Intonation Question
Discussion in 'Tele-Technical' started by jondanger, Dec 20, 2018.
  1. jondanger
    jondanger Poster Extraordinaire
    Charm City, MD
    Hey folks. I’ve been setting up my own guitars for almost 20 years, all different bridges, scale lengths, etc., but have encountered an issue that I’ve never experienced before.
    I just picked up an Epiphone Elitist Casino - cool guitar. I put some DR pure nickel 11-50s on it, because I wanted something more mellow and a slightly heavier gauge than I usually use. Here’s the issue I’m having:
    The D string is slightly flat from about the 3rd fret to the 10th, but comes back in line around the 12th fret. I don’t have the same problem on any of the other strings. It’s only about 2.5 cents flat at the worst point, but I can hear it. My first thought was the nut, but that should have the greatest impact closest to the nut. This is the worst around the 7th-8th fret.
    Anyone ever had this kind of issue? Any idea what could be causing it?
  2. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    You are flat in the center section. To me that implies a high bridge and a high nut. Are you tuning to open or fretted strings?
    Obsessed likes this.
  3. jondanger
    Charm City, MD
    I’m tuning to both a Boss TU-2 and an iPhone tuner app that shows Hz.
  4. jfgesquire
    jfgesquire Tele-Meister
    Lake View
  5. jondanger
    Charm City, MD
    I’ll need to dig into that page when I don’t have to divide my attention. Thanks!
    I’m going to go get my standard string set to compare, change them out tonight, and see where I’m at.
  6. Greggorios
    Greggorios Tele-Afflicted Silver Supporter
    Patterson, NY
  7. Wally
    A string can be bad from the get go. Since there is only one string giving you this problem, the string is suspect, imho. Or....is the radius at the bridge proper??
    dsutton24, jondanger and LutherBurger like this.
  8. Nickadermis
    Nickadermis Friend of Leo's
    Camden Point, MO
    I think I must play differently with flatwounds, like maybe my fretting hand is more delicate? When I play roundwounds I tend to go sharp for some reason. It has to be me, but it is pretty consistent. So I don’t keep round wounds on too many guitars unless they are at least 11s. I have flat 9s on my little strat and have no trouble, flat 12s on my G&L and no trouble. But I have A new set of Elixer 10s on my 339 and it’s wonky when I play it. Not enough to be drastic but enough that I can hear it on my Jazz shell chords.
  9. moosie
    on the roof
    Both. You'll be in tune only on the octaves, really. And it might be a dead string.
  10. Obsessed
    Montana
    How is the fret wear along the D string?
  11. Wally
    Excessive fret wear takes notes sharp, ime.
    sjwieczorkow likes this.
  12. moosie
    on the roof
    I was thinking the same, unless the 12th is unusually worn? :):rolleyes:
  13. Ricky D.
    Ricky D. Poster Extraordinaire
    Raleigh, North Carolina
    If it was mine, I'd replace the string before getting surgical on the guitar.
    I used DR Pure Nickel for about a year. Had to walk away - too many bad strings. Went back to Fender strings.
    jondanger likes this.
  14. jondanger
    Charm City, MD
    Just changed the strings to Ernie Ball Beefy Slinkys and everything is fine. Musta been a bad string. Bummer, I was happy to find pure nickel 11s locally. Guess I’ll need to order online if I want some that aren’t DRs.
    Thanks all!
    Ricky D. likes this.
  15. aerhed
    Boulder, WY
    So what would make a particular string do that? Thin spot? Overdrawn? I can see that, I guess.
  16. moosie
    on the roof
    Think so, yes. Possibly more conditions relating to the raw material before drawing...?
  17. sjwieczorkow
    sjwieczorkow Tele-Holic
    Milwaukee
    Definitely this.
    Think of the intonation difference between a tall narrow fret that has had a fret level or two and a nice crowning, versus a Gibson style fret that has a distorted shape due to extensive wear. Also, take into consideration Gibson frets are funny to begin with due to their wide/square shape. Not good for intonation.
    My opinion.
  18. Wally
    A properly crowned fret will present the same witness point regardless of its width. If the frets are not properly crowned; then yes...a wide fret can present a wider witness point.
  19. Ricky D.
    Glad that worked out easily. What a pain it is to buy a set of strings, come home and put them on, and have one turn out to be defective. And good luck trying to buy a single, nobody sells them that way. Got to buy a whole set again. I don't know why I started getting DR instead of Fender, must have bumped my head, :)
    I use Fender nickel wrap now, I forget the exact designation. Fender 150, maybe?
