Grill Cloth tutorial
Discussion in 'Shock Brother's DIY Amps' started by jsnwhite619, Feb 9, 2017.
  1. jsnwhite619
    jsnwhite619 Tele-Afflicted Ad Free Member
    Sep 10, 2013
    Georgia
    Just wanted to pass this on because I know the question comes up from time to time, and I've done a few myself, but this was definitely a better method. A little slower, but tighter & straighter than my usual way.
    Here is the link @ https://www.forum-speakerbuildersupply.com/post/grill-cloth-installation-2403012 I've bought grill cloth from them in the past, and they have a sales page with discounted end cuts that is definitely worth checking out. But, it's the old vintage tweed method of stapling on the sides of the baffle instead of wrapping around to the back. It definitely saves the frustration of sinking a staple in the exact spot that a baffle screw needs to run, and it has a nice clean look to it in the end. Just run a box cutter down the edge of the baffle to trim the excess. Anyway, I think it's an improvement on what I was doing, so I wanted to pass it on.
  2. Sandhill69
    Sandhill69 Tele-Holic
    702
    Jun 18, 2016
    Colorado
    Nice, and great link, thanks!
  3. jsnwhite619
    Sep 10, 2013
    Georgia
    Thanks! And this hasn't even had the hair dryer over it yet!
  4. SacDAve
    SacDAve Poster Extraordinaire Silver Supporter
    Dec 23, 2009
    Rocklin Ca.
    Th thanks I wish I saw that before I did my bandmaster. It came out nice But I did my fair share of pulling staples. I use a soldering iron to cut the grill cloth it melts the ends no fraying. Also on the corners when I had them all folded and stapled, I used a little crazy glue to help hold them, kind of let it wick in the cloth.
  5. jsnwhite619
    Sep 10, 2013
    Georgia
    Whoo! I never thought about covering the grill cloth on those cabinets of yours! I bet that was a bear. I don't know how much time you have in each one of those things, but just as someone who has built a few standard cabs, you have some real skill & patience!
    Sent from my XT1585 using TDPRI mobile app
  6. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    I wouldn't paint the board unless it was already supposed to be painted.
  7. Tidepoolbay
    Tidepoolbay Friend of Leo's
    Jan 27, 2009
    Franklin New Jersey
    Nice! I could have used this a couple of years ago.
    Bitsleftover likes this.
  8. D'tar
    D'tar Tele-Afflicted
    Jan 11, 2013
    WNY
    jsnwhite619 likes this.
  9. TelZilla
    TelZilla Friend of Leo's
    Jan 21, 2007
    Cleveburg, USA
    I'm thinking about a tweed style cabinet for my next build, and yours looks great. Can you fill me in a little on the following:
    1. How do you attach the speaker to the baffle? Are there captive nuts attached to that baffle?
    2. How do you attach the baffle to the cab? Wood screws from the front of the amp? I can never quite tell with Narrow panel style cabs.
    3. What wood stock did you use for your fascia boards (the narrow panel parts of the narrow panel)? 1' x 2"?
    4. What's the hair dryer for?
  10. 5ofeight
    5ofeight Tele-Holic Ad Free Member
    770
    Oct 17, 2016
    Glasgow
  11. jsnwhite619
    Sep 10, 2013
    Georgia
    Thanks! I'll go through each one if I can. My method isn't vintage correct, but it's secure and the wood can never strip out from the screw holes.
    1. I drill a hole through and use t-nuts from the outside. Don't drill too big or the center of it won't dig in right, but I'll start it with a screw and drill on the back side, then remove the screw and hammer it in. You could put a drop of super glue if you were worried about it.
    2. I drill through and use machine screws and keps nuts inside the cab. I don't use wood screws for anything. Everything is machine screws and t-nuts or keps nuts. No wood is ever going to strip out or split that way.
    3. On the finished wood cabs like this, I use the same 3/4" (bought as a 1"x 10") boards that I use for the cabinet. These are glued on the 3 sides and clamped. Probably 1-3/4", but that just where I settled on what I liked proportionally. On a tweed or tolex cab, I use 3/8" birch ply and route it in both the sides and a long channel across the whole top.
    4. The hot air helps tighten up the baffle in the end. I don't have or trust myself with a heat gun, so an old hair dryer gets the job done.;)
  12. jsnwhite619
    Sep 10, 2013
    Georgia
    One more word on the method at the top of this post. You can get a really tight fit, but make sure all the staples are seated down. I scratched the heck out of the inside of a cabinet - luckily it wasn't tearing tolex - because a staple wasn't flat. My advice is to go all the way around with a hammer in the end and tap them all to be sure it's flush.
    Bill Moore likes this.
  13. SacDAve
    Dec 23, 2009
    Rocklin Ca.
  14. SacDAve
    Dec 23, 2009
    Rocklin Ca.
    Acually they are easy they are stabled on the front, I don't wrap cloth around.
  15. String Tree
    String Tree Doctor of Teleocity
    Dec 8, 2010
    Up North
    Beautiful.
  16. jsnwhite619
    Sep 10, 2013
    Georgia
    Thanks. It's taking forever to finish because the current weather pattern in Georgia lately resembles something between Seattle & London. It's for a friend that I'm building a Harvard for. Here are the latest pics I have.
    String Tree and 5ofeight like this.
  17. magic smoke
    magic smoke TDPRI Member Silver Supporter
    90
    May 28, 2017
    Quantum Entanglement
    That cabinet looks great. How did you stain and/or finish the wood?
  18. jsnwhite619
    Sep 10, 2013
    Georgia
    Thanks! That is the result of approx. 16 ounces of boiled linseed oil rubbed in over a few months. I'm trying to get the polyurethane on there now, but we've been having tropical weather here lately and it just won't work.
  19. theprofessor
    theprofessor Friend of Leo's
    Aug 8, 2016
    Chattanooga, TN
    Thanks for this! I did my first grill cloth covering today. I followed the instructions you gave, and they worked perfectly. Mine is straight and super-tight, even without a hair dryer!
  20. theprofessor
    Aug 8, 2016
    Chattanooga, TN
    Forgot pics (had to take inside with a flash, so not the greatest). This is on a 5e3 head I'm just about to finish. Made it out of poplar. Now I've got to figure out what color to stain it that will at least half-way match the Fender tweed cab below.
    Also, I've noticed that the Mojotone Fender-style Oxblood with gold stripe is much nicer-looking than the stuff Fender uses nowadays. The oxblood is richer, and the gold stripe is a little thicker and more prominent, too.
