Hollow Body sound vs Solid Body.
Discussion in 'Tele Home Depot' started by vinvision, Mar 17, 2009.
  1. vinvision
    vinvision TDPRI Member
    21
    Mar 15, 2009
    Ypsilanti
    I was thinking about making a Tele. An all Maple or Swamp Ash hollow body without an f hole . I love the traditional Tele sound but I was thinking the Maple would give it a lot more sting because it such a bright wood. I want this to be extra light, thats the reason for the hollow body, but if it's not going to twang then I'll just go with a Swamp Ash solid. Does anyone knows how much the Hollow body changes the sound.
  2. mrothacker
    mrothacker Tele-Meister
    401
    Oct 6, 2008
    Asheville
    It will have an affect on the sound of the guitar but other factors will also . I bought a Squier Vintage Modified Tele Thinline that is made of alder , I would have expected a little more beef or mids from it but it sounds amazingly like a solidbody . I think a lot of that has to do with the pickups that are in it . Dont get me wrong I think it sounds great and it is also lightweight .
    I believe your thinking is correct though on the effect on the tone of using maple for the body . If you do use maple I would definately recommend routing it like a thinline to lower the weight of the body . I think putting a top on it without the Fhole will have minimal affect on the tone compared to having the Fhole .
    Another thing you may want to consider to add to the twang factor is using an ebony fretboard on a maple neck , although it is probably overkill , but it will add snap to the tone .
    One last thing is to use pickups with resistance ratings that are close to the original 50s Tele pickups . Hotter pickups will have more mids and less highs . Also stay away from stacked humbuckers as they will also have less highs .
  3. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    Maple guitars are bright, but even hollowed out, maple will be a heavy guitar body. Also, maple won't give you that classic twang sound as well as swamp ash or alder. You'll be able to get that sting you want from a good pickup and good body.
    Thinlines sound different than solid body guitars. If you are really after that classic tele tone, a light swamp ash body and good set of pickups is the way to go.
    I invite you to check out posts by Arlo West and his pinecasters. They sound great.
    Also, here is a link to my pinecaster. Sound clips are on the second page.
    http://www.tdpri.com/forum/tele-home-depot/151309-colts-first-pinecaster.html
    Not all ash or even swamp ash is the same. You can have a 3.5 lbs body or a 7 lbs body. If you order your blank from a reputable supplier like USAG or others, they will be able to select a blank that will suit your weight needs. Pine also provides a great soudning light weight guitar.
  4. vinvision
    21
    Mar 15, 2009
    Ypsilanti
    I was thinking about doing the ebony fret board and I'm defiantly going to go thru USAG for the body. For the pups I'm fighting between Twang king neck,Fast track bridge or Don Mare set. Thanks for the help.
  5. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    Don makes great pickups, and he is a great member here on the forum. I just can't afford his pickups. I have all mine made by O.C. Duff, and I keep hereing good things about Dimarzarrio Twang King. I think my next build is going to utilize a set of Twang Kings.
