Help with contours
Discussion in 'Tele Home Depot' started by YALCaster, May 10, 2018.
  1. ndeli55
    ndeli55 Tele-Afflicted
    May 12, 2008
    oklahoma
    My dragon rasp makes quick work of these jobs, but the trouble is making it flat afterwards.
  2. Deegatron
    Deegatron Tele-Meister
    203
    Feb 5, 2014
    Alberta, Canada
    I take a slightly different approach than most. I draw out my contours on the body and then put the body in my thickness router jig. then I freehand rout the contours in steps matching up to the contrours I drew on.
    Gets the bulk of the material removed rather quickly and accurately.
    Then you just kinda "connect the dots" with a rasp, sand to 80 then 120 grit (I leave the finer sanding for right before finishing)
  3. ndeli55
    May 12, 2008
    oklahoma
    For the arm carve, I like to use my hinge box. A little trigonometry and some simple layout, then go at it. It makes the work fast.
  4. Macrogats
    Macrogats Tele-Afflicted
    May 15, 2017
    Auckland, New Zealand
    R. Stratenstein likes this.
  5. YALCaster
    YALCaster Tele-Meister
    254
    Jul 24, 2017
    noitacoL
    Here’s the template set for anyone interested
    loopy reed likes this.
  6. jimgchord
    jimgchord Tele-Holic
    627
    Apr 3, 2018
    victor,ny
    Chisel, then rasp, then sandpaper. Nuthin to it.....Bing,bang,boom.
  7. DavidV
    DavidV TDPRI Member
    61
    Dec 9, 2017
    Springfield, MO
    You can rasp the whole thing in minutes if you use a Farrier's Rasp, then just clean it up with a standard rasp and sandpaper. A shinto rasp is pretty good but still takes a while
  8. YALCaster
    254
    Jul 24, 2017
    noitacoL
    Another question, do I round the edges with a router bit before or after I do the contours?
  9. guitarbuilder
    Mar 30, 2003
    I do as much as I can with a router bit and then do the contour roundovers by hand with a file and abrasive. For the contour roundovers, I put two lines around the edges with a pencil to denote the starting and stopping points of the curve. Then I will file a 45 degree angle there as a primary facet, and then round that into the roundover.
  10. YALCaster
    254
    Jul 24, 2017
    noitacoL
    That makes sense. Thank you!
  11. loopy reed
    loopy reed Friend of Leo's
    Nov 14, 2007
    Nashville, TN
    Dammit this was gonna be MY next build. Where did you get these?
  12. Wallaby
    Wallaby TDPRI Member
    34
    Feb 19, 2018
    Midwest
    Being a hand-tool kind of guy, I would use a rasp and an inshave or a spokeshave.
    It's surprising how much material a good French rasp removes, and quickly!
    YALCaster likes this.
  13. Macrogats
    May 15, 2017
    As I said - rasp and sandpaper. :D I did use my largest round over bit on most of the body first though. 3/8ths I think.
    Please note - I wasn't going for major contours on the bc or forearm. Just what felt good to me.
  14. trev333
    I've only done one.. on a lefty build....
    I marked the back radius trying a few different dinner plates for size.....penciled in the edge line, connected the lines with a saw, chiseled/knocked out the pieces then finished with a 4" flap grinder/rasp/sanding blocks...
    came up OK....:)
    Macrogats likes this.
  15. Mad Kiwi
    Mad Kiwi Friend of Leo's
    Now that's a nice piece of wood Trev!!!
    trev333 likes this.
  16. trev333
    Ta.... it came from a Pine corner benchtop I got at the scrap yard cheap.....hard as hell, yet light..... good wood indeed....:)
  17. Macrogats
    May 15, 2017
    Nice wood and great technique Trev!
  18. crazy_aussie
    crazy_aussie Tele-Meister
    114
    Mar 9, 2011
    Adelaide
    I've done a couple - 1 on a Tele and 1 on a Jazzmaster. Used the same technique for both. Marked it out on the body with a pencil then used the trust ROSS to get the shape I wanted. Quick and easy.......:D
