How to wire this output jack???
Discussion in 'Tele Home Depot' started by blindsagacity, Aug 24, 2013.
  1. blindsagacity
    blindsagacity TDPRI Member
    71
    May 10, 2010
    Maryland
  2. jmczaja
    jmczaja TDPRI Member
    65
    May 15, 2011
    NJ
    Are you positive it's a mono jack?
  3. blindsagacity
    71
    May 10, 2010
    Maryland
  4. jmczaja
    65
    May 15, 2011
    NJ
    I've never used one of those personally but my guess is that it is stereo.. Just leave the long connector (most likely the 'ring') unconnected. Should be fine.. Or to be sure test with a meter..
    Here's some switchcraft tech drawings to compare.
    http://www.switchcraft.com/productsummary.aspx?Parent=884
  5. Ripthorn
    Ripthorn Tele-Afflicted
    Oct 22, 2009
    Austin, TX
    That is a mono jack with a cable relief, it looks like. I have one of these guys sitting on my bench for my current build right now. You can solder to it for ground, or not. It's up to you. All you have to do is wire the center lug and then either the other lug or the cable relief (they should be electrically connected internally so don't solder to both, you'll get a ground loop). I love these style, have used them a couple times and will never go back to a normal jack, though I will do locking in the future for certain builds.
  6. Ronkirn
    May 1, 2003
    Jacksonville, FL
    they have a center terminal, ya solder the "Hot" to and the braided shield goes to the solder tab you can see sticking out the back... it's easy.... I mean really easy..
    Ron Kirn
  7. blindsagacity
    71
    May 10, 2010
    Maryland
    Alright awesome. Thanks for the help, guys.
