Help with grid resistors value(Wattage)
Discussion in 'Amp Tech Center' started by NMore, Apr 13, 2019.
  1. NMore
    NMore Tele-Meister
    Castle Rock
    So I just finished the recap on my Fender Bules Deville, and turn on the power and just get a loud hum. Then I notice the grid resistor job that was done on it by electric city. They broke off the soldier joints. Tried to resoldier but there is no lead what so ever, left so I have to order 2 new resistors. The values I looked up is a 1.5k ohm but not sure if they are 1W, 1/2W or 1/4W... Help. Thanks
  2. schmee
    schmee Poster Extraordinaire
    Not sure in that amp but I usually just put in 2 watt or higher..
    Teleguy61 likes this.
  3. NMore
    NMore Tele-Meister
    Castle Rock
    yeah the schematic just says 1.5k ohm.
  4. NMore
    NMore Tele-Meister
    Castle Rock
    Yep everything I readsays 2w so that's what i'm ordering. Thanks
  5. Ten Over
    Ten Over Tele-Meister
    Central California
    1/4 watt is fine electrically, but you might use a higher wattage just to have a physically larger and more stout piece to mount in that funky way.
  6. NMore
    NMore Tele-Meister
    Castle Rock
    Thanks for that advice.
  7. dan40
    dan40 Tele-Afflicted Silver Supporter
    Richmond Va
    If the 1.5k is attached to the control grid, 1/4 watt would be plenty as Ten Over mentioned above. I like 1 watt here just for the physical strength of a larger resistor. If those were attached to the screen grid, 2-5 watt is the preferred rating.
    Wally likes this.
  8. Andy B
    Andy B Tele-Afflicted Gold Supporter
    Colorado
    1.5K 1 watt metal oxide for the control grid. 470 ohm 2 watt metal oxide for the screen grid.
  9. NMore
    NMore Tele-Meister
    Castle Rock
    Thanks Guys.
  10. sds1
    sds1 Tele-Holic
    Orlando, FL, USA
    The stock ones were probably 1/2W. 1W would be fine, I don't see any reason to pay extra for 2W resistors here but won't hurt anything.
  11. Wally
    fender used 1/2 watt resistors for the control grid stoppers back in the day. Their modern amps use /14 watts. I see no reason to go above 1/2 watt....and I have never seen larger resistors than 1/2 watt used there.
    D'tar likes this.
  12. NMore
    NMore Tele-Meister
    Castle Rock
    I ended up buying the 1/2 watt resistors. Thx
    Wally likes this.
  13. sds1
    sds1 Tele-Holic
    Orlando, FL, USA
    Lame!
  14. NMore
    NMore Tele-Meister
    Castle Rock
    Finally got the resistors and installed them last night. I thought I had done something wrong because when I took the amp off of standby there was no noise and then I played a chord and MAN! The recap made this thing sound amazing. Thanks for the help guys!
    Wally likes this.
  15. NMore
    NMore Tele-Meister
    Castle Rock
