How to clean up a 1953 Fender Deluxe
Discussion in 'Amp Tech Center' started by Wicked-T, Jan 2, 2018.
  1. moosie
    Jul 18, 2010
    Western Connecticut
    It's like autoincorrect or something... :)
  2. Wicked-T
    Wicked-T Tele-Meister
    344
    Apr 1, 2017
    I started a debate on another site about my deluxe amp, last night I replaced the tone
    control/switch with a newer CTS 1 meg (closer to spec) and switch, and once done the
    hum level dropped and is much quieter. The debate is pot's don't cause hum if bad, I
    think because of the current going though the pot if it's shielding or whatever degrades
    because of age does something.
  3. Wally
    Or....perhaps a cold solder joint? I once switched out the positions of a special pot from a Vib channel to the Normal channel due to a scratch that cleaner/lube would not correct. When I got the pots in the circuit, there was no scratchiness in that ‘offending’ pot. There was a cold solder joint causing the scratching noise.
    Wicked-T likes this.
  4. Wicked-T
    344
    Apr 1, 2017
    I'm going over it bit by bit checking everything to make sure.
