Join TDPRI Today
Friggin Fret Edges
Discussion in 'Tele-Technical' started by tuddy24, Dec 31, 2012.
  1. tuddy24
    tuddy24 Former Member
    233
    Jun 27, 2011
    Lombard, IL
    Hi All,
    I tell ya, I'm comfortable with all non-invasive adjustments to a guitar but those fret edges and filing 'em....that just isn't what I'm comfortable even thinking about. On the other hand, it's really hard to find someone to trust who knows what their doing...I think. My current tech who shall remain nameless is awesome at every other single thing....just not fret edges. I'm not going to get into the details but the frets are always still a little sharp and I have to bring it back or there's damage to the wood in the immediate area around the fret corner. Is this just what comes with the territory? I'm to the point of tracking down a cheap-o used Squier that you can shave with to experiment. I just don't know where to start. I'd be willing to drop 75 -$100 to a person who will do the work perfectly but would also love to learn how it's done and buy the tools to do so. Any ideas? I'm in the Chicago land area. Thanks.
  2. PinewoodRo
    PinewoodRo Tele-Afflicted
    Get a cheap neck from a well-known on-line auction site and practice.
    A long, fine, flat metal file should do the trick or you can buy one set in a piece of wood to maintain the correct angle if you're feeling unsure about it. Then tidy up with a small needle file.
    Rosewood fingerboard might be easier as there's no finish to mess up : )
  3. dsutton24
    dsutton24 Poster Extraordinaire Ad Free Member
    Dec 29, 2010
    Illinois
    Yeah, that's how the trouble starts... erm... I mean, ahhh... great idea!
    You're right, the fretboard damage isn't right. The problem is this is a seemingly simple project, and really it is, but it requires some patience.
    The ends of the frets are easy. Get a 12" mill bastard file. Cut the tang and the end off, and taper the ends slightly and polish the teeth of the edges with a belt sander (or buy the file...). Run it up and down the edge of the fretboard until the barbed wire feel is gone. Use a dab of Tru Oil to touch up the edge if necessary. If the neck of the guitar is still attached to the guitar, it's a good idea to mask the top of the guitar alondside the neck with several layers of masking tape to guard agains those 'whoops' moments.
    The fret ends are a little more work, but only because there are so danged many of them. You're going to go over each end (and both sides) with a fine Pillar or triangular file to round them over slightly. Just go slow, and be patient. I usually mask on either side of the fret with a couple of layers of blue masking tape to avoid slipping and damaging the fretboard edges. Never leave the tape on overnight, though. Even the expensive masking tapes can leave residue that's a pain to remove. Polish things up with some 800 grit wet and dry paper wrapped on a popsicle stick, go finer until you're satisfied or insane, and you're done.
  5. tfsails
    tfsails Friend of Leo's
    Oct 11, 2010
    Richmond VA
    I agree with what dsutton says. One more thing--use your fingers and sense of feel to determine when the edges/ends are smoothed correctly. Like auto bodywork, your hands and fingers are more accurate than your eye. Just be careful you don't rip some skin when you do it.
  6. Peter Rabbit
    Peter Rabbit Tele-Holic
    885
    Sep 17, 2009
    Toronto, Ontario, Canada
  7. H. Mac
    H. Mac Friend of Leo's
    May 26, 2012
    Atlanta, Georgia
    At the risk of mentioning the elephant in the room, it's December, and the OP is in Illinois, so . . . it's hard not to wonder about the average humidity level for the past two weeks or so of the room where the guitar is kept.
  8. KokoTele
    KokoTele <img src="http://www.tdpri.com/gifs/vendor.png" /> Vendor Member
    albany, ny [not chicago]
    It takes patience, a soft touch, and a very fine file.
    The best tool I've found is the little diamond sharpening cards, like these from Woodcraft:
    File a few strokes and check often. The difference between a protruding fret end and going through the finish is just a couple of thousandths of an inch, so toothed files are far too coarse for this kind of work.
    A small piece of sandpaper on a small wood block is a good bet too, but it's hard to keep the surface perfectly flat, which means you're going to wind up sanding things you don't mean to.
    Contrary to popular believe, by the time a neck is fully finished, the edge where the fretboard meets the shoulder is not a perfectly straight line, so a long file is not a good tool for the job. I usually angle my sharpening card so that it only spans a few frets.
  9. dsutton24
    Dec 29, 2010
    Illinois
    ... It's the perfect time to address fret sprout. As a Norweigian friend once put it, if you fix it when they are the stabbiest, then they will be good the rest of the year.
  10. Vizcaster
    Vizcaster Friend of Leo's
    Sep 15, 2007
    Glen Head, NY
    But the point is you should be paying attention to the humidity where your guitars are stored, so you don't get fret sprout.
