Join TDPRI Today
Help! Transformer snapped off amp?
Discussion in 'Amp Central Station' started by Paulie13, Feb 13, 2013.
  1. Paulie13
    Paulie13 Tele-Holic
    581
    Feb 16, 2009
    Atlanta
    So I decide to fully retube my amp for the first time in awhile. As I am looking around the back of my amp, I realize something looks off. The transformer has snapped at the piece where it connects to the rest of the amp. It is working fine and I would have never noticed the problem without retubing my amp. Since I just caught it I have no idea how long it has been this way either.
    What should should I do? Anyway to fix it/prevent it from getting worse?
  2. jhundt
    jhundt Poster Extraordinaire
    Mar 23, 2003
    Netherlands
    I have a homebuilt amp based on an old Traynor chassis. I used it hard for about 5 years. One day I looked in the back and found that all 4 mounting tabs had broken off the power transformer and it was just hanging by the wires.
    I spent many hours fashioning some new mounts from small 90-degree angle irons. It seemed like a lot of trouble, but I had more time than money. I wonder what a replacement transformer would cost you?
  3. Paulie13
    Paulie13 Tele-Holic
    581
    Feb 16, 2009
    Atlanta
    I am not sure. It still is connected on one side, and sounds absolutely fine so I'd hate to switch until I absolutely have to. . And unfortunately I am probably not handy enough to craft some new posts
  5. winny pooh
    winny pooh Friend of Leo's
    Jan 24, 2006
    South London
    You can buy teeny L shaped brackets that are used to support 90 degree corners on wood joints. I used these to mount a laydown tranny upright on a kit build.
  6. teleamp
    teleamp Poster Extraordinaire
    Oct 17, 2006
    Under scrutiny...
    I would fashion a "L" bracket, remove the broken tab, remove the two screws on the PT, attach the L bracket and secure it to the original mounting hole on the chassis.
    I imagine it broke during transit, if you ever ship the amp again, make sure it has no free play in the packing and shore up the PT so that has no room to wiggle when the package is dropped.
  7. gwjensen
    gwjensen Friend of Leo's
    Looks like NAD time :lol:.
    However, like the previous posts, it looks to me like you could connect one end of an L braket to the screw with the yellow washer, and one end to the screw in the amp chassis.
    Before doing anything, you might want to wait for one of the forum sages, like Muchxs, who actually build and service amps, to weigh in.
  8. BobbyZ
    BobbyZ Poster Extraordinaire
    Jan 12, 2011
    Snellman MN
    I did an L bracket google search there's a ton of them they come in all shapes and sizes. Here's two from google images.
    You never know what you'll get on google images.:lol:
  9. jhundt
    Mar 23, 2003
    Netherlands
    that's what I did, I had to make 4 of them It was a pretty long and difficult process, I had to file the heck out of those things to get 'em to fit. It wasn't really hard, it just took quite a bit of thinking and tinkering to get them to fit the transformer and the chassis.
  10. jmiles
    jmiles Friend of Leo's
    Nov 29, 2003
    ohio
    Or you could bend a simple bracket that goes from the opposite side screw hole, across the top of the tranny, and down to the screw for the broken bracket. Not as elegant, bu,,,,,,,,,,Not too sure I'd want to remove the screw with the yellow washer, as it's one of the screws holding the leaves of the transformer together. Maybe I'm too cautious?
  11. lewis
    lewis Friend of Leo's
    Colorado
    ...but what do I know?
  12. BobbyZ
    Jan 12, 2011
    Snellman MN
    I was going to say. (I got distracted) That to fix this you will need to get inside the amp so you'll need to know how to discharge the filter caps to do it safely.
    Pretty simple fix like the other guys said. Just some work with a drill, file and maybe a hacksaw, hammer and grinder.
    I wouldn't worry about pulling the screws out of the transformer just don't pull them all out at the same time.
    Onother fix would be to just change the endbells on the tranny if you can get them. But they already broke so I wouldn't bother.
  13. bo
    bo Friend of Leo's
    Arlington, VA
    Reverend amps were made with the transformers hose clamped to the chassis. Seems to work fine.
  14. thumbpick
    thumbpick Tele-Afflicted
    Nov 22, 2012
    somewhereville
    ...2 part epoxy.....white and black crap....mix up a wad...jam it in there..nobody gonna see it but you... and it will hold....
  15. tresspassor
    tresspassor Tele-Meister
    276
    Jun 17, 2010
    Austin
    universal fixall
  16. printer2
    May 24, 2010
    You don't have to worry about the transformer falling apart if you take out the bolts as they are varnished together. Get a piece of metal at least the same thickness as the one that snapped and work to fit. I doubt the bolts will be long enough for those ready made corners or if they will fit in the space with the bend they have.
  17. jefrs
    jefrs Doctor of Teleocity
    Nov 20, 2007
    Newbury, England
    Meccano job - make or buy a little L-bracket
    Btw- remove the mains plug from mains completely, nothing plugged in, then by the time you have the chassis out those big nasty caps will have discharged far enough to only give you a little fright. If in doubt, stick your voltmeter across them until they read zero. The voltmeter will both safely discharge and indicate safe.
  18. T Prior
    T Prior Poster Extraordinaire
    Charlotte NC
    +1 "L" bracket
    easy fix
  19. ice_pick
    ice_pick Tele-Meister
    340
    Jun 8, 2012
    Midwest
  20. jhundt
    Mar 23, 2003
    Netherlands
    I forgot to mention - I had to replace the long bolts through the transformer, because they were not long enough to attach the new brackets that I made. The new brackets were not long enough to reach the mounting holes, so I had to stack a variety of washers between the brackets and the transformer to space everything correctly. Then the long bolts through the transformer were too long and interfered with the chassis-mounting bolts...
  21. Paulie13
    Paulie13 Tele-Holic
    581
    Feb 16, 2009
    Atlanta
    Thanks everyone. I had thought about doing the JB weld epoxy. So unscrewing the screw on the side of the transformer is safe? If I can get an L shape bracket to fit that might be best like a few of you have said.
    Do I need to worry about discharging if I am using an L bracket with the holes already in place?
