Help me find a delay pedal...
Discussion in 'The Stomp Box' started by jguitarman, Oct 4, 2017.
  1. Sounds Good
    Sounds Good Tele-Holic
    517
    Oct 2, 2017
    Luton UK
    Sorry to repeat myself! already put this one up once on another thread but not a delayed one so here goes.
    A behringer echo machine is cheap as well and many features also.
  2. JJAdams1956
    JJAdams1956 Tele-Meister
    111
    Dec 14, 2016
    Los Angeles
  3. sammy123
    sammy123 Tele-Meister Gold Supporter
    387
    Jul 25, 2011
    MKE
    The Behringer Echo Machine is a nice pedal with nice features. So is the Reverb Machine (which also has an echo mode).
    Sounds Good likes this.
  4. Rich_S
    Rich_S Friend of Leo's
    Dec 29, 2006
    Potsdam, NY
    What the heck are you people talking about? Effects loops? Preamp gain? Read the OP... ROCKABILLY BAND. We're talking cleanish amp, with dirt/compression mostly coming from the output stage of the amp. Delay pedal will be in front of the amp. He doesn't need versatility, he doesn't need presets, and he doesn't need tap tempo. He needs a good analog or tape slapback sound.
    I agree with the folks who say the DD-7 should be able to do it, but the DD-7 is different from previous Boss delay pedals. The DD-7 is all-digital, meaning there's no analog dry signal path. The whole guitar signal gets A/D converted to digital, then D/A'd back to analog at the end. I'd like to think Boss can do all that processing and have the pedal sound natural, but through a wound-up clean(ish) amp, maybe that's what the OP is hearing a "color".
    I don't play rockabilly, but back in the old days, I used some slapback delay for songs like The Pretenders' "My City Was Gone", and "Middle Of The Road". When I switched from a DM-2 to a DD-2 sometime in the early '80s, I distinctly remember thinking the DD-2 didn't do the slap as well. The delay stuck out too much, because of the clean digital sound. I simply backed off on the mix knob a bit, and for my purposes it was "good enough", but if I was really a stickler for the slapback, the DM-2 would have been better.
    Now of course, YMMV. Some people like the DD-3's clean repeats, even for slapback. The DD-3 does have an analog dry path, so the A/D and D/A conversions are not messing with your dry guitar signal, just the repeats. Used DD-3s are cheap and plentiful, so it's worth checking on out to see if is solves the coloration problem. I personally believe anytime anybody needs a delay and doesn't know where to start, a used DD-3 is the place to start.
    If the DD-3's repeats are a bit too clean, try analog. The DM-3W Waza pedal is worth checking out, though pricey. There's the Carbon Copy and if it's too dark, the "Bright" version. For real authenticity, look at some dedicated tape-emulation pedals, but be wary of the analog-dry-path problem. A lot of the super-booteek, super-verastile delays out there are going to digitize your whole guitar. The EHX Canyon comes to mind. It has both analog and tape emulations on it, and from all reports it sounds great, but it is a "no analog dry path" pedal. (I recently bought one, but haven't had a chance to fire it up yet.)
    There are cheaper delays out there. Of the recent flood of cheap mini-pedals, I only have experience with Mooer, and Ana Echo and a Yellow Comp. Both pedals sounded great, but their tiny controls were a bit finicky. Their build quality is good, but not "Boss good". If your rockabilly band is going to be gigging regularly, and especially if your delay is going to be used alone (no pedalboard) then I would spend a bit more for a quality pedal like MXR, Boss, or boutique. (Gasp! I'm no fan of the booteek pedal market in general, but I will admit that, say... Earthquaker Devices' build quality is way better than Mooer or Caline.)
    You're lucky in that the effects needs for rockabilly are pretty simple, and you don't need a whole lot of pedals or options. Start with the basics: DD-3, Carbon Copy, DM-2W. If none of them floats your boat, at least you'll have a good idea of why not, and which direction to head.
  5. bacongrease
    bacongrease Tele-Meister
    429
    Mar 27, 2013
    The SubDecay makes DD-7 sound like horse poo.
  6. Fiesta Red
    Fiesta Red Friend of Leo's
    Nov 15, 2010
    MXR Carbon Copy Analog Delay.
    Works great.
    If you want a larger pedal (lol),the Rocktron Short-Timer works very well for this purpose as well.
  7. chris m.
    I knew it was "rockabilly" but there are variants out there that are pretty heavy with a fair bit of gain. I didn't assume he was going just for traditional clean country sound.
  8. Sounds Good
    517
    Oct 2, 2017
    Luton UK
    Thanks Alot! sammy123 yes i have the reverb one as well, but tend to use the reverb on my amp, i also have a H & K replex delay which is nice, but i got it very cheap and now the little tube needs replacing but it lasted a long time.
    It would be good to have a favourite pedal thread, but i suppose that would be like a favourite players thread with what suits ones ears and tastes best.
    Still i search on utube alot but of course the sound is never quite the same as the pedal setup within your own rigs and using your own playing styles.