  11. Jupiter
    Jupiter Doctor of Teleocity Ad Free Member
    Jun 22, 2010
    Osaka, Japan
    These are cool. :eek:
  12. dsutton24
    Dec 29, 2010
    Illinois
    That's a good point as far as it goes, but it's just a guitar. If it has to be kept in a controlled environment just to keep it happy, you might as well be collecting violets or tropical fish or something. Or trying to please a woman. :D
    In my part of the country the humidity swings from nearly zilch to downright tropical. Our friends in the Southwest know dry. The rest of us? Who knows?
    I've got one expensive acoustic that has a case humidifier in it, just because it's an expensive guitar. I've got another that is cranky and old, and it also gets a humidifier. The rest don't seem to mind the humidity and temperature swings. Some guitars just sprout, others don't.
    Regardless of environmental factors, the time to address sprout is when it's happening. It does no harm to dehorn the guitar when it's prickly. If it's one of those that moves with the seasons, I doubt anyone would ever pick it up when it's well hydrated and say, "Gee, I miss those callouses on the sides of my thumb and forefinger!"
  13. benderb9
    benderb9 Tele-Holic
    986
    Mar 3, 2011
    St Petersburg,FL
    sharp edges on frets and nuts/bridges just don't make for comfortable playing. These three tools may be just what your looking for, they make remving the burrs off fret ends a piece-o-cake. The cost of all these tools is about 75.00
  14. H. Mac
    May 26, 2012
    Atlanta, Georgia
    I think that actually, it's the other way around. Guitars never need controlled environments. People do.
    If you're comfortable in the environment, your guitar will also be comfortable. If your skin, hair, etc. are dry, your guitar is dry too, and if you're too cold, too hot or whatever, it's the same for your guitar. That's all there is to it.
    So when you combine cold temps, low humidity, and dry heat (especially forced air gas), your skin and hair dries out a bit, and so does your guitar, and with the guitar, you get fret sprout.
  15. craigs63
    craigs63 Tele-Meister
    434
    Aug 23, 2009
    Naperville, IL
    I recommend Music Solutions in Bolingbrook, I have had them do the frets on several guitars and ukuleles. Mid-winter seems to be the peak time (the wood dries out and the fretwire remains the same size), most of my instruments seem to be made in more humid climates than northern Illinois.
  16. Bongocaster
    Bongocaster Friend of Leo's
    So you could easily make a wooden holder for those diamond thingies or sandpaper that would keep it at 30-35 degrees in relation to the fretboard.
    So you are saying start with a (relatively short) file and end with the sandpaper or diamond sharpeners.
  17. KokoTele
    No, I'm saying only use these cards or a very small sanding block for fret sprout.
    I only use files on a refret and get the ends down to about 5 thousandths away from the surface of the finish, and then finish with the diamond card.
    I also use files on a raw, unfinished neck, but that's a different ball game.
    Frets ends on a finished neck is meticulous work and requires meticulous tools. A toothed file is too coarse for this kind of work.
  18. shutterbiker
    shutterbiker Tele-Meister
    116
    Mar 23, 2010
    I found an old post by Ron Kirn http://www.tdpri.com/forum/2282024-post3.html . I had some minor
    fret sprout (I'm in Texas). I used the sanding block and really smoothed it up. I gave it a quick polish with #7 meguiers and there are no finish issues. I made a diy humidifier for my tele and my epiphone acoustic. Hopefully, this will take care of the issue.
  19. tuddy24
    233
    Jun 27, 2011
    Lombard, IL
    Hi All,
    Thanks for all the comments, I'm a little apprehensive of attempting this myself, I'm just too clumsy. If I see a cheap guitar with sharp frets I'll give 'er a try.
    Regarding the humidity levels, this is the time of year the frets stick out and why I'd like to get this done before the winter ends. The guitar-in-question was just right when I received it a few weeks ago....then the frets just started to poke through although not terrible, just not super smooth. Strangely, my American Tele fret edges are still smooth! Oh well, I love the Classic 50's MIM Fenders, they sound and play great for the money. I'll tolerate the fret issues and get 'em figured out eventually :)
  20. Vizcaster
    Sep 15, 2007
    Glen Head, NY
    I disagree. I'm perfectly comfortable in 35 degree humidity in a heated house in the wintertime, but that's not safe for a guitar.
  21. rebelwoclue
    rebelwoclue Poster Extraordinaire Ad Free Member
    Jan 15, 2012
    kentucky
    Thanks Kokotele- this is what I have been looking for- good thread, OP! (I want to make all my teles feel like my American Standard and American Special- nice fret edges)
    Koko- do you use the extrafine cards?
    Thanks
