Installing a 'cut-off' bridge on a Telecaster
Discussion in 'Telecaster Discussion Forum' started by Loobs, Mar 22, 2010.
  1. Loobs
    Loobs Tele-Holic
    883
    Apr 5, 2005
    Berlin, Germany
    I am thinking of purchasing a Baja Tele soon but I want a cut-off vintage bridge on it, most probably the Glendale Half-Plate, or something similar. I realise it probably screws right in, but will it affect the height of the bridge pickup, will it need rubber spacers under the pickup or something similar to make it the right height?
  2. robt57
    robt57 Telefied Ad Free Member
    Feb 29, 2004
    Portland, OR
    Depends on the PUP route depth and you PUP I'd say. The 'right' length wood screws, and possible some foam under the PUP. When I did it, I was able to use 7/8" long screws and surgical tubing under between the base plate and bottom of the PUP cavity. The PUP cavity was 3/4" deep IIRC. I di dnot like the tone though and undid it FWIW.
  3. Loobs
    Loobs Tele-Holic
    883
    Apr 5, 2005
    Berlin, Germany
    Interesting, what did you not like about the tone? I love the look.
  4. robt57
    Feb 29, 2004
    Portland, OR
    Lost the twang a little too much for me. Interestingly, it was a hardtail modern bridge, and I used the piece left over from cutting a vintage Fender plate [for a dual HB Tele] next to the modern Hardtail bridge to mount the PUP in. I liked it a lot that way.
    Before and after:
  5. Hollmanp90
    Hollmanp90 Tele-Afflicted
    Feb 10, 2009
    Hamilton County
    Each his own........
    Here at So. Ill.......and I'm hearing of others,but I love a half-bridge setup....fatter tones,and still as twangy as any except Bakersfield.............
    Great giggin' setup.....I suggest using a a hotter pickup.
    Been having good results using mous pad foam in the route.
  6. fendorst
    fendorst Banned
    378
    Jun 18, 2009
    usa
    $18
    I got the Wilkinson half bridge. Direct replacement for four-hole bridgeplate, fits perfectly, compensated brass saddles work great. Subtle but definite change in tone. More open and airy, very lively and twangy, and maybe a little bit more growl to the tone as well.
    Scroll down to bottom of page:
    http://www.azguitarparts.com/id6.html
  7. Loobs
    Loobs Tele-Holic
    883
    Apr 5, 2005
    Berlin, Germany
    Awesome and so cheap! I'll be picking one of those up. Do you have to alter the pickup mounting at all, put rubber spacers under the pickup to push it up to the correct height or something?
  8. Loobs
    Loobs Tele-Holic
    883
    Apr 5, 2005
    Berlin, Germany
    Can you briefly explain the foam thing in the route, and how I'd go about installing that?
  9. Hollmanp90
    Feb 10, 2009
    Hamilton County
    Simply,make you a pencil rub template.......pick you up a mouse pad, cut it to shape,mine usually need nothing to keep in place, I use spring on pickup screws,install pickup.
    Keep everything solid, stable........some shielding perks.
    I don't use shielding paint or tape on my builds......ground that bridge and whastever is on the bottom of the pickguard.
  10. Ronkirn
    May 1, 2003
    Jacksonville, FL
    This is another one of those "how does it sound" questions... the answer is the same for 'em all.
    It doesn't matter what anyone likes or dislikes, there is only one way for you to find out if it works for you, ya gotta jump in and get wet.
    I would recommend taking a looooong look at your amp. That's where 90% of whatever you will hear is produced.
    Ron Kirn
  11. GreeneFan
    GreeneFan Tele-Meister
    326
    Oct 9, 2009
    SE Virginia
    Is there a wire already connecting the bridge on tha Baja to ground? If not, you'll need to run one as you'll be eliminating the connection through the bridge pickups ground.
  12. boris bubbanov
    My recollection is the Baja bridge depends for its grounding on the physical connection by screws of a grounded base plate to the bridge plate itself.
    If my recollection is correct, a new lead from the bridge plate to the back of the volume pot is in order:
    This Seymour STK T3b in the single coil position has plenty of twang - I am very excited about this guitar and plan to get some more of these Seymour Duncans. Might be this Esquire has a surplus of twang but it sure sounds nice.
    Robt, what type of half bridge plate did you try? I think if you use something like a Taipantone brass 1/2 plate, you might have this issue. Guitar used to have one - it has improved very sweetly with the .048 steel.
  13. robt57
    Feb 29, 2004
    Portland, OR
    I did a vintage Fender which I cut myself, and a hard tail Modern Fender with polished saddles, sintered I guess.
    I did find I like the cut bridge better with a hotter PUP.
    I used some stainless saddles on the vintage 3x setup.
  14. fendorst
    fendorst Banned
    378
    Jun 18, 2009
    usa
    when screwing the bridge pickup directly into the body cavity i didn't' use foam beneath the pickup. i used three springs.
    i've tried foam in the past (for the neck pickup) but foam gets fatigued after a short while and it "remembers" the shape it was in. so if you try to raise the pickup, the foam no longer expands or pushes upward, and the pickup doesn't raise.
    long story short, i put three springs under the bridge pickup, same deal as using two spring under the neck pickup.
  15. mellecaster
    mellecaster Former Member
    Here's how Fender does it on the G.E.Smith
  16. boris bubbanov
    Yeah, the bridge pup rout is obviously shallower on the GE Smith.
    I use tubing, and stainless steel #2 x 5/8ths inches phill. pan head sheet metal screws. Product # 9864 from www.boltdepot.com. .75 length screws will work fine, also.
    The bed of closed cell foam is, I think, a mistake. As observed, it doesn't rebound when crushed down over time. And, if you winch the pup down with the fasteners while suspending the pickup under the middle of the base plate, you will distort the base plate and it may separate from the Bobbin. It could cause some serious squeal, which I discovered on a Keystone T bridge pup.
  17. Loobs
    Loobs Tele-Holic
    883
    Apr 5, 2005
    Berlin, Germany
    Thanks for all the replies guys...the tubing and screws or perhaps the springs methods sound the best. I will keep you posted on progress when I get my Baja.
    A guitar store owning friend of mine has 10 Bajas coming in this week, he's gonna cherry pick the nicest (and lightest) for me! 'cited!
  18. Loobs
    Loobs Tele-Holic
    883
    Apr 5, 2005
    Berlin, Germany
    So here are they putting the rubber tubing under the pickup to prop it up? Is that screw also there to stop the pickup falling down?
  19. Tom_B
    Tom_B Tele-Meister
    159
    Feb 11, 2009
    Astoria, NY
    hmmm... Yeah, the route on mine was very deep, so I couldn't find tubing or springs long enough to bring the pup high enough. I went with foam which, btw, is much easier to install and haven't had any problems, yet. But maybe I'm just lucky so far... I could definitely see the plate separating or the foam decaying. But that surgical tubing rots, too. Anywho, I don't mind getting back in there if I have to replace the foam or whatever.
  20. cband7
    cband7 Friend of Leo's
    Oct 27, 2007
    Thule, Greenland
