if a filter cap shorts, does that put high voltage DC on the chassis?
Discussion in 'Amp Tech Center' started by peteb, Jan 12, 2018.
  1. peteb
    peteb Friend of Leo's
    Apr 25, 2003
    Cascadia
    I think it would
    this is just a question, not something that happened to me.
    that would be a short to the chassis.
    shorts to the chassis I thought were rare, but filter caps could basically fail at any time, new or old, old is more likely of course.
  2. clintj
    clintj Friend of Leo's
    Apr 4, 2015
    Idaho
    Usually the end result is an exploded cap, and possible damaged components up to and including a fried PT.
    If the reservoir cap shorts, the available current is limited by the capacity of the rectifier (tube or diode) and HT winding capacity (ampacity). Either the mains fuse will blow, or one of those components will quit working.
    A later cap that shorts becomes limited by the dropping resistors, and depending on the value/power rating etc one may burn up and open, stopping the fault.
    There's two safety features every amp should have these days that will keep the guitarist safe. The shorted cap may draw enough current to trip the mains fuse (and/or B+ fuse if equipped), and with a proper grounded plug the ground conductor can easily handle the fault current, preventing the chassis from building up a voltage.
    AAT65 and peteb like this.
  3. FenderLover
    FenderLover Friend of Leo's
    Jun 11, 2009
    Minnesota
    Short answer, No.
    A shorting cap can disable an amp without catastrophic failure and without a hot chassis.
    Long answer, the resistance of a failing component (including the dielectric integrity of a capacitor) will always drop the applied voltage across it as current rises, up to the instance of failure. So no, the chassis is always ground if the safety ground is connected. That's the purpose of the safety ground.
    The caveat is Yes, in that it is the mechanism that happens at ultimate failure, but it is instantaneous. This may be the answer you are looking for, even though the chassis is still always at ground potential.
    peteb likes this.
  4. peteb
    Apr 25, 2003
    Cascadia
    Great answers both, thanks.
    The subject is plausible amp catastrophes. Ones that are known to happen.
    You got the tube failure which often results in excessive current draw, fuse failure, and the need for new tube(s) and a fuse. No tube amp is immune from this.
    Then you have the shorted filter cap. No amp is immune from this either, but fresh caps will mostly prevent this. The shorted filter cap will provide a direct path from the high voltage DC supply to the chassis. This has to be one of the very worst things that can happen to an amp.
    I was looking for a general answer. I think you guys have answered it well.
    Now consider a stock and mostly original fender amp from the 60s.
    (The filter caps have been renewed on 3 of my 4 amps. The 4th I consider as a test case)
    Another tdpri member just had a shorted filter cap, it happens.
    A two prong fender with 50 year old filter caps is one shorted high voltage cap from a scenario in which 400 VDC could suddenly appear on the guitar strings. If the player provides a path to ground, the amps 1amp or one half amp fuse could be out of the circuit (on the neutral line) and the 15 amp circuit breaker is the lone remaining safety feature at this point.
    The 3 prong grounded cord, fresh filter caps, and even moving the fuse to the hot line could could all be life savers.
    This could be the educatin that forces my hand to do some long overdue upgrades.
  5. BobbyZ
    BobbyZ Doctor of Teleocity
    Jan 12, 2011
    Snellman MN
    The fuse is still in circuit regardless of how you plug in an old two pronger cord. With any luck it'll blow instead of saving itself while the power transformer does it's imitation of a fuse. That's slower, smokey and stinky.
    peteb likes this.
  6. dsutton24
    dsutton24 Poster Extraordinaire Gold Supporter
    Dec 29, 2010
    Illinois
    There are shorts, and there are shorts. If you get something close to a zero ohm short, and there aren't any other paths to ground, the fuse will blow and everybody survives. Worst case scenario is a two wire line cord, and a cap that is shorted to the degree that significant current could flow to the chassis but doesn't blow the fuse. You then have a live chassis and the potential for death or injury.
    There are any number of things in an amp that can create this situation, including tubes or a leaky Death Cap™. This is why three conductor cords are essential if you don't want to kill yourself or anyone you care about. A properly installed three wire cord plugged into a properly wired three conductor outlet eliminates this danger. With a three wire cord plugged into a good three prong outlet, the chassis is always going to be grounded, and therefore, safe.
    Teleterr and peteb like this.
  7. RLee77
    RLee77 Friend of Leo's
    May 15, 2016
    Silicon Valley
    You aren't going to see DC on the chassis or strings. Voltage potentials are developed with respect to ground. If you short the B+ to ground, you have zero dc volts on the chassis.
    OneHenry and peteb like this.
  8. Dacious
    Dacious Poster Extraordinaire
    Mar 16, 2003
    Godzone
    The general answer is if you walk outside an airliner could fall on your head. It's more likely you spill a fluid on a live point just as you're plugging in....
    It the cap earth's, that is where the current goes.
    Yes you should put fuses on a HT leg of your transformer. More to save it. 3 wire cord is easy safety measure.
    People who've been killed by amps is nearly the result of bad house or power point wiring.
    peteb likes this.
  9. Hobs
    Hobs TDPRI Member
    93
    Sep 16, 2011
    Nashville, TN
    RLee77 has it right. A shorted filter cap will not put HV DC on the chassis, because the DC potential ground is referenced to that same point. There may be some oddball amp in which that is not true, but that's the case with all of the common designs. Shocks from amps occur because of line voltage AC being present on the chassis.
