How to wire separate 8 Ohm and 16 Ohm speaker input jacks?
Discussion in 'Amp Tech Center' started by dragonfly66, Apr 20, 2019.
  1. dragonfly66
    dragonfly66 Friend of Leo's Silver Supporter
    I have an amp (5E3) that has an OT with taps for 4, 8, 16 Ohms. I have 8 and 16 Ohm speakers and would like the option of using either in this amp. The amp already has two speaker inputs so I don't need to drill any new holes. I want to wire the two speaker inputs where one is for 8 Ohms and the other is for 16 Ohms. I do not want to use both inputs at the same time. The intent is to use one 8 Ohm speaker or one 16 Ohm speaker that is installed in the amp.
    I have seen examples of multi-tap setups but not like what I want. I am not certain what jacks to get or how to wired them. All of the examples I've seen have been for parallel connection of two input jacks, which is not what I want. So if you anyone can point me in the right direction I'd be grateful.
  2. Bendyha
    Bendyha Tele-Afflicted Silver Supporter
    Northern Germany
    For one, or, the other, you can make it completely simple.
    I prefer to use output jacks that are isolated from the chassis, and the cliff jack would be my normal choice. This of course is a non-american style, so for a 5E3 amp you might go for the basic switchcraft style jack, either bolting it straight onto the chassis for a chassis grounding - old school, or add isolating (insulating / shoulder) washers to the two jacks, and running a dadicated ground wire from the ring terminal tabs to where the OT is also grounded.
    robrob likes this.
  3. Bendyha
    Northern Germany
    Here is the more visual layout of the wireing, the jacks you need and the pairs of isolating washers for the jacks. The colours of the appropriate transformer taps on you OT are not known to me, so substitute as needs be.
    Wally, robrob, telemnemonics and 2 others like this.
  4. ecoast
    ecoast Tele-Holic
    NWNJ
    so isolated jacks, but should they be shorting or non-shorting?
    shorting, I would guess?
  5. schmee
    schmee Poster Extraordinaire
    Connect the NFB to the amps normal output leg (8 ohm)
    Non shorting I would think? You dont want one tap grounding while you are using the other tap right?
    I use a switch on the hot leads when I do multitaps.
  6. dragonfly66
    Thank you @Bendyha this is perfect.
    Here is what the two jacks look like now. The green is 8 Ohms and orange is 4 Ohms. Looks like I'll need to get new jacks cause the installed ones appear to have more lugs/layers.
  7. dragonfly66
    Do you have a diagram/layout (not schematic) of how the switch and jack are wired for multiple taps?
  8. telemnemonics
    I prefer a switch when the jacks are hard to see, and in general.
    You would just pull the hot wire from the center lug on a speaker jack and connect it to one of the DPST sides of the switch, then from there to the (changed to a single jack) jack.
    Same with the the other speaker jack to the other side of the switch, so it breaks the connection of one tap to the jack and connects the jack to the other tap, but both connect to the same jack. Then your switch takes one of those holes and you toss the second output jack in the parts bin.
    But you've wired it up now and if it works for you no need to change it.
    Also my description might be confusing and not very helpful!
    I'm going to presume that there are different switches lug pinout, so a diagram/ layout might be wrong if the switch you get has a different pinout.
    DPDT has two separate circuits that either make or break, so six poles, and only one throw with two on positions.
    Hope i got all that right!
    dragonfly66 likes this.
  9. schmee
    dragonfly66 and robrob like this.
  10. telemnemonics
    This makes sense, for some reason I was thinking of keeping the two transformer taps on separate sides of a DPST switch, but here it's on a SPST switch which is more correct.
    Same idea as I posted above, with no drawing though.
    I would also have put the switch in one of the jack holes since space is limited, but that's a separate issues from the actual wiring.
  11. schmee
    Yeah, the trouble is, most big Carling style switches you have to ream out the jack hole as it's too small. SO I usually end up in the old ground switch hole on Fenders...
    telemnemonics likes this.
  12. dragonfly66
    Thank you @schmee! I may do the switch instead and use one switch and one jack, putting the switch in one of the jack holes as suggested. I like it better than two jacks.
