Help with buzz
Discussion in 'Amp Tech Center' started by robotguitar, Apr 6, 2013.
  1. robotguitar
    robotguitar Tele-Holic
    visalia, CA
    Recently got a 1967 Fender Vibro Champ shipped back from repair. It sounds great but there is some buzz. The tech is well respected but here is the issue. With a tele, strat, and les paul, there is a buzz that sounds like a ground issue. If I turn the volume down on the guitar it goes away. Also, if I turn the tone down about half way it goes away as well. When I plugged in my 1960's Tiesco Delray, there was no buzz at all. Is this something I just have to live with or does this sound like a problem with the input jacks on the amp. Of the two input jacks they both act the same. Thanks.
  2. Lunchie
    Lunchie Poster Extraordinaire
    Downstate Illinois
    I could be very wrong but, it doesnt sound like the amp to me. If it was the amp the hum would be there whether you have the guitar volume at zero or dimed. Are your guitars stock or have they had work done to them?
  3. DTPBUSCHPILOT
    DTPBUSCHPILOT Tele-Afflicted
    McKinney, TX
    Take it to Doug @ DAMAGE INC.
  4. robotguitar
    visalia, CA
    The guitars are all stock. Doug is not around unfortunately. I hope he goes back into business but I think hes still recovering. I might be over reacting. It is a pretty slight little buzz. Just enough to annoy me.
  5. DTPBUSCHPILOT
    McKinney, TX
    Recovering? Wha Happened? I'm an old Visalia boy myself. I bought my MXR Distortion + from Doug years ago...
  6. Harleyjon
    Harleyjon TDPRI Member
    England, UK
    Does the hum/buzz go away if you touch the strings and the case of the jack plug from the lead at the same time?
    If it does the guitars need looking at, electrically, as far as ground shielding is concerned.
  7. robotguitar
    visalia, CA
    He had medical emergency and was in the hospital for a while. He got evicted while in there and I dont know if he gonna keep his business going. I hope he does.
  8. telex76
    telex76 Doctor of Teleocity Silver Supporter
    Fort Worth,Tx.
    If it doesn't do it with every guitar then the problem is not in the amp.
  9. robotguitar
    visalia, CA
    Well, it could be the electrical. The old guitar I used has lower output on the pups than the modern ones. The guitars are fine on other amps. I need to try the amp with a power conditioner maybe. I can live with it for now. Thanks for the replies
