0037O2J7I/?tag=tdpri-20
  15. telemnemonics
    You can do all your fret filing with tools from the local hardware store.
    Luthiers used to use and modify normal files because there were no fret specific files available.
    For fret sprout all you need is a fine single cut file.
    If you need to file above the tang you'll need a thin triangle file as well, but you don't really want to take that much fret material off.
    Better to do something about the lack of humidity that caused the neck to shrink!
    rangercaster and Piggy Stu like this.
  16. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    It's worth it if you're great at it.
    It's worth paying a professional if you aren't.
    It's almost always worth doing or having done, even on expensive, well made guitars.
  17. telemnemonics
    I would not grab an oil stone from the tool box to file off fret sprout on a maple board.
    You want dead flat, a sharp cutting edge, clean, and a clear view, so when the file just touches the maple, it barely dulls the finish at all.
    A clean diamond sharpening "stone" would be fine, but oil and stone are not pretty on lacquered maple, and a used stone is generally not flat.
    4pickupguy likes this.
  18. kbold
    kbold Tele-Meister Silver Supporter
    If it's fret sprout on the ends, it may be worthwhlie to re-humidify the guitar before griding away at the frets.
    The wood can shrink in low humidity.
    With a maple neck, I wouldn't do it myself.
    See if you can get a luthier to check it out.
    rangercaster and thechad like this.
  19. Chunkocaster
    In space with Ziggy
    All work that's required on your guitar is better done by yourself if saving money and having a better understanding of your instrument is important to you.
  20. thechad
    Kamloops
    Thanks for all the info guys. It’s not a bad case of fret sprout really, if I look along the board they are flush. They just feel a bit rough. I think I’ll call the luthier in town first. I can live with it for a while if need be. On the plus side I’ve learned a bunch about dressing frets. For what it is, I don’t think a full re-dress is needed. If the luthier doesn’t have time to take it on, maybe he can at least have a look. I think they just need a bit of a polish to smooth them up.
