Join TDPRI Today
help! my bridge plate is buzzing like crazy when i touch it...
Discussion in 'Just Pickups' started by vanguard, Feb 6, 2009.
  1. vanguard
    vanguard Friend of Leo's
    Feb 7, 2007
    Charleston, SC
    i just did some rewiring on my tele. i have a nocaster bridge and a don mare stelly neck. i had to wire the bridge pickup with the wires swapped to avoid the dreaded out of phase middle position. but there's a problem. the neck pickup sounds great, and the middle and bridge work, but the bridge position hums like crazy. when i touch the bridge it pops a bit and the buzzing lowers some. also, when i touch the control plate. when i run my fingers along the strings, there is a nasty distortion.
    what's going on:confused:
    edit: i should mention that the bridge pickup has a base plate, so it should be grounded without the wire under the bridge. up until the the new neck pickup, there was never a problem there.
  2. mellecaster
    mellecaster Former Member
    Since you switched the wires on your bridge pup...you have to now modify the jumper to the plate, with what is now the ground wire.
  3. vanguard
    Feb 7, 2007
    Charleston, SC
    i'm a novice to all this. could you explain in lay man terms? i'm not sure what jumper to the plate is, or what ground wire we're talking about. i just follow diagrams:oops:
    also, if i hook the bridge pickup wires normally, and swap the wires on the neck pickup instead, the neck pickup buzzes the same way when i touch it.
  5. Don Mare
    Don Mare Tele-Afflicted
    Mar 22, 2003
    CA.
    thats due to Hot Running into the Bridge from the copper coated elevator base plates adjusting screws,
    take and clip away the bare metal ground wire from the base plate (only) ( not the black cloth wire from the eyelet ground )
    ~next run a separate ground wire to that base plate and it should all be back to normal -
    its like the neck - when you switch Ground wires to "hot" you must take out the ground jumper wire to the necks metal cover or in your special case the "base Plate"
    usually we only reverse wires at the neck pickup on a Tele-
    this is because - sometimes the bridge pickup will not stop grounding out to the base plate
    - as it was- the old Fenders will sometimes ground the magnets to the plate - this happend from those pesky partial shorts in the start wires of the fine wire coil itself.
  6. vanguard
    Feb 7, 2007
    Charleston, SC
    boy, that sounds messy. this bridge pup is the old collectible one that goes for like $250 on ebay. don't wanna screw with it. i'm gonna put the bridge pup wires back to normal and switch the stelly wires. is there a simpler way to keep the neck pickup from buzzing when i touch it?
  7. twangcaster1
    twangcaster1 Friend of Leo's
    Feb 28, 2008
    Nashville, TN
    Don't you live in Utah? I'd fix it for you for free just for the heck of meeting a fellow TDPRIer.
  8. vanguard
    Feb 7, 2007
    Charleston, SC
    yep. that'd be cool. can we fix it without modding the pickups? like just with wiring?
  9. Don Mare
    Mar 22, 2003
    CA.
    same trick -- take off the bare wire that connects the coils ground over to the cover - look at the bottom of the pickup - see the shiny solder joint in the middle? - thats hiding a small bare wire - heat that joint and lift that wire away from the covers bent over metal holding tab -- next solder a whole new section (piece) of wire. one thats at least 13" long ~~~ and run it on under with the others, so it runs on over to the cavity - where it then gets soldered to the back of any pot , it acts as a ground for that neck pickups metal cover.
    no more buzz;)
  10. twangcaster1
    Feb 28, 2008
    Nashville, TN
    Yep. Just wiring.
  11. mellecaster
    Here's a Picture of what the folks are trying to explain for you.
  12. Don Mare
    Mar 22, 2003
    CA.
    Nice picture, ( i copied it and save it- very helpful indeed!- for future customers)
    : but it shows the cover taps on 180* out - normally on all fenders we see just one tab (centered) on the cloth wire on hook up side of the bobbin ~ and so the remaining two tabs from the metal pickup cover are always on the non hook up side of the bobbin ...
    actually the cover will not fit on as shown - as the tabs would not bend all the way around the angled part of the bobbin
    Add section of wire to that metal covers tab that comes thru that center hole - thats located between the two eyelets that the cloth braided wires solder to
    But First:
    Remove this section of bare wire that I highlighted with a Red marker - cut away that section of bare wire ( simply clip it away is the safest - that way you do not heat the coils black wire thats soldered into the tiny brass eyelet along with the coils very fine hair wire - thats actually your pickups "magnet coil~ start wire"
  13. vanguard
    Feb 7, 2007
    Charleston, SC
    thanks, guys. great, helpful pics and charts. worked like a charm, and now everything sounds great!
  14. mellecaster
    We all Love Happy endings....don't we.......;)
  15. vanguard
    Feb 7, 2007
    Charleston, SC
    :lol: i actually had a dream about an asian masseuse last night:oops:
    then i woke up right before the good part and saw my wife looking over the side of the bed. i asked her what she saw, and she was asleep! she was really embarrassed when i asked her about it the next morning. she finally confessed she was dreaming little fraggles (remember that show?) were driving tonka trucks around on the floor with balls of yarn in the truck beds. she was picking out the ones she wanted to make a new sweater:confused: WTF, honey?
