Humbucker Sizing
Discussion in 'Tele-Technical' started by Jim_in_PA, Jun 7, 2019.
  1. Jim_in_PA
    Jim_in_PA Tele-Meister
    SE PA near New Hope PA
    "In general", is there a lot of variation in sizing between different manufacturer's humbucker format pickups? I want to insure that some of the designs I'm faddling with will be flexible in that respect. Thanks in advance!
  2. RottenTheCat
    RottenTheCat TDPRI Member
    Drambuie, Africa
    Depends how persnickety you wanna get. Generally there is USA size and not_USA size, each of which come in both bridge and neck sizing, so that's four general sizes. Body routes generally accommodate all of those, but pickguard cut outs will need fine tuning if you want a really close fit.
    One deviation I've run into is the old Guild humbucker as used on their 70's and reissue solid bodies. Those are neither route compatible, nor ring compatible with anything else.
    Jim_in_PA likes this.
  3. Jim_in_PA
    That's very helpful, Rotten'...I appreciate it. I"m new to this. I'd likely be using "current" stuff when it comes to the electronics and the USA vs not-USA is a good point to check for. I guess I'll check for engineering specifications for anything catching my eye as I'm kinda thinking about eschewing a pick guard on certain bodies that are either "not flat" or that feature wood that would be sinful to cover up.
  4. Andy B
    Andy B Tele-Afflicted Gold Supporter
    Colorado
    Those Guild Humbuckers are worth the effort to fit them. Fantastic sound.
    schmee likes this.
  5. tessting1two
    tessting1two Tele-Meister
    Southern California
    The Fender Wide Range Humbucker is also a different, larger size but that's a unique pickup which most body routes aren't designed to accommodate.
  6. RottenTheCat
    Drambuie, Africa
    Ah, so true, my bad, and yes, the Guild pickups are pretty nice. I've got them in an S-100 (original) and other players wonder how they get the tone, and power... Very loud, but they got "the tone".
    Will also say... those pickup rings Guild used are made of Bakelite. Crumbly stuff. I had to "rebuild" the rings on the S-100 with black superglue, filling in superglue where pieces didn't exist any more, then file, dremel, sand and polish back into some semblance of normalcy. Same thing on the tip of that bakelite Gibby L6s (original) which is prone to breaking off. Make a new one with built up superglue... takes forever, but looks pretty good, hard to see where the repair is.
  7. schmee
    schmee Poster Extraordinaire
    The nice thing Guild and Ibanez did was three screws so they dont wiggle around and sit at an angle.
    OP: most standard HB's will fit most rings. Watch out for aftermarket rings though, some dont fit screw holes Body and pickup) well at all. As others noted, wide range Tele style and off brand HB's are a bit different. But Gibson, Seymour Duncan, DiMarzio etc fit fairly well.
