Hollow body LP? Solid Body LP? Dunno, both I guess
Discussion in 'Tele Home Depot' started by Muzikp, Apr 15, 2015.
  1. crazydave911
    East Tennessee
    My favorite kind of guitar :cool:.Wasn't well known but Aria made one back in the day and I ALMOST bought.Got an Aria Les Paul clone instead.Was killer on the Bread song leads I got it for but always regret not following my heart, they built VERY good in those days
  2. Muzikp
    Muzikp Friend of Leo's
    Sacramento
    You know, on second thought. I'm pretty sure it's only worth about $7. I'll give you $14 and cover shipping.
  3. Muzikp
    Sacramento
    And I probably won't steam it all apart either.
  4. musicalmartin
    musicalmartin Poster Extraordinaire
    Norfolk UK
    There is no sign of any kerfing so I assume machined out but the belly is arched beautifully and drums well .My Gibson Midtown ,also gouged out but with a centre block is much duller.Top maybe two ply or just even one ply .Difficult to tell .As I dont have any problems with it I havnt bothered taking it apart .Its beautifully made .Not a single fault anywhere .Maybe I got the demo model sent to get some sales in before production values dropped. Keiper are known to be patchy quality wise and just a cheap to Germany import .I only paid 60 quid for it .Its loud to play unplugged a real acoustic vibe to it .I was surprised how good it is .No idea where it was made .Like any hollow body it feeds back like when cranked up but plays hottish blues well and its perfect for warm finger style jazzy stuff.Naturally it suffers from its small size so hasnt got the acoustic depth of a huge hollow body buts good enough ,I will try to post some more pics.Its certainly a reminder of just how good Asian woodwork can bes.,often it gets lost in the hardware spec
  5. Muzikp
    Sacramento
    Time to get this neck done. I made a new spacer between the body and fretboard, the old one was awful.
    The sides of it are tapered to match the heel of the neck.
    And it's wedged shaped for a perfect fit.
    Testing the wedge shape here, still need to trim down to perfect size.
    Then glue it on
    With that done it's time to fix the headstock. Got the neck clamped safely in the vice so I can pry the crack open and inject glue.
    Thin down some glue to put in the syringe
    Poured the thinned glue in and pointed it straight up and tapped it while pushing the plunger to get the air out like TV Dr's do. The plunger was hung up on something and not going in well, and when I put enough pressure on it to finally go in it went all at once and shot glue everywhere.
    I got really lucky with that since I had a body and a neck not far away getting clear coat applied, you can see the neck in the background. One of the glue blobs missed the neck by a few inches. This was all the glue left in the syringe after the eruption
    That must have rattled me enough to stop taking pics but the glue is all squeezed into the cracks and it's clamped up to dry.
    Barncaster likes this.
  6. Muzikp
    Sacramento
    Then I started sanding the clear coats off this strat body so I could put more on. I'm sorta grain filling with lacquer here. This body has no color or tint on it, it's all natural. I tried to grain fill it a few times with a matching color grain fill but it never looked good enough to me. So I stripped it all off and I'm trying to fill the grain with lacquer. You can see the pores in the wood below the jack hole area. Not sure how well it's going yet.
  7. Muzikp
    Sacramento
    I'd say I'm not having a perfect day in the shop, some days I should just go do something else I think. I ordered new water slide decal paper off Amazon and I'm really having trouble with it.
    I started by spraying a mist coat over the printed decal to seal the ink just like the instructions say and all the other water slide paper I've ever had. I let that dry and cut out the decal, all good so far.
    Soak it in the water
    And end up with this... about 5 times I ended up with this.
    What I've noticed is this decal paper is way thinner than any other I've used, which will be great when I go to bury it in clear but, the lacquer seems to melt the thin paper and it just isn't use-able. So I printed a new sheet and sprayed a very light coat of poly over the decals. I know lacquer over poly is a no no but if I carefully mist the lacquer on I might get it to work. So far so good, this is after 3 light mist coats of lacquer
    R. Stratenstein and Barncaster like this.
  8. schmee
    schmee Poster Extraordinaire
    Solid, if you want to deaden something put encapsulated air in it.
  9. magicfingers99
    magicfingers99 Tele-Afflicted
    atlanta
    metal and an aluminum telecaster body soon.... some people consider aluminum to be metal. Did you perhaps mean metal and Anthracite or metal and Aardvark or maybe Mollusk and Aluminum?
  10. Muzikp
    Sacramento
    Good catch, I meant a mild steel body and and an aluminum body, so two I guess.
  11. Muzikp
    Sacramento
    Hmmm, I'm sure I'll take that to heart as soon as I figure out what you are talking about :D
    guitarbuilder likes this.
  12. schmee
    hah! Thread title. Seems to have little to do with thread though!
  13. Barncaster
    Northern California
    I have encapsulated air in me.....
  14. Muzikp
    Sacramento
    With the headstock back to solid I can start on the finish repair. I'm only repairing the finish where your hand would touch the back of the neck and I'll do my best to blend it in to the old. Keeping the cool patina as much as I can. Did I mention black is the hardest color ever to match.
    Started by sanding some really deep gouges in the finish out.
    And this is my first color test to see how the match is when it dries. Not too worried if it doesn't match perfect at this point, this is just a filler coat that will get sanded a lot.
  15. Muzikp
    Sacramento
    Apparently that makes you deadened (just made that word up I think).
  16. crazydave911
    East Tennessee
    :lol::lol::lol::lol:
  17. magicfingers99
    atlanta
    don't forget to put rf shielding in the cavities, no wait that's probably overkill. Ovation used to build the bottom of the line guitars with solid aluminum necks - the idea was when the frets wore down you just replace the neck. If you can find one of those necks and refret it with stainless steel it would last forever.
    here's some info on the aluminum necks, they used some on acoustic and some on solid body electrics
    http://uniqueguitar.blogspot.com/2009/11/ovation-kaman-corporation-aluminum-neck.html
    the nice thing is no truss rod ever needed...
  18. Barncaster
    Northern California
    Yes, it will definitely deaden anything standing behind me......
    Muzikp likes this.
  19. Muzikp
    Sacramento
    With the coats of paint going on the necks and getting sanded off I can tackle the last issue before reassembly. The jack hole is whack! Multiple cracks all the way thru and pretty long cracks.
    Need to make a backing piece to glue inside to tie all the cracks together and reinforce this area.
    Had to thin it down and check that the tone pot would still fit, what a disaster that would be if it didn't fit :eek:
    The final shape
    Recess the jack inside
    That's just long enough to get the nut on after it's glued in. Might switch to a longer jack so I can use a Les Paul style plate on the outside of the body, not sure yet.
    Inside looks like this
    I use tubing to pull it thru the guitar.
    Glue
    Pull it thru, screw it down to clamp against the side. I'll let it sit upright overnight in case any glue wants to drip.
    Tomorrow I can fill the cracks and touch up the black and should start to reassemble this thing soon.
  20. R. Stratenstein
    Loganville, Ga.
    Easy there, fella ! :D
