Help getting a new amp for HB and single coils
Discussion in 'Amp Central Station' started by tce63, Apr 15, 2018.
  1. tce63
    tce63 Tele-Holic Ad Free Member
    Sweden
    Just got my first Gibson Lea Paul
    The problem that has arisen now is that I probably need to buy a new amplifier to.
    Has today only a Fender Blues Junior tweed that does not make the guitar fair. (or i can´t dial it in)
    Also has a POD HD500x that sounds perfectly OK, but i have no active speakers at home, just use Headphones.
    I will keep the Blues Jr for my Telecasters / Esquires, then it sounds good and i love that sound.
    The best of course would be an amplifier that can handle both single coils and HB for home training.
    Grateful for suggestions?
  2. Rialto1564
    Rialto1564 Tele-Meister
    Metro Detroit
    Perhaps you could say more about the style of music and type of sounds you like?
  3. Trev14
    Trev14 TDPRI Member
    California
    As said above, it depends on they style of music you're going for. A Marshall is going to pair with a Les Paul any day of the week, but it depends if thats what you're looking for sound wise.
    troy2003 likes this.
  4. 3-Chord-Genius
    Winchester, VA
  5. MilwMark
    near Arnold's
    Turn down the mids and maybe the bass on your blues junior. Turn the master up and the level down.
    Jakedog likes this.
  6. tce63
    Sweden
    I haven´t seen that before, Thanks will look in to that.
    3-Chord-Genius likes this.
  7. tce63
    Sweden
    Thanks, will try that tonigt.
  8. tce63
    Sweden
    I play a lot of covers, and the Gibson will ( i think ) mainly be used to play like AC/DC / ZZ-top kind of sound.
    The Telecaster take care of the rest.
  9. 3-Chord-Genius
    Winchester, VA
    It's brand new. And the cool thing is that they look like guitar amps.
  10. tce63
    Sweden
    I have read about it now, and it could be interesting, but expensive .
  11. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Clean set up on your amp through a Plexi-Drive pedal would be good.
  12. chris m.
    Santa Barbara, California
    A Les Paul has a very different voice than a Telecaster. Even after you adjust the EQ and gain/volume levels
    on your amp, the two guitars will sound very different. That's the whole point of owning two different guitars!
    If you play the LP all the time, then the Tele will sound really trebly and weak. If you play the Tele all the time,
    then the LP will sound too bassy and loud.
    This is a real issue-- subjective perception. I have been playing humbucker guitars mostly,lately, because the
    other guitar player in my band uses a Stratocaster. Because I have been playing HBs all the time all of my
    single coil guitars sound really thin to my ears these days. Before, when I was always playing single coil
    guitars, my HB guitars sounded too muddy to my ears.
    I agree that you should be able to adjust the Blues Jr. settings to get a good sound with your LP-- but don't
    expect it to sound anything like your Tele.
    In general I would suggest that an amp that has a full tone stack-- bass, mids, and treble, maybe even
    presence (high treble)-- will be easier to optimize for both your LP and Tele. That said, I can make my
    Fender MusicMaster Bass amp with just a volume and tone knob work great for a LP or a Tele, but
    I don't expect them to sound the same at all-- I just want them to sound like they're supposed to sound.
  13. CK Dexter Haven
    GCDB
    You should be able to get a decent LP sound out of that rig; as Chris mentioned they will not sound the same, nor should they. Before you do anything try turning the guitar volume down a bit, that may thin the sound out a bit and take way some of the thump you may be experiencing.
    Try this also.. Make sure the FAT switch is off..
    Can you run the Line 6 into the Fender? Im not familiar with that Mult FX, but most of the ones I have used have some ability to run a line out, in this case you want to turn off any cab simulation/ modeling and start W/the Fender as clean and flat as possible (you are basically using it as a small PA) try some different thing paying special attention to your EQ settings, or simply just use it to shape your Eq..
    You have a lot of possibilities.. many more than an original LP owner had in the 50's,( a mid control was rare then..master volume non existent), a new amp w/ a new guitar is fun, but rarely a necessity.
    MilwMark likes this.
  14. tce63
    Sweden
    Thanks for your inputs, i have tonight run the POD infront of the Blues Jr just as a pedalboard (dist and EQ), and it worked out really nice.
    Tomorrow i will pickup my LD Maui 11 and try that with the POD, i think it going workout just fine.
