Hardest easy/wipe on finish for pine?
Discussion in 'Tele Home Depot' started by JRevel, Jun 28, 2013.
  1. JRevel
    JRevel Tele-Meister
    468
    May 6, 2010
    Minneapolis, MN
    This is for my Bill Bo. The pine dents when admired too strongly. What's a thin and easy to apply finish that gets somewhat hard? Shellac?
  2. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Aug 4, 2010
    Athens, GA
    Tru Oil. The wipe-on finish of champions.
    Minwax makes a wipe-on poly that a lot of people like. I've never used it so I can't comment on it other than to say it exists.
  3. teleforumnoob
    teleforumnoob Tele-Afflicted
    May 25, 2010
    North Alabama
    Flake shellac. Mix it thin and do a buncha coats.
    But if you dont mind neutral color, and don't wanna be bothered with mixing flake, just get a can of this
    Its, dewaxed, and thin enough to brush or wipe right on, straight outta the can.
    This body is 10-12 thin coats of it, then a couple more thin coats of it mixed with a little garnett flake I had. Thats it. Simple as pie.
  4. teleforumnoob
    May 25, 2010
    North Alabama
    I've used the wipe on minwax poly(satin) on necks. It works fine. Heck of a lot easier than spraying nitro.
  5. JRevel
    JRevel Tele-Meister
    468
    May 6, 2010
    Minneapolis, MN
    very nice. How hard is the finish? Did it take all 10 coats to be appreciably hard?
  6. teleforumnoob
    May 25, 2010
    North Alabama
    Seems pretty hard to me, but its pawlonia, even softer than pine. I could dent it with a fingernail if I tried, but so far it hasnt gotten any noticable dents. Its been on a stand in my music room for almost a yr now. Hasnt been out of the house more than a couple of times in a gig bag tho. And yea, it took a lot of coats to build up any kind of thinkness/hardness. I didnt even bother to grain fill it so its still wood grainy to the touch. I would apply a coat, let it dry good 30 min-hr between. THe more coats the longer the drying time it seemed. Eventually your coats stop soaking in as well and you get some tiny beads in places when it dries. I'd knock those off very lightly w some 600 grit and put on another coat. I just kept going till it seemed like I had enough. The last 2 coats w the flake mixed in just darkened it a little. I disolved the flake in datnatured alc then mixed the 2 solutions, to keep a thin consistancy. When shellac gets thick its really hard to get even.
    One thing about it tho is if dosnt turn out hard enough to suit you could always go over the top of it with just about anything, its compatible.
  7. Bentley
    Bentley Friend of Leo's
    Jul 25, 2012
    Kelowna B.C, Canada
    I know this might sound stupid, but maybe a couple coats of lacquer. Brush on a couple coats, and it might work great. I know that when I lacquered a table I made, with two coats, it didn't build up to much, but it feels a lot harder, and is shinier. Keep in mind it was a mahogany table.. Might be worth a test.
  8. teleforumnoob
    May 25, 2010
    North Alabama
    I dunno about brushing on laq, but this stuff works great and can go right over shellac.
    Takes a while to cure tho. Spray outside and wear a respirator.
    Available at Wallyworld at about $5 can. Prob take 5-6 cans.
  9. xardoz
    xardoz Tele-Meister
    292
    Apr 21, 2010
    St. Louis, Misery
    Looks great - what did you wipe it on with? Any tips or suggestions?
  10. magicguitar
    magicguitar Tele-Afflicted
    Aug 23, 2006
    Fallon, Nevada
    +1
  11. teleforumnoob
    May 25, 2010
    North Alabama
    xardoz,
    clean old white t shirt. Went thru 2 or 3 of em, cause after the shellac sets up and gets hard you gotta get another rag. I just tore off some strips and rolled em up, dipped and spread it on, working fast. You gotta get it on and leave it alone, the more you rub it around the worse it gets. Dip, swipe, get the drips, and move on. You can't fuss over it.
  12. nosmo
    nosmo Friend of Leo's
    Jan 31, 2012
    Lake Jackson, TX
    I'd say the hardest to apply would be some type of bubble gum based finish. The easiest I have used is Tru-Oil :lol:
  13. teleforumnoob
    May 25, 2010
    North Alabama
    I may try tru oil on the neck of my current project. I've avoided it so far because shellac is so easy, or for necks, wipe on poly is even easier. People seem to indicate it takes a whole lot more coats and a lotta rubbing and stained fingers. I may get some medical gloves and give it a go tho. Guess a trip to the gun shop is in order.
  14. kwerk
    kwerk Poster Extraordinaire
    Feb 22, 2010
    New Zealand
    I suggest you do the neck in Tru-Oil first and then tackle the body afterwards. I think you'll find the TO doesn't stain fingers at all, at least not in my experience. You can get a great finish in just a few coats, Though for a body I'm inclined to just keep using the bottle until it gets too thick or runs out completely. I think once you've done the neck, you'll be convinced.
    This is a TO body and neck:
  15. teleforumnoob
    May 25, 2010
    North Alabama
    ^My current project is gonna get paint on the body, some goof ups I plan to hide on this one. The neck has a rosewood board tho, so I guess I'll give tru oil a go on the headstock and back of it. Heard so many good things about it I gotta try it sooner or later.
    Thats a right pretty guitar.
  16. Mojotron
    Mojotron Poster Extraordinaire
    Dec 21, 2008
    Seattle
    Pine will flex quite a bit, so trying to go hard is going to be problematic as hard usually means rigid too - what happens then (as with Lacquer) is that the finish will chip off a little at a time: Which is a great worn look - did that on a Western Red Cedar Tele a few years ago and it looks pretty neat after a few years - seems to have aged 10 times faster than lacquer on Ash.
    What you may want to do is go with something that is pretty durable and easily repaired. Any Poly would win the durability contest if there were enough coats, but Poly does not repair well. The top coats will melt lower coats with Shellac and Lacquer so those are pretty durable and reparable - I like Shellac and just spray it on just like Lacquer for pine.
    The main issue is that you can't really make the wood harder, so it's going to either need finish repair from time to time or do like everyone else and go with the warn-in look. The main purpose of a finish on a softwood is to try to seal it as much as possible. The finish will protect a little, but not a lot since the wood between the grain is pretty soft with Pine.
    So TO, Shellac, Lacquer is gong to get you a pretty serviceable finish.
  17. JRevel
    JRevel Tele-Meister
    468
    May 6, 2010
    Minneapolis, MN
    I ended up going with Minwax wipe on poly over several coats of Maloof's finish.
    I'm on the third coat today and I think this is a great way to go so far. Goes on easy, dries relatively quick (ACTUALLY dry and able to sand in 4 hours), and even with one coat I could tell there was a "shell" of finish on the body.
    Pics to follow.
  18. teleforumnoob
    May 25, 2010
    North Alabama
    That will certainly work and look just fine. Simple easy. I've used it a lot on maple necks, and furniture. The only prob is its not very repairable, as has been said. But hey, if you arn't beating it to heck thats not gonna be issue anyway.
  19. JRevel
    JRevel Tele-Meister
    468
    May 6, 2010
    Minneapolis, MN
    Oh no, I'm going to beat the hell out of it. It'll get played out a lot. But that's how that goes. :twisted:
  20. metecem
    metecem Friend of Leo's
    Hy kwerk, is that a red palm neck????
