Join TDPRI Today
Humbucker in neck.
Discussion in 'Just Pickups' started by guitarslinger92, Feb 28, 2012.
  1. guitarslinger92
    guitarslinger92 Tele-Meister
    205
    Jun 8, 2010
    Athens, GA
    I put a seymour duncan humbucker in the neck position on my '98 MIM. I heard a lot of people saying it was hard to get it to sound good. Well the only issue with mine is when I'm using just the humbucker it's a tad muddy (which is no issue in my opinion because I don't usually use just the neck pup anyhow) but when I combined it with my fender vintage noiseless in the bridge it sounds GLORIOUS!!! I just thought I'd share, it sound pretty awesome.
  2. JKjr
    JKjr Tele-Holic
    787
    Aug 24, 2007
    raleigh nc
    Welcome to the Middle Kingdom,where twang and boom live together in harmony. I come here whenever I can.
  3. GigsbyBoyUK
    GigsbyBoyUK Friend of Leo's
    Apr 30, 2008
    Peterborough, UK
    I too found that the neck HB was a tad muddy with an amp setting that suited the bridge PU.
    One solution would be to rewire so that the the tone pot just works on the bridge PU, so you'd then set the amp's tone controls up so that the HB sounds nice and clear, and then dial off some high end on the bridge PU using the guitar tone pot.
    My solution however was to go one step further and fit an extra tone pot between the control plate and the edge of the body. I now have a tone pot for each PU and the one for the bridge PU is almost always rolled off a bit to balance things up.
  5. PumpJockey
    PumpJockey Friend of Leo's Ad Free Member
    Oct 12, 2010
    New Joisey
    Humbuckers and mini-hums give you another weapon in the arsenal without sacrificing the twang!
  6. uriah1
    uriah1 Doctor of Teleocity Ad Free Member
    Feb 12, 2011
    Around
    - Put in a treble bleed or 60's wiring.... that adds a little highs on the neck.
    IMHO
    I do it to un-muddy p90's in a couple guitars.
  7. scottrollick
    scottrollick TDPRI Member
    78
    Nov 29, 2011
    Northwest, Louisiana
    Don't have much to say about your mud problem, but I really like the combo of a minihum and single coil. I'm thinking about putting one together that way. When dialed in nicely, the combo sounds great.
  8. Stratburst
    Stratburst Friend of Leo's
    Mar 31, 2009
    Toronto
    If you're willing to spend the $$$, some pickup manufacturers will put together a single coil pickup that's optimized for 500k pots so you'll keep the treble from your humbucker. Some manufacturers (BG, for instance) won't charge much more than the big boys, but the wait can be a problem.
  9. el cheapo
    el cheapo Tele-Afflicted
    Jan 13, 2011
    Southcentral Pa
    Never tried the Fezz Parka mod on a humbucker. Interesting!
  10. guitarslinger92
    205
    Jun 8, 2010
    Athens, GA
    Thanks I just solved all my problems by running it through a decent amp. I'd been running through a solid state fender amp, when I finally got to run it through my twin reverb, all the muddiness was gone. I couldn't be more pleased.
  11. gwjensen
    gwjensen Friend of Leo's
    ACME Guitar Works makes a Tone Shaper with a 500k pot for the bucker and resistors that dial back to 250k for the bridge.
  12. Spider
    Spider Tele-Meister
    184
    Aug 21, 2009
    New York
    Put in a 500k volume pot and the muddiness problem is solved!
