Howdy, ya'll
Discussion in 'Welcome Wagon' started by Bergy, Dec 20, 2018.
  1. Bergy
    Bergy Tele-Meister
    Denver
    Howdy there, TDPRI. I’ve been using the forum a lot lately and decided to join in. Here are some of my primary pieces of gear;
    #1. American Special Telecaster. This is my primary electric guitar and I’ve upgraded it as much as I could with recommendations from this forum (thanks!). I spend most of my time on the neck pickup, which is a Fralin Steel-Pole 43. It has convinced me that I need to seek gritty P90 sounds more often.
    #2. Huss and Dalton CM Custom. This is my primary acoustic guitar. I don’t mess with it. :) Well worn!
    #3. Gibson ES-137. I played this guitar a ton at one point. The neck-side strap button recently ripped out, which is apparently a common problem for this make. I’ve used mostly flat-wound strings on this guitar, although I plan on changing that. I also eventually plan on upgrading pickups on this at some point, unless someone talks me out of it!
    #4. 1989 Strat Plus. I’ve nearly played the frets off of this thing. Currently out of commission until I can slap some big ol’ stainless steel 6100-sized frets on ‘em (unless someone convincingly suggests otherwise, as well!).
    #5. MiM Stratocaster. I have upgraded just about everything but the pickups, and that'll be next up on the slate.
    #6. Alessandro Rottweiler. Great amp that I use when I can. I often run a Roland Cube (80 watt) instead to save wear-and-tear. Hoping to build a 5e3 at some point in the next year or so.
    #7. My Pedalboard. I run a Crybaby Wah to the right side. I don’t really use most of these pedals, except the clean boost from the Empress Buffer+, and the Timmy. Really like the sound of my Timmy at 18v. The rest of the pedals are basically options for other jam session people to use. I probably shouldn't instigate them....
    Here are my current builds that I have been referencing TDPRI for (again… much thanks, ya’ll!);
    #8. Cab Fail. Tested my finger-joint jig on some common board from Home Depot. Then proceeded to test blow-torching with steel brush-back + truoil. I failed to consider the roundover I would have to add! All suggestions on how to compensate for this oversight are appreciated! Shelves or firewood…hmmmmm… :)
    #9. Pinecaster. Also blow-torched and brushed backed. Just building up the courage to add a single bridge pickup + cavity route and attempt to hand drill some ferrules on this puppy! I am already planning on drilling the 2 E string holes, using the actual bridge as a template and then half-drilling from both sides to sink the marriage of the holes. I’m planning on using pre-drilled blocks to assist in avoiding the brad-tipped drill bit wandering. Afraid that Tru-oil might darken it too much, may opt for more of a shellac-ed look?
    #10. Alder body blank. It has to be a Telecaster. That is all I know.
    #11. Mahogany Toronado-ish build. Attempting to build a sorta Toronado-Cabronita hybrid. There are already a few different threads that are great guides for this. Might mix a p90 and a filter-tron? Going for a Pelham blue muscle car look. Think I might go for a G&L Saddlelock style bridge as well.
    Phew, that was a lot of typing! Suppose that'll be more than enough. All feedback appreciated!
    Stringbanger, Vespa_One, DonM and 3 others like this.
  2. CalebAaron666
    CalebAaron666 Tele-Meister
    Portland, Maine
    Welcome! Great collection of toys you got there!
    Like your strat, my tele’s frets are getting pathetic, but I’m still playing it everyday.
    I’m almost at the point of needing it fretted. But i get nauseous at the thought of spending that kinda cash when there’s more exciting stuff to invest in.
  3. brookdalebill
    Austin, Tx
    Howdy!
    Cool gear!
  4. unixfish
    unixfish Poster Extraordinaire
    Northeast Ohio, USA
    Nice gear. Welcome!
  5. Greggorios
    Greggorios Tele-Holic Silver Supporter
    Patterson, NY
    Nice to see ya. 10 pics...great way to start. Nice stuff.
  6. Nickadermis
    Nickadermis Friend of Leo's
    Camden Point, MO
    Welcome welcome :) Looks like you are well on your way into this wonderful addiction:D
  7. Nubs
    Nubs Tele-Afflicted
    Houston, TX
    This guy knows how to intro.
    Welcome & nice gear!
  8. Blue Bill
    Wow, great collection! Welcome aboard.
  9. Bristlehound
    Bristlehound Friend of Leo's
    Wales
    Croeso! Thanks for the pics.
  10. Bergy
    Bergy Tele-Meister
    Denver
    Thanks, folks! Took some 000 steel wool to the maple fretboard on the Strat last night. The gloss was causing an awful lot of friction during string bends ( small frets + a thick layer of gloss). Pretty happy with the results, doesn’t look as bad as I guessed it would. I also got a Les Paul that has a real gummy neck, may hafta take the steel wool to that, too. Wouldn’t have dared to try it without reading a bunch of really good TDPRI threads on it first. Tons of cool ideas goin on in this forum. I appreciate ya’lls passion for guitars.
  11. FrankJames
    FrankJames Poster Extraordinaire
    Ohio, USA
    Welcome to the forum !!
  12. GreatDaneRock
    GreatDaneRock Tele-Meister
    Central FL
    Welcome to TDPRI! Cool gear, great intto thread.
  13. DonM
    DonM Tele-Afflicted Silver Supporter
    Henderson,NV/SLC,UT
    Greetings.
  14. Vespa_One
    Vespa_One Tele-Holic
    US
    Welcome!
    Nice gear and projects.
    I'm going to attempt to hand drill ferrules also, let me know how it goes!
  15. Djentleman Dan
    Djentleman Dan Tele-Holic
    Moorpark, CA
    Hey, welcome and great looking stuff!
  16. Stringbanger
    Stringbanger Telefied Ad Free Member
    West O' Philly, PA
    Welcome to the fold!
    SB
  17. Bergy
    Bergy Tele-Meister
    Denver
    Just picked up the WEN version of a ROSS. I think de-emphasizing my router skills is a great idea. Should have details on the hand-drilled ferrules over the couple days. I predict that it will not go well, lol.
  18. Frank'n'censed
    Frank'n'censed Doctor of Teleocity
    Parts Unknown
    Howdy & welcome to Tele Town!!
  19. preactor
    preactor Tele-Meister
    gainesville, ga
    Welcome. You really have some nice gear.
  20. telex76
    telex76 Doctor of Teleocity Silver Supporter
    Fort Worth,Tx.
    Welcome aboard.
