Ground problem
Discussion in 'Tele Home Depot' started by Zeellee, Jan 15, 2019.
  1. Zeellee
    Zeellee TDPRI Member
    Italy
    Hello, i have a telecaster with a 4 way switch (4th position is the series) that gives me a electric noise in certain positions; those are the symptoms:
    - bridge position: the hiss is present when NOT touching the strings or metal parts. touching the neck pickup makes it louder
    -parallel and bridge positions: the noise is present ONLY when touching the neck pickup
    -series position: exact same as the bridge position
    What could be the cause?
  2. Gmountain
    Gmountain Tele-Holic Silver Supporter
    I saw the the thread title and thought that it's a good thing this isn't a skydiving forum.
  3. Zeellee
    Italy
    Hahahahahah
  4. Ronkirn
    Jacksonville, FL
    the 4 way requires you to remove the jumper on the Neck pup that connects the chrome cover with the black lead.... connect a third wire, usually yellow, directly to the cover.... that connects to a ground point.. like a pot case..
    rk
