Asher Guitars WD Music Products Amplified Parts Mod Kits DIY Nordstarnd Pickups
how can i make my strat sound more like my tele
Discussion in 'Stratocaster Discussion Forum' started by Twang King, Sep 19, 2010.
  1. Twang King
    Twang King Tele-Meister
    Jul 7, 2009
    i love my strat - almost as much as my tele - but when playing one after the other the strat sounds very thin, without the clout and punch of the tele, lots more top end too, can get shrill. any ideas on how to give my strat that tele punch?
    Tazz3 likes this.
  2. BradL
    BradL Tele-Afflicted Gold Supporter
    Feb 9, 2009
    Sussex, UK
    I think the metal baseplate on the Tele is a big factor in the Tele sound. The Strat's tremolo would need to be taken right out of the equation too (blocked off or some such).
  3. vlada
    vlada Tele-Holic
    Apr 21, 2010
    belgrade, serbia
    sell the strat and buy a tele. LOL.
    jackinjax and Ripradiant like this.
  4. 71maverick
    71maverick Tele-Meister
    Jul 22, 2010
    Urbana Illinois
    Tazz3 likes this.
  5. MN Punk
    MN Punk Tele-Holic
    Feb 9, 2010
    Nothing sounds like a Tele except a Tele.
    But you can do a switch mod to give you neck+bridge as an option. That will at least get you a kinda-sorta approximation of the Tele middle position.
    Also, maybe try setting your bridge pickup a bit closer to the strings, especially on the treble side.
    Steve Ouimette likes this.
  6. mtjo62
    mtjo62 Tele-Holic
    Jul 17, 2008
    StatesVegas, NC
    Not sure of your PU configuration, but if you have an HSS, you might try the GFS Surf 90. I have one in my Strat and I find it "Tele" like in its sound. It is definitely more lanky than a single coil and doesn't have the P90 mid bark so to speak. The quack in the bridge/mid position is very tasty. GFS has some sound clips using their delay pedal on the following page:
  7. photoweborama
    photoweborama Friend of Leo's
    Dec 16, 2003
    Sacramento, CA
    First off. put a lipstick pickup in the neck position... You need something to muddy... no.. uh... change the sound of the neck pickup.
    Then add a push pull pot so you can get a N+B combo.
    Then, put a humbucker in the bridge position, and then coil split to the BACK coil.
    I've had Tele's for years, but had to sell them due to financial problems. I ended up getting a Fender Prodigy (a Strat on Steroids). When I split the pickup to the back coil, it's the only Strat I've been able to get tele tone out of.
    By default, humbuckers split to the front coil, but that's not sharp enough. When I learned to split to the real coil, there it was! I think the metal base plate on the humbucker and spread under the inactive coil adds to the Tele sound.
    I'm not saying everyone will think this is great, but to me, it sounds as sharp as a Tele bridge pickup.
  8. telewhat
    telewhat Banned
    Oct 2, 2009
    Trying to make your Strat sound like a Tele is an odd approach. A Strat is what it is and a Tele is what it is. When you want the Tele punch while your playing the Strat you know what to do!
    Tazz3 and jackinjax like this.
  9. chipbutty24
    chipbutty24 Friend of Leo's
    Oct 16, 2008
    Ontario, Canada
    Just change the body, the neck, the pickups, bridge and pickguard. After that it will sound pretty close to a tele.
  10. MN Punk
    MN Punk Tele-Holic
    Feb 9, 2010
    And if you change 'em one at a time you can still call it the same guitar. Like Lincoln's axe. :lol:
  11. Pepi
    Pepi Tele-Afflicted
    Aug 8, 2004
    Not a LOL. It's the truth :D
    Ripradiant likes this.
  12. Durtdog
    Durtdog Poster Extraordinaire
    May 19, 2004
    While we're at it, can anyone tell me how to make my cat act more like my dog?
    nosuch and jackinjax like this.
  13. Nash
    Nash Tele-Holic
    Mar 8, 2009
    Fullerton, CA
    Rather than trying to make your Strat sound like a Tele, perhaps you should try to make your Strat sound like a better Strat.
    Sounds to me like you don't like the pickups in your Strat. A simple pickup upgrade might allow you to appreciate both guitars as individual tools for your playing.
    nosuch likes this.
  14. Telenator
    Sep 19, 2005
    Seriously, I would grab the Tele and go to the store and try a ton of Strats. You will at least then know if what you're looking for in a Strat is indeed available. If you find an awesome sounding Strat while you're there, buy it. Then sell the one you have that doesn't sound as good.
    The road to modding is paved with good intentions and several detours and cul-se-sacs.
    If you can just go out and buy something that plays and sounds awesome, why even mess around with the other stuff?
  15. bobthecanadian
    bobthecanadian Tele-Afflicted
    Put a Tele bridge pickup in the Strat.
    Zepfan likes this.
  16. Geo
    Geo Friend of Leo's
    Hendersonville, TN
    Add the bridge pickup to a separate tone control and turn it 1/4 back from
    the neck & middle with their tone knob on full.
    You might check out Jimmy Thackery on Da Tube as he gets a good Tele
    like sound like this from his Strat.
    I use a Robert Cray strat some and doing this works real well for the above
  17. Rich_S
    Rich_S Friend of Leo's
    Dec 29, 2006
    Potsdam, NY
    Like Lowell George.
    Actually, you have it easier than Mr. George did - Seymour Duncan makes the Twang Banger so you don't have to route your Strat body, cut the pickguard, mess with mounting screws, etc. The Twang Banger purports to sound like a Tele bridge pickup, but fits in a normal Strat. Yes, it has a metal baseplate, just like a real Tele pickup should.
    I can't say I've ever tried one though, I never play Strats. Look up member B Bent here or at the Duncan forum - he has one in his Jazzmaster/Tele/Strat hybrid thingie.
  18. Wardpike
    Wardpike Friend of Leo's
    Feb 16, 2008
    St. John's, Newfoundland
    You know, that was going to be my suggestion also! I don't recall seeing pictures of a full 3 brass saddle bridge assembly put on a strat, but blocking up the tremolo cavity, cutting the pickguard to accommodate a tele bridge and then installing a tele bridge assembly and pickup MIGHT do it!
    I'd love to see pictures of a conversion like that, if someone here has done one!
    Cheers, and good luck,
  19. Drunkinminer
    Drunkinminer Tele-Holic
    Feb 3, 2008
    That's what I'd do.
  20. Steely_Ken
    Steely_Ken Tele-Meister
    May 28, 2010
    Austin Texas
