Is it possible to change the resistance of a speaker?
Discussion in 'Amp Central Station' started by scud133, Oct 7, 2011.
  1. scud133
    scud133 Tele-Holic
    552
    Dec 29, 2009
    Houston, TX
    Is it possible to change a speaker's resistance (e.g., 8ohm to 16ohm)? Like soldering a resister somewhere inside or something?
  2. jrfrond
    jrfrond Tele-Holic
    955
    Aug 11, 2008
    Long Island, NY
    The only way to change the impedance of a speaker is to recone it using a different voice coil impedance.
  3. scud133
    scud133 Tele-Holic
    552
    Dec 29, 2009
    Houston, TX
    righto. my fault for such a noob question. i was thinking merely resistance when i need to be thinking impedance. it's early in the morning, my bad.
  4. megafiddle
    megafiddle Former Member
    610
    Feb 27, 2011
    VA
    If you're willing to give up 1/2 of the amp's maximum power, you could
    add an 8 ohm power resistor in series with the speaker.
    Sometimes guitar players like to get some extra overdrive without the
    extra volume, so it would act as a mild power soak at the same time.
    But as jrfrond said, you have to change the voicecoil to change the
    speaker itself (and maintain full power).
  5. dqami
    dqami Tele-Holic
    820
    Feb 11, 2004
    you could add another speaker to get your desired resistance.
  6. Raybob
    Raybob Tele-Meister
    You can re-cone the speaker with a different impedance coil, or just get a Weber Z-Matcher.
