Join TDPRI Today
How to align neck and body
Discussion in 'Tele Home Depot' started by chiodoa, Aug 20, 2009.
  1. chiodoa
    chiodoa TDPRI Member
    9
    Apr 15, 2009
    Brasil
    Hello guys, I'm about to start to build my first bass.
    But I'm struggled on how to align the body and neck properly?
    How do you guys do it, do you guys trust only on the body cavity
    and neck width or is there some trick to do that?
    Thanks,
    Alessandro
  2. Jack Wells
    Jack Wells Doctor of Teleocity
    Oct 19, 2003
    Albuquerque, USA
    The method below can be used to align the neck if the bridge is installed or align the bridge if the neck is already installed. The neck mounting holes in the body should be large enough to allow the mounting screws to pass through easily. This will allow slight angular movement of the neck.
    ......[​IMG]
  3. theOutlawCJ
    theOutlawCJ TDPRI Member
    13
    Mar 7, 2009
    Austin, Tx
    There was a really good meathod I heard of recently for aligning a set neck design, but it should work for anything. Put a piece of masking tape on the body marking your center line, then put a strip on the nut of the neck, and another one at the bottom. On the two pieces of tape on the neck mark the horizontal center. Now get a laser level and see if the center line on the body aligns with the bottom and top of the neck strait through.
  5. Rob52
    Rob52 Tele-Holic
    jwells's method works well, have used the same method for years.
  6. Ronkirn
    Ronkirn Poster Extraordinaire Vendor Member
    Jacksonville, FL
    once you are through, if the neck is a little "off" it can be corrected by de-tuning to reduce tension, loosen the neck bolts and give the neck a bump laterally to correct... Even a guitar with a dead snug neck/neck pocket fit, it will still move a crack, it only takes a few thousandths movement at the nut to move the strings 1/16 at the 20th fret...
    Ron Kirn
  7. vinman
    vinman Tele-Meister
    292
    Feb 8, 2008
    long island, ny
    jwells, what are you using in the pic. regular string or elastic or something?
    thanks.
