GFS Gibson-style jack plate...
Discussion in 'Tele Home Depot' started by Boolywho, Feb 14, 2011.
  1. Boolywho
    Boolywho Tele-Meister
    450
    Nov 18, 2010
    Portland, OR
    Has anyone used these Gibson-style jack plates before?
    Do they fit the curve found around the jack hole of a standard tele?
    I ask because I've been hacking away at my jack hole area trying to get an electrosocket to fit flush, and I might just need to cover the whole thing up if I can't make it look good :cry:. This GFS thing seems like if might fit the bill. Thanks for your info!
  2. xbearxau
    xbearxau Tele-Meister
    155
    Jul 17, 2010
    Melbourne, Australia
    Does your body have the flat section where the jack goes or is it an even curve all the way around? Pics might help.
  3. M Black
    M Black Tele-Meister
    118
    Sep 23, 2010
    Melbourne Australia
  4. jkingma
    Admin Post
    Worked for me on this one...
  5. JNow
    JNow TDPRI Member
    64
    Aug 27, 2010
    I installed one on my build...it is curved a little much for the flat spot
    What I did was took two pieces of 1 inch scrap boards, drilled a 7/8 inch hole in one so the recessed part fit into it, sandwiched it all together and squeezed it flat in a vice...worked great, fits flush, looks sharp.
  6. Boolywho
    450
    Nov 18, 2010
    Portland, OR
    Mine is curved all the way around.
  7. Boolywho
    450
    Nov 18, 2010
    Portland, OR
    Do these GFS "football" plates work with the tele curve too?
    Do they cover as much thickness as the square ones mentioned above? I just want to make sure I can cover up my (lack of) handywork. I've reamed out about a 1" opening (from the original 7/8" hole). Do you think the GFS football plate would cover this?
  8. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    I have used the GFS curved football and square jacks.
  9. Boolywho
    450
    Nov 18, 2010
    Portland, OR
    Is the square one wider in the vertical dimension (going along the thickness of the guitar body) than the football? Do you think it would cover up my hole still? It somehow seems smaller than the square one, at least in the pictures GFS has posted.
  10. PlutoLex
    PlutoLex Tele-Meister
    204
    Nov 26, 2009
    Bay Area, California
    I believe that my 'football' plate is from Grizzly, but it is 1" at its widest.
    An Allparts square plate is 1.5"
  11. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    I am almost certain the GFS football jack is wider than the GFS square jack, but the square jack is taller than the football jack.
  12. volowv
    volowv Tele-Meister
    356
    Sep 29, 2010
    maine
    i have an allparts football and a GFS square jack.
    the square is 1 1/8" x 1 7/16"
    the football is 1" x 1 7/8"
    a heads-up to anyone else who might be buying these in quantity, grizzly sells squares on amazon for $3 instead of $5.50 at GFS.
  13. PlutoLex
    204
    Nov 26, 2009
    For both Grizzly and GFS, if they are the only thing you are ordering the shipping will get you. Plus, both are pretty thin metal. The Allparts plates cost me less on eBay due to the shipping and they are nice thick plates, but don't have the recess.
  14. bellis
    bellis TDPRI Member
    67
    Jun 1, 2009
    Williamsport, PA
    It's your standard jack plate. I've used both styles on different guitars and they seem to fit the curves of LP, Tele, and Strat knockoffs. The biggest problem (if it can even be called that) is some slight compression of the clear layer of the finish on the edges of the plate, particularly with the football plate.
    I actually believe the square one is slightly wider than the football. And only order from GFS if you're getting $100+ worth of product, the shipping charges are the only downside to getting anything from them. I usually wait until I need to replenish supplies, and even then I order for friends at the same time to save on shipping.
    I'd also like to add that I've been very happy with the GFS stuff I've purchased, and I've gotten quite a selection over the last year.
  15. Boolywho
    450
    Nov 18, 2010
    Portland, OR
    Yeah, I'm placing a big GFS order. It's a pain trying to remember every little thing that I'm going to need from them but oh well. By the way, how much is their shipping?
