Hollow body LP? Solid Body LP? Dunno, both I guess
Discussion in 'Tele Home Depot' started by Muzikp, Apr 15, 2015.
  1. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    Great idea Rick. I like it. Drywall screws are a necessity for guitar builders..
    R. Stratenstein likes this.
  2. R. Stratenstein
    Loganville, Ga.
    Upon closer reading and examination of the photos, I think I must amend this explanation. James did indeed fabricate a new dovetail piece to fit the dovetail pocket, which I assumed he would then glue, maybe with dowels, to the neck, then reset the neck as done originally. However, it appears James has replaced the dovetail piece attached to the neck with a tenon, not a dovetail, and has glued the dovetail piece into the dovetail socket in the body, and will machine a mortise into the dovetail block, to match the tenon. This means there will be no dovetail to hold the neck into the body, only a small tenon, much too small to hold with glue alone. Obviously, James is going to use large drywall screws to hold the neck to the body.
    This makes me very happy, as James is a master craftsman, so when I am able to guess how he will effect a repair, it means that I, too, am becoming a master craftsman!:cool::cool::):)
  3. Jupiter
    Osaka, Japan
    Aha! That was my guess. But I'll wait to see about the drywall screws.
  4. Barncaster
    Northern California
    With the tenon glued into a soon-to-be-revealed matching receptacle in the dovetail portion, it becomes a new perfectly-matching dovetail on the neck. I think this modular approach is brilliant!
    crazydave911 likes this.
  5. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    My guess is that he's converting it to a bolt on.
  6. Barncaster
    Northern California
    Brainy definitely would have contorted that statement into something about the superiority of a strap-on vs a bolt on but I would never go there.
    coonhollow greg likes this.
  7. crazydave911
    East Tennessee
    Bingo! :)
  8. Muzikp
    Muzikp Friend of Leo's
    Sacramento
    Hey I didn't know there was conversation going on in here.
    Ok so it's going to be a double dovetail. I shaped the part of the neck I kept into a slight dovetail, much less than 10 degrees like you typically see but I did want some dovetail. So I will make a dovetail inside the piece I matched to the body and glue it to the neck. Then I can reset the neck with the bigger dovetail that I already made. That probably makes no sense. I'll go out to the shop and take some more pics.
  9. Barncaster
    Northern California
    You told is to talk...
  10. Muzikp
    Sacramento
    It's hard to tell but I've shaped this into a dovetail, or sloped the sides I guess.
    Now I need to make a matching dovetail in the piece I'm holding which will glue to the neck.
    It will fit tight against the heel of the neck so lot's of gluing surface. Once that's glued on I can reset the neck like any normal dovetail neck set.
    Make any sense now?
    crazydave911 and RogerC like this.
  11. Muzikp
    Sacramento
    Yeh I know but I never got a notification that you actually listened :lol:. Carry on.
  12. Muzikp
    Sacramento
    This is a for reals archtop, and archback as well. Not easily duplicated in a garage but several here have done it and documented it well.
  13. R. Stratenstein
    Loganville, Ga.
    Carved or pressed ply?
  14. Muzikp
    Sacramento
    3 piece pressed ply.
  15. Muzikp
    Sacramento
    Slotting the... thing.
    That's a good start on that, need to slope the sides of it to match what I did on the neck.
  16. RogerC
    Oklamerica
    Nice work, James! Pretty clever fix.
  17. Barncaster
    Northern California
    Ah yes I see, the mating doves technique. Very Brainy.
    Muzikp likes this.
  18. Muzikp
    Sacramento
    Thanks Rog. I think I can see the end of the neck reset in sight, then I can tackle that reinforced truss rod cover dilemma.
    Barncaster likes this.
  19. Ongo Gablogian
    Ongo Gablogian TDPRI Member
    US of A
    I'm way late on this thread, but I've read all the way through. Excellent all the way around!
    But one question, what will happen with the hollowbody LP???
  20. Muzikp
    Sacramento
    Oh that's right, we were building a hollow body LP :lol:. I don't have any plans at the moment to finish it mostly because I still don't like the carve on the top and it's too thin to fix the carve. I need to run that thing thru the drum sander and make a new top then I might get excited to work on it again.
    Barncaster and Ongo Gablogian like this.
