Got a problem, losing my tone
Discussion in 'Squier Tele Forum' started by DrBGood, Sep 25, 2018.
  1. DrBGood
    DrBGood Tele-Meister
    328
    Jan 30, 2015
    Sutton QC, CANADA
    I think I might be losing some of that precious tone, through the strap button.
  2. LocoTex
    LocoTex Tele-Afflicted
    Jan 16, 2018
    Waxahachie, TX.
    Just try to stay loose so you don't lose any more.
    DrBGood and Danjabellza like this.
  3. Danjabellza
    Danjabellza Tele-Afflicted
    Sep 22, 2014
    Pahrump, nv
  4. memorex
    memorex Friend of Leo's
    Jan 14, 2015
    Chicago
    Seems like that tone would just recycle through the strap into the other strap button.
  5. howardlo
    howardlo Tele-Meister
    401
    Feb 16, 2011
    Hobart, IN
    Your tone is loose???
  6. DrBGood
    328
    Jan 30, 2015
    Sutton QC, CANADA
    Thanks, excuse my loose English.
    Edited that.
    howardlo and LocoTex like this.
  7. DrBGood
    328
    Jan 30, 2015
    Sutton QC, CANADA
    But I never wear a strap !
  8. Jim622
    Jim622 Tele-Afflicted Silver Supporter
    Apr 1, 2011
    Far N.E. Philadelphia
    Have you cleaned your ears lately, so you are maybe hearing differently?
  9. memorex
    Jan 14, 2015
    Chicago
    Well then you're probably losing tone out of both strap buttons.
    src9000, RoyBGood and ChuckC like this.
  10. ChuckC
    ChuckC TDPRI Member Gold Supporter
    54
    Aug 17, 2017
    Maryland
    That's why! Also using the plain G string ... You need one of the fancy ones ....
    EDIT: I looked again .. You've broken a piece out of the little knob thingy that the strap goes on.
  11. Jim622
    Apr 1, 2011
    How do you know what he's wearing?
  12. radiocaster
    radiocaster Friend of Leo's
    Aug 18, 2015
    europe
    Go to the tonedist and have it pulled.
    DrBGood likes this.
  13. ChuckC
    54
    Aug 17, 2017
    Maryland
    Here is another very strange thing that will effect the tone of guitars. It seems most apparent on my Fender type guitars, maybe because of the design of the pickups. I have noticed that only when I take Pepto Bismol and play a gig, my tone is very noticeably brighter. I've since discovered that Pepto Bismol contains a soft metal called bismuth that is anti magnetic. Bismuth repels magnetism.
  14. eallen
    eallen Tele-Afflicted
    That's why you never use someone else's strap. They can end up getting some of your tone!
    ChuckC likes this.
  15. memorex
    Jan 14, 2015
    Chicago
    It also blackens your stool. Just sayin'.
    RyCo1983 and ChuckC like this.
  16. RifleSlinger
    RifleSlinger Tele-Meister
    161
    Mar 12, 2016
    Strap buttons are a common leakage point for tone. This is a point where proper maintenance is critical.
    The most common point of failure is the felt gasket. These should be replaced every 150 playing hours, or every 10 hours if using a boutique tube screamer type pedal, which will create a back pressure spike of the haunting mids.
    Next, make sure the screw is not cross threaded and is precisely torqued- not enough torque will cause leakage, and too much could damage the gasket or even strip the threads, which can cause a massive tone rupture, and even result in injury from the smoking hot tone.
    With a small amount of routine maintenance, all of your tone can reach the amplifier.
    VintageGearMan, Jim622 and ChuckC like this.
  17. DrBGood
    328
    Jan 30, 2015
    Sutton QC, CANADA
    What ... what ? What did you see ? Tone erosion maybe, but there's no chip there.
    I religiously use Q-Tips every morning and I didn't have any knowledge I was losing my tone before I took this picture.
    It's one thing to hear a leak, but to see it ? Have any of you ever seen a tone leak like this ? Or maybe it's Fairy Dust coming out ?
    I think I'll make a visit to my local inorcist. Tried the exorcist before and it just got worst.
    src9000 and ChuckC like this.
  18. pipethemike
    pipethemike TDPRI Member
    21
    Aug 16, 2018
    Kansas
    most likely a leak...just go to the nearest shop and have them top off your tone fluid. this will become regular maintenance from now on.
    DrBGood, Jim622 and ChuckC like this.
  19. Churchjack
    Churchjack TDPRI Member
    90
    Oct 22, 2017
    I'm not real geeky 'bout my gear, I'll stack strap buttons until it's just a wash of feedback and hiss. Love it. Not for everybody.
    But the guys on That Strap Button Show put buffers after.
  20. Fearnot
    Fearnot Friend of Leo's
    Jan 17, 2010
    Decatur, GA
    The question is, are your strap buttons directional? Maybe you have them backwards.
