How do I remove an OT tap?
Discussion in 'Amp Tech Center' started by Dan_Pomykalski, May 23, 2019.
  1. Dan_Pomykalski
    Dan_Pomykalski NEW MEMBER!
    Madison, WI
    I wasn’t sure what to search for, so sorry if this has been asked, but how would I go about “removing” a speaker tap?
    For instance, if I had a better output transformer with three speaker taps, but the amp I was putting it into originally had one or two taps, would I just ground the tap I didn’t want?
  2. schmee
    schmee Poster Extraordinaire
    Just put shrink tube around the end and leave it. Don't ground it. Or cut it short and do that.
  3. Rich_S
    Rich_S Friend of Leo's Gold Supporter
    Potsdam, NY
    Don't even cut it short, you might want it some day. I would cover it with one of those white crimp-on wire nuts. You don't want it grounded or touching anything, and it needs to be well-insulated since it will have high voltage on it.
    schmee likes this.
  4. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    I never cut them, you never know. Heat shrink tubing over the end, coil 'em up and use a cable tie to keep it (them) out of the way.
    Wally likes this.
