Harvard 5F10 Build
Discussion in 'Shock Brother's DIY Amps' started by mjcyates, Nov 14, 2018.
  1. Mr Ridesglide
    Mr Ridesglide Tele-Afflicted Gold Supporter
    Bloomington, MN
    I may have misunderstood, but if you put them on the tube sockets you are also elevating the heater reference to ground. Maybe read a bit of this for more and better information than I could give.
    http://www.valvewizard.co.uk/heater.html
  2. mjcyates
    mjcyates Tele-Meister
    louisville ky
    Well I don't have any 100 ohm 1/2 watt resistors on hand but according to Merlin's article using 220 ohm 1/4 resistors is also acceptable. I do have some of those on hand from my pedal building stock. I wired them up to the pilot light and grounded to tab on chassis and that took care of the problem! You guys are awesome! Just for my education what is the purpose of the Red/Yellow center tap from the transformer?
  3. trippercaster
    trippercaster Tele-Meister
    Roanoke, VA
    Red and yellow is probably the center tap for the high voltage secondaries. Glad that solved it though. You can always say thank you by letting us hear it...
    Sent from my SM-G960U using Tapatalk
  4. mjcyates
    louisville ky
    I don't really have a good set up for recording but I will see what I can do:)
  5. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    With some chopsticking and pushing some wires around, I got mine as silent as any I've built. Knob on 12 you literally couldn't tell it was on without looking at the light. I think the bare bones circuit leaves a lot of room to place things without being too close to other components.
    Sent from my XT1585 using Tapatalk
    robrob likes this.
  6. mjcyates
    louisville ky
    Mine is pretty quiet now. When turned to level that I will be playing at it is almost silent. This thing gets pretty loud! I was at first not so sure about the need for 3 different inputs but they definitely make a difference. Here is a picture in a roughed out head cabinet. I need to round corners, sand and stain.
    FRANKENJAG, robrob, rjtwangs and 2 others like this.
  7. jsnwhite619
    Georgia
    Good job! Yeah, they can be a lot louder than people expect for a "little Harvard". Starting raising that NFB value and it gets a lot louder too. I know what an efficient 1x12 can do with it, I can only imagine that head with a 4x10 or 4x12 cab. When I took my Vibrolux to the local music shop back when I had it biased around 370v and 70%, the guys there guessed it was a 25-30 watt amp.
    rjtwangs likes this.
  8. cottontails1959
    cottontails1959 TDPRI Member
    Pittsburgh, PA
    Wow, nice build. Any chance you would post your final schematic? I was thinking of doing one of these for a first build. I like the two-power tube, low-watt with simple controls.
  9. mjcyates
    louisville ky
    Thanks! Mostly used the stock Fender schematic. Attached is a layout file that shows how it is currently built.
  10. mjcyates
    louisville ky
    PT is Hammond P-T290BX, OT is Hammond 1750E
  11. rjtwangs
    rjtwangs Tele-Afflicted Silver Supporter
    Reston, Virginia
    Every time I turn mine on and crank it, my neighbor thinks i'm using a big amp, it just makes me laugh. It's a great amp, hope you have a lot of fun with yours!!!
    RJ
  12. mjcyates
    louisville ky
    Nice amp! Yes it can get quite loud!
  13. Lynxtrap
    Lynxtrap Tele-Holic
    EU
    No grid leak on the the first tube?
  14. mjcyates
    louisville ky
    So I've gone back and forth on this topic. The original Harvard schematic does not have a grid leak resistor as far as I can tell. Is that because it doesn't need one? I just watched the Uncle Doug video on this topic and it seems like a good idea to have one. What would be the benefits of having one or the drawbacks of not?
  15. mjcyates
    louisville ky
    I decided to have a cabinet built for this amp. John Mergili is building and it should be here next week. I will post final pics when I get it all together.
    rjtwangs and D'tar like this.
  16. mjcyates
    louisville ky
    This showed up today!
  17. Mr Ridesglide
    Bloomington, MN
    Awesome. Mergili does nice work.
    robrob and rjtwangs like this.
  18. rjtwangs
    Reston, Virginia
    Really beautiful!! I'm going to plug a tele into mine and turn it up!!! Can't wait to see it completed!! Hurry!!!!!
    RJ
    Mr Ridesglide likes this.
  19. mjcyates
    louisville ky
    Chassis installed.
    Just need to install faceplate and speaker cable and she will be complete!
  20. mjcyates
    louisville ky
    Final shot. The faceplate was supposed to say Custom Harvard but I guess it is just as much a Custom Deluxe as it is a Custom Harvard. Deluxe cab, Deluxe transformers, Deluxe size chassis, Harvard circuit, 10" speaker.
