Hide glue over paint?
Discussion in 'Finely Finished' started by jsnwhite619, Oct 1, 2017.
  1. jsnwhite619
    jsnwhite619 Tele-Afflicted Ad Free Member
    Sep 10, 2013
    Georgia
    I'm working on a cabinet that I plan on tolexing. I painted the inside and the corners with flat black, brush-on latex paint to help hide any gaps & match the tolex, then after it dried, I wondered if I had just messed up. Will the paint create any issue with hot hide glue bonding the tolex to the cabinet?
    Thanks
  2. Silverface
    Mar 2, 2003
    Lawndale CA
    It depends on how well the paint adheres. Hide glue shrinks as it dries and cools, which pulls wood together in joints and pulls tolex down onto a surface. If the surface is unsound it will come apart.
    Press duct tape tightly down on the paint - rub it down with something smooth and hard - and pull it off, across itself at a sharp angle if possible. that will tell you how loose the paint is and may remove most of it if you're lucky. If removal is extensive but random I think it should be scraped off. A Cabinet scraper should make quick work of it.
