Fret leveling yer tele.......101
Discussion in 'Tele-Technical' started by Ronkirn, Feb 27, 2010.
Thread Status:
Not open for further replies.
  1. Ronkirn
    Jacksonville, FL
    I keep getting asked how to level frets, or does a compound radius come into play etc... so let's do it..... I know It's been done before, but there are many welcomed newcomers to Paul's party, and since this is the single best "mod" you can do to improve your tele, or any guitar for that matter. it bears repeating.
    The first thing you need is a leveling tool. There are a multitude of things you can use, but one common feature they MUST have is a precision flat surface to use against the frets.
    A couple of months ago I was discussing the use of a piece of scrap Corian, generally available free from many solid surface fabricators. They throw away dumpster loads of scrap every week... so ask....
    You can buy a tool specifically designed, for fret leveling. but the are nothing more than an aluminum square tube with one edge milled flat and at 50 bux, that's a bit pricey.
    A couple of months ago, a friend that is in the solid surface counter top fabrication business asked what I though of a piece of Granite, or manufactured "stone", I told him to send me a hunk and I'd give it a shot.... this stuff is the bomb....;)
    The weight is correct so that you apply NO down force, ya just scrub away...
    here is a shot of a piece about 2 inches wide X 16 inches long...
    To this I, using 3M 77 spray adhesive, attach a piece of 180 grit sand paper… this is from a roll or industrial stuff, you can buy it off the “bay” for about 10 bux… one roll will do every guitar within a 1 mile radius of your house…
    and that makes one fine fret leveling tool… Oh it is now available on ebay for about well here it is….
    http://cgi.ebay.com/QUARTZ-FRET-LEV...emQQptZGuitar_Accessories?hash=item4a9ef5f00b
    The reality is, if you are going to do it, you may as well do it right…. To do so you will have to buy a few tools… the bar above is 25 bux, and no I’m not associated with it in any way other than I told the guy sure , you can mention that I like it…
    The other tool you are gonna have to buy, because it cannot be made in a home shop is a fret crowning file….
    Ron Kirn
    JK202, Vespa_One, Zaxxon and 5 others like this.
  2. Ronkirn
    Jacksonville, FL
    The Crowning file is made so that when you slip it does minimal damage….. Note the smooth rounded nose and the polished edges that protect the fingerboard…
    this one is pretty good and only 32 bux,
    http://cgi.ebay.com/New-Diamond-fre...emQQptZGuitar_Accessories?hash=item3a580c42b4
    Stew Mac also caries one, at a bit higher price….
    Ok… lets level the boogers……
    First I mark each fret with a marker, that makes it easier to see what the leveling tool is touching…
    Here are the highly specialized tool for doing so,,
    The little fret protector is also available from Stew Mac for about 10 bux for a set of 6 if I recall…. Well worth it…..
    Once the frets are marked…. I loosen the truss rod, and re tighten it until I just begin to feel resistance…. Then I take the leveling tool and place it on the frets and give it a slight shove…. It will remove the marker from the “high” frets… check it, and if the frets are “scrubbed” on both ends… tighten the truss rod… and re scrub…. Repeat ( you should re mark) those frets scrubbed) until the fret leveling tool is “scrubbing pretty consistently up and down the neck… YOU WILL SEE some are not touched at all, whereas others are. What we are doing here is adjusting the truss rod to get the neck as level as possible before we actually begin work.
    If the scrubbing reveals a high spot in the center of the neck, say around the 9th fret… and loosing the truss rod does not “relieve” that high spot.. the neck has a natural back bend in it and unless you have a double acting truss rod, it will take a professional to correct it… DO NOT try to level it.
    This is similar to what you will be looking for…
    Now you are ready to level ‘em…
    Ron Kirn
    Vespa_One, gregulator450 and songtalk like this.
  3. Ronkirn
    Jacksonville, FL
    Now place the tool on the frets and begin sliding it back and forth, gently rolling from side to side to ensure that the entire surface of all the frets have an opportunity to feel the rascal scrubbing the high points down..
    here you see the frets are just about there, but the 15th and 16th and the ends of the 17th thru 21st aren’t quite leveled yet…
    This is not surprising…there is always a ***** or two somewhere. When there is you MUST grind all the other frets down to the level of the lowest fret…
    You will also notice the “shavings” accumulating on the fingerboard, you should see some at each fret…. I use an oval-circular sliding motion moving the tool about 2 – 4 inches back and forth, changing direction, i.e. clockwise, then counter clockwise… continuing until you see each and every fret has been ground to some degree.