    OneHenry, peteb and RLee77 like this.
  10. Hobs
    Hobs TDPRI Member
    93
    Sep 16, 2011
    Nashville, TN
    As far as fuses: a fuse provides some protection against fire, and some protection against catastrophic damage to equipment. Fuses do not protect against shock. 20mA can kill you. Even a 1/2A fuse will not even begin to blow at that level.
    peteb likes this.
  11. dsutton24
    Dec 29, 2010
    Illinois
    Not true. Those voltages are referenced to the chassis. if the chassis is floating, you most certainly can have a hot chassis situation. Witness the lip biting amps of yesteryear, or the thousands of transformerless two wire electronic devices built from the forties through the sixties. Or, for that matter the bad stuff that happens when outlets get wired wrong.
    I had an old National HRO radio that had a leaky bypass cap that did exactly what I described above.
    Teleterr, peteb and 24 track like this.
  12. RLee77
    May 15, 2016
    Silicon Valley
    Yes true. I'm referring to the OP question, which was about DC, not AC. And if a chassis is floating, all bets are off. The assumption was for normal amps.
    OneHenry, JD0x0 and peteb like this.
  13. 24 track
    24 track Poster Extraordinaire Silver Supporter
    Nov 6, 2014
    kamloops bc
    isnt that the premixe to the old widow maker amps of the 60's , no power transformers etc like my pepco?
    peteb likes this.
  14. peteb
    Apr 25, 2003
    Cascadia
    Thanks for all of the excellent replies.
    Gerald weber wrote, if a filter cap shorts, the fuse blows.
    This is a general answer for vintage amps. G weber does not discern 2 prong vs 3 prong, and does not discriminate against 2 prong. He also does not say this is dependent upon the fuse being on the hot leg.
  15. peteb
    Apr 25, 2003
    Cascadia
    More
    I agree with the assertion that the fuse will blow on either leg
    Because
    Nothing of significance good or bad is going to come out of the other end of the PT unless both legs of the primary are in service.
    OneHenry and BobbyZ like this.
  16. nasdak
    nasdak Tele-Meister
    172
    Mar 22, 2013
    france
    Hi,
    I just had a shorted first (reservoir) filter cap incident last week on a 1953 amp i'm restauring.
    Even though it does have a fuse, the rectifier redplated like crazy and the fuse did not blow.
    I had time to turn off the amp before the pt blows, the fuse blows, or it takes fire. Happily enough, the cap made a small "pop" noise when it failed that took my attention... Without that noise things would have gone bad.
    Chassis was grounded too, so i didn't kill myself !
    peteb, robrob and RLee77 like this.
  17. robrob
    Dec 29, 2012
    United States
    Take a new power transformer out of the box. Connect the primary to 125 volts AC from the wall. The center tap and HT secondary wires aren't connected to anything (they're floating) and we measure 650 volts AC from one HT secondary wire to the other. We would also measure around 325 volts AC from either hot wire to the center tap.
    We can touch either hot wire or center tap and not get shocked because the voltage isn't referenced to ground--the voltage is only between the three secondary wires. If we measure the voltage between a metal ground rod sunk into the earth and any secondary wire we'll see only random low voltage caused by transformer leakage.
    But if we touch any two secondary wires we will get shocked.
    If we connect the power transformer center tap to an un-grounded metal chassis we would measure around 325 VAC between either HT wire and the chassis but we can still touch a single hot wire or the chassis (not both) and we won't get shocked.
    Ground the chassis and now we and the chassis have a common path literally through the ground (Earth). If we touch a hot wire electrons can flow between the ground and the hot wire through our body and shock us.
    If we rest one hand on the chassis and touch a hot HT wire with the other then 325 volts AC will push current from one hand to the other across our chest (that's why we have the one-hand rule).
    If we stand on an insulated plastic box so we have no path to earth we can touch either hot wire and not get shocked.
    We can hold the grounded chassis in our hands and touch a hot wire (or failed short capacitor) to the chassis and not get shocked because the lowest impedance path to earth is through the chassis ground wire. Now if we were standing in a pool of water in our basement and did that we might feel a tingle.
    peteb likes this.
  18. peteb
    Apr 25, 2003
    Cascadia
    nasdak,
    you were fortunate, I am happy for you and your amp.
    the surprising thing is why didn't the fuse blow?
    That is not right. I would lower the fuse size so that it is effective. No use in having a fuse that wont blow.
    to make the case for the half size fuse:
    a basic champ idles and runs on about 0.4 amps of wall current. the stock fuse is one amp slo blow, a half size fuse is a half amp slo blow.
    that means with the half size fuse, 0.1 amps of over current will reach the fuse value. the standard fuse needs 0.6 amps of over current to reach the fuse value. Which fuse is going to blow first?
    this may not work with the more complicated half of the fender line.
    it is known to work on champs (no vibrato)
    princetons (no reverb)
    and bassman's (no frills)
    Thin69 likes this.
  19. Thin69
    Thin69 Friend of Leo's
    Oct 28, 2009
    Galveston, TX
    Hence the need for a 3 wire power cord with the ground conductor securely fastened to the chassis!
    peteb likes this.
  20. nasdak
    nasdak Tele-Meister
    172
    Mar 22, 2013
    france
    I think it's because it shut it down quickly :)
    peteb likes this.
