Guitar wiring ?
Discussion in 'Tele Home Depot' started by SacDAve, May 23, 2019.
  1. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    Screen Shot 2019-03-31 at 7.00.54 AM.png Screen Shot 2019-05-23 at 6.28.34 PM.png Screen Shot 2019-05-23 at 6.28.58 PM.png I’m wiring a guitar I just finished. Pick of how I want to wire the guitar (pic) Not familiar with a push/pull switch. Looking at the diagram of the switch would that be the same as looking at the switch (pic of switch) ?
  2. TimTam
    TimTam Tele-Holic
    Melbourne
    Yeah that's correct. CTS DPDT push-pull's new style terminal layout and soldering is a PITA. How the solder terminal labels map to more conventional DPDT style is seen at the terminals at the other end of the switch and in the top image here. The bottom diagram shows what is connected to what in the push and pull positions ...
    https://www.stewmac.com/How-To/Onli...Wiring/Wiring_the_CTS_DPDT_Push-Pull_Pot.html
  3. SacDAve
    Rocklin Ca.
    Would this be the correct wiring for the switch in the diagram
  4. SacDAve
    Rocklin Ca.
    Working off this diagram the one Tim Tam shared a link too I got it kind of partially working. I ordered a Bourn’s switch should have it today
  5. TRexF16
    Tucson
    No, I think this is the key for you. Here's the old CTS switch:
    Here's the "conversion key" for wiring your mod. I think your CTS switch you have is fine and there was noneed to order the bourns. Try this and then you can still use the Bourns for another project if it does not work.
    Good luck.
    Rex
  6. SacDAve
    Rocklin Ca.
  7. TRexF16
    Tucson
    I hope it works for you. I'm no expert but I just used these new CTS push pull for the first time, and I had to do all the tracing like you.
  8. TRexF16
    Tucson
    BTW, what brand of Humbuckers are you wiring? Are you 100% sure you have your color codes on the 4 wires right? I bet you do just thought it was worth asking.
    SacDAve likes this.
  9. SacDAve
    Rocklin Ca.
    Tone rider PAF I'll put up a post up tomorrow of how I did the color coding also I've never installed a push/pull pot switch.
  10. TRexF16
    Tucson
    Well heck, here's Tonrider's own diagram of the the same set-up (attached as PDF). Only difference is it's a toggle not a blade. But the rest of it should be informative. Notice they are only using one bank of the poles on the push-pull switch. You could do it either way.
    I'm sure you have this:
    http://www.tonerider.com/wiring-diagrams
    Here's their color codes
    SacDAve likes this.
  11. SacDAve
    Rocklin Ca.
  12. SacDAve
    Rocklin Ca.
    I like the Tonerider Diagram better than mine pretty simple I'm going to use that. Thanks Screen Shot 2019-05-26 at 8.59.48 AM.png
  13. SacDAve
    Rocklin Ca.
    I got everything working on the mechanical end everything functions properly. But I’m getting a high buzzing in every position, then if I roll the volume back I get a low hum. The pickup cavity is shielded no cover plate on it. I’m guessing it’s a grounding problem any suggestions?
  14. SacDAve
    Rocklin Ca.
    All is good I kept looking the diagram everything looked good I knew it was something simple with the meter all the grounds were tied together. I pulled the Jack the hot was to the ground thats the one spot that I didn't check with the meter. The pickups are Tonerider's Alnico IV classic Vintaged-voiced Humbuckers AC4. About 20 minuets plugged in these pickups sound great really liking them. Still have to do a set up on the guitar. The other problem I had I used the bourns Switch/pot they have knurled shafts I pulled the knob to add a washer the shaft pulled right out of the pot I bought 3, I'm afraid to put a knob back on might buy some knobs with set screws and adaptors. Still have the CTS pot could use that. Anyway thanks for all the help.
  15. TRexF16
    Tucson
    I'd use the CTS. Is it solid shaft or knurled? That's one thing I like about those CTS push-pulls - they are available in solid shaft.
    SacDAve likes this.
  16. SacDAve
    Rocklin Ca.
    Such a small job yet a big mess