  9. jguitarman
    jguitarman Tele-Afflicted
    Oct 14, 2003
    No CA
    My guitar, (for now) is an American Tele and my amp is a Deluxe Reverb. I play clean and at less than breakup volume. Thanks for everyone's input. The first thing I'll try is the digital setting on the Boss DD7 and if that doesn't work I'll start researching your suggestions. I don't see myself using tap tempo or the effects that some pedals offer in addition to delay so why spend the money.
  10. chris m.
    If you want tap tempo in the future, you can add an external tap tempo button to your DD7 very cheaply.
  11. BWNadeau
    BWNadeau Tele-Afflicted
    Feb 2, 2011
    Lachute, Canada
    Rockabilly - Mad Professor Deep Blue delay. Sounds great in front of the amp, handles drive like a champ, and is half the footprint and price of an AD999, which does the same thing (maybe a little better) in a big, pink, pricey box. ;-)
  12. thefruitfarmer
    thefruitfarmer Tele-Meister
    155
    Sep 26, 2013
    kent UK
    Way Huge Aqua Puss does a good bright sounding analogue slapback, which works for me.
    Pretty much any echo box will work as a slapback machine but it's a personal thing as to the exact choice. I put several together in the shop and ended up with the AP, but YMMV.
  13. DaveKS
    DaveKS Friend of Leo's
    Oct 21, 2013
    KS
    You do know slapback is 1-1.5 repeats at most, that's not 1:00, more like 9-9:30 at most.
    Put it in modulated mode... why? That pitch waver is what old worn out tape machines do.
    1. Level about 10-12:00? Why? your slapback should never, ever be louder than your original dry notes.
    I'm gonna be blunt, and I'm not trying to be rude or a d**k, but with those settings you listed, you really have no idea what slapback is. It's a delay that pops back at you once, maybe with a faint 2nd echo that you almost cant tell it's actually there, only in less busy passages can you even, just barely make out that 2nd repeat, that 2nd repeat if you can even make it out is more like a reverb than a repeat.
    waparker4 and MilwMark like this.
  14. MilwMark
    Apr 29, 2013
    near Arnold's
    I'll join the chorus of people noting that you already the delay pedal you need. (I don't agree with any suggestion that slapback "requires" analog, IME digital does it - and everything else - better.)
    But I'm surprised it took so long for someone to note @Rich_S's point.
    In analog (or modulate) mode, the delay range is 200ms-800ms. 200ms is already getting a bit long for slapback. But at noon on the delay dial you are already at roughly 1/2 second. An eternity.
    Similarly, feedback on 1 o'clock has to be at least 6-8 repeats and probably more.
    So turn the Level to 11 am, the Feedback all the way down and if you insist on using analog mode, turn the Delay knob all the way down and see if that is too short. If so, nudge it up very slightly until the delay is long enough. You can conveniently use the word "slap back" to time it. Initial strum "slap" and repeat "back".
    You'd be better off though starting with the Level and Feedback as I suggested (as a starting point) and then using 200ms mode. That gives you 50-200ms of delay and allows you greater range to tweak the delay time to your liking. I've never heard a slabback longer than 200ms.
    Good luck. Please don't go chasing down the pedal rabbit hole if you can help it. You already have all the pedal you need (and one of the best delays ever made, IMO.)
  15. cyclopean
    cyclopean Friend of Leo's
    Aug 14, 2009
    innsmouth, MA
    wouldn't the tone matter way less if it's a slapback?
  16. King Creole
    King Creole Friend of Leo's Silver Supporter
    Jan 24, 2011
    Colorado
    I've always felt that any delay pedal can do slapback fine, but I don't have golden ears, either. For a rockabilly band where you only need slapback, I would avoid modulated delays. They never sound like actual tape delay. To me, they always sound like a chorus pedal, which is probably not a sound you want unless you lean more to the Police and the Cure than to Cliff Gallup and Eddie Cochran.
    If I were building a strictly-rockabilly rig, I'd probably go with an Aqua Puss or Boss DM2w for a delay sound that is slightly darker than the main signal to keep things sounding snappy. Boss DD3 is also good if you want a brighter repeat. Electro-Harmonix #1 Echo is fine, too.
    For what it's worth, I use an Analogman delay (which sounds kind of like a slightly brighter Boss DM2) and a Boss DD3.
  17. MilwMark
    Apr 29, 2013
    near Arnold's
    I can't seem to find the image now, but Scotty Moore (who knows a thing or two about rockabilly slapback) actually used a Boss digital delay and a Boss chorus for much of his career. Food for thought.
  18. King Creole
    Jan 24, 2011
    Colorado
    Food for thought, indeed. Was it this picture?
  19. MilwMark
    Apr 29, 2013
    near Arnold's
    Yeah, Daddy-O!
    Is that also digital chorus? I think so.
  20. King Creole
    Jan 24, 2011
    Colorado
    "Digital chorus" is not what I think of when I want to recreate "Mystery Train." But what do I know?
