How do You do it?
Discussion in 'Tab, Tips, Theory and Technique' started by jarpat, Apr 18, 2019.
  1. jarpat
    jarpat Tele-Meister
    Helsinki, Finland
    Headstock and string ends?
    Leaving the whole string uncut might be not so dangerous, but looks really messy and "hippie".
    Cutting the extra string away guarantees that some day it will puncture your finger tip.
    I do not like too much of "Jacksons or Floyd Roses", but stringing them is clever. Because You can not get the string end (with the ball) through the bridge hole, I've stringed it through the tuning axel. The ball stays there on the headstock and on the bridge I just cut away the extra and stick the string end in to the bridge - no worries there!
    But on a "normal" guitar - how do You do with the string ends? Leave it messy, or dangerous - or something else?
    Of course there's the ideal fender shaft too where You can "hide" the string end inside the tuning pole, but that's something I don't have on every guitar..
  2. telemnemonics
    Haha I stick to Fenders with the vintage style split shafts so I never have the ends giving me trouble!
    I do have a few without the split and just cut the ends as short as possible to avoid punctures.
    There's always locking tuners to hide the ends, and I'm looking for a set of aluminum Sperzels for a LP with Grovers on it.
    nojazzhere, JL_LI and Chunkocaster like this.
  3. awasson
    awasson Friend of Leo's Gold Supporter
    Vancouver
    All of my Fenders have split shaft vintage and surprise surprise, my first real guitar, an Ibanez Artist Series semi-hollowbody came with hybrid tuners that are split and also have a hole like regular tuners. I use them as split shaft and have no worries.
  4. beagle
    beagle Friend of Leo's
    Yorkshire
    I don't own any "normal" guitars. ;)
  5. Chunkocaster
    Chunkocaster Friend of Leo's
    In space with Ziggy
    Vintage split shaft tuners here so no problems, on my grover tuner guitars I cut the string as close as possible to the post. I do the z bend thing so no troublesome knots to hamper the string ends being close to the shaft.
  6. VintageSG
    Yorkshire
    On sub-normal guitars that insist on displaying hypodermic weaponry, I snip to around 3-5mm after stretching out and tuning to pitch, then bend the offending stabulata at 90 degrees downwards. This ensures the fluffy case liners and my delicate fingers remain unviolated.
    Tonetele and thebowl like this.
  7. Matthias
    Matthias Tele-Afflicted
    Split shaft is nice and neat... all tuners should be like that!
    Other tuners, snip them off and bend inwards around the post so you don’t cut your hand while turning the pegs!
    nojazzhere likes this.
  8. LKB3rd
    LKB3rd Friend of Leo's
    CT
    I spin the ends into a little pigtail around the peghead(doubling back opposite direction to lock it in place), then cut it with an inch or so of curl. This gives it some suspension and movement so if it pokes me it won't go straight in like a hypodermic needle!
    Cantbreak100guy likes this.
  9. T Prior
    T Prior Poster Extraordinaire
    Charlotte NC
    non fender posts, short leader, 5 wraps minimum with continued tension.
    Neat and clean
  10. fasteddie42
    fasteddie42 Tele-Holic
    Tip of the Mitt
    Ive grown to really like vintage fender style tuners.
    If I dont hace one of those, I usually leave a little tail (few mm) and then fold/kink the the tail tightly to the tuner shaft.
    Keep dem sharpies from poke'n!
  11. Jupiter
    Osaka, Japan
    Locking tuners, cut nearly flush. Some of the tuners I have actually snip the end automatically when you tighten em. No pokies.
    guitartwonk and Treadplatedual like this.
  12. WireLine
    WireLine Tele-Afflicted
    Midland TX
    If the split is present, I’ll use it. Either way I try to limit excess wraps to 2-3 turns. Each string gets one over and 2 under the string connection.
    guitartwonk likes this.
  13. macatt
    macatt Tele-Holic
    silverdale wa
    Those cut strings ends can rip the heck out of the inside of a gig bag too.
    I cut the ends with enough room left to bend them in towards the headstock with needle nose pliers; like this. (usually a little shorter than pictured)
    Don't let them touch the headstock itself and scratch it.
    S Mac
    DonM likes this.
  14. Axis29
    La Quinta, CA
    I use the knot method of securing the strings, minimal wraps and then use diagonal flush cutters to cut as tight to the mess as possible. I have one pair of cutters that are used for only this purpose. They sit in my guitar maintenance toolbox. This has worked for me for a good number of years now.
    thegeezer likes this.
  15. Junkyard Dog
    Junkyard Dog Tele-Afflicted
    I cut the excess string with wire cutters. Not any special guitar tool...just plain old hand held non-powered wire cutters. Haven’t been injured yet!
  16. Treadplatedual
    Treadplatedual Tele-Meister
    Indianapolis, IN
    On my non-locking, I wrap as little as possible and cut to within 3/8.
    On my locking, I cut as close to flush as possible and try to keep less than 1 whole wrap around the post, much better tuning stability that way.
  17. Moriarty
    Moriarty Tele-Meister
    New Hampshire
    You can cut the excess string?
    How have I missed this?
    Kidding aside I usually just cut the excess off all but the low E, which I make a loop out of because I know it annoys other guitarists. Yes
  18. Blue Bill
    I cut them to about 1/4 inch, then use needle-nose pliers to bend the pokey ends into a question-mark shape to avoid bloodshed.
    telemnemonics likes this.
  19. ASATKat
    ASATKat Tele-Afflicted
    next to the burn zone
    Why have those dangerous pokers,, how about none? I got this tip from Steve Kimock.
    Lots of wraps
    Wrap a few winds on the high side of the pegs string/hole, then the rest of the wraps go underneath the string/hole. Break the string by tight circular movements at the base where excess string meet the hole.
    No pokers and excellent grip, if done correctly there's no need to tighten up any slack or 'stretch', just tune and go on stage.
    https://photos.app.goo.gl/K5Z8P39yNzZc6kcw7
    https://photos.app.goo.gl/oqLrPVSaHsW2LZcZ7
  20. ronzhd
    ronzhd Tele-Meister
    Spring, Texas
    Clip em close on my guitars with out split shafts, and get them close to the post. Rarely get bit anymore unless I'm not paying attention.
