Identifying an old Tele body
Discussion in 'Tele-Technical' started by buddyboy, Mar 15, 2019 at 9:53 AM.
  1. buddyboy
    buddyboy Tele-Meister
    Melville, Long Island, NY
    I've owned this body for a number of years and I'd like to try and determine exactly what it is and whether it was made by Fender.
    It was stripped years before I owned it. It appears to be a two piece ash body. It would make about an 8 lbs. guitar. There is no channel route, which, if it is a Fender body, places it after 1968. It appears to have the classic earlier "Tele notch". The control cavity route seems a bit odd as it has two router indentations in the sides.
    There is one faint marking in the neck pocket. This is the one clue that tells me it may, in fact, be a genuine Fender body. The number font ("022 ...) seems to match the font used on an American Fender Strat, judging from the pic I found online of it's neck pocket (See photo below).
    Anyway, if anyone can chime in with their opinions on this body, I would be grateful.
  2. preactor
    preactor Tele-Meister
    gainesville, ga
    Couldn't tell you anything. It's a nice body....time to build her out!
  3. MatthewK
    MatthewK Tele-Holic
    Hobart, Australia
    If you're thinking that the typeface match on the numbers suggests that a similar stamp was used - the number height on yours is about the same as one of the neck screw holes. The stamp on the Strat has numbers about twice that size. Not that it's impossible they had two different stamps, more that it's not the same stamp. That style of digit is very common on number stamps, some of my Japanese guitars have them for example.
  4. Bluetelecaster
    Bluetelecaster TDPRI Member
    Waynesville NC
    Have you contacted fender with the serial number?
  5. netgear69
    netgear69 Tele-Afflicted
    england
    A standard type telecaster body is really hard to identify the old vintage stuff router hump lip overhang dowels etc is easy enough to identify even that kind of thing can be reproduced
    It looks like 2 badly matched pieces of Ash so at a guess i'd rule out Fender still nice though