    Here you can see the 15th fret is just now being “touched” that is not enough. The 16th is low on the treble side all the way over to beyond the G 3rd position, and the 17th is low on the very edge of the treble side, all must be corrected…
    Here they are almost done…. Only a few more scrubs…. OH at this point ALL the other frets are have been ground, but they must all be ground down to this one last POS… hard headed fink it is…
    Ron kirn
    Vespa_One, Zaxxon, PingGuo and 2 others like this.
  4. musicalmartin
    musicalmartin Poster Extraordinaire
    Norfolk UK
    I straightened the neck on the truss rod completely flat before I started work on my Dot .Was this correct procedure ?.
    GerryB likes this.
  5. LeroyBlues
    LeroyBlues Tele-Holic
    Michigan
    Thanks for the thread Ron.
  6. Ronkirn
    Jacksonville, FL
    I might point out; this neck is one from one of the very high end aftermarket neck/body suppliers. I only mention that to reinforce the point I have made often that each and every neck made has to have this done to achieve optimum playability. And NO…. I’m not gonna identify who made the neck; this is just typical of any manufacturer’s frets.
    Also, if you prefer Stevie Ray’s action of 1/8th inch, none of this is necessary; the angle created by pressing the string down to the fret and as it rises back to the bridge, there is an acute angle severe enough to clear all but the worst fret height anomalies.
    OK so now the little woggies are all level relative to each other… ya get yer fret crowning file…and crown ‘em…
    If you’re crazy like me, or really very good, you can do this without a fingerboard protector…. I use ‘em, but since I’m right handed, and there is no way to hold the tools in my right hand and the camera in my left…. Ya get these screwy photos….
    So you take the crowning file and crown….
    You file each fret until you see the “scratch” marks the leveling tool just left faintly disappear….
    Of course, do each an every fret…. And I may mention, there used to be some lame “fret leveling” tool available on eBay for a few bux that was for the most part a block of some junk and a piece of sand paper… NO… Stop… don’t even think about it…. While yeah… the ad DID say it would crown the frets… remember, the Pres said no one making less than 250K a year would pay any increased taxes either…
    So do this… get ya a fret crowning file… if ya think it’s too darn expensive, well You’re right, but whatcha gonna do…. And you will be doing a lot more guitars over the years so take the plunge … do it right….
    Ron Kirn
  7. Ronkirn
    Jacksonville, FL
    So now, the frets are effectively crowned, and you COULD go play 'er now… but let’s finish the job….
    At this point I take a scrap of at least 320 grit paper and sand each fret until the matte appearance is completely consistent along the top of all the frets…
    Now to do this you must protect the fingerboard, the fingerboard protecting tool is the way I do it, others will mask off each fret with painter’s tape, and either way is fine… no preference, except there is no pealing tape off the board with the protector
    Once this is done the guitar is complete… some may say how ‘bout the polish… well it’s really not necessary, because the “scratches” the sandpaper leaves run lateral to the string, it will only encounter the tops of the ridges the sandpaper leave as you bend the string across them resulting in a very smoothe action, bend the string a time or two and the action will burnish the fret anyway……. But… I polish them anyway…
    If you want to polish too, use the protector or tape, take a Dremel with a polishing wheel and a bit of compound, Cleaner car wax is perfect… and buzz each an every one… then wax the whole board, unless it’s Rosewood or Ebony, string ‘er up and revel in the feel of what you have just done….
    Ron Kirn
  8. nadzab
    nadzab Friend of Leo's
    New England
    Ron, it's awesome that you are so generous with your knowledge...thanks. Where you mention gently rolling the leveling tool from side to side as you slide it, I assume that's to account for the fretboard radius...any special technique here? It seems that there would be a danger of changing the radius of the tops of the frets, such that it doesn't follow the radius of the fretboard. Is it just a matter of experience and "feel"?
    gregulator450 likes this.
  9. Ronkirn
    Jacksonville, FL
    Nah, not to any significant degree, even if you did, few realize how very slight the radius changes from say 7.25 to 9.5
    In this shot, I have placed a 7.25 radius gauge on a 9.5 radius board.. the difference at the apex is less than the thickness of your maxed out Credit cards... ;)
    Ron
  10. Colt W. Knight
    Tucson, AZ
    Great thread Ron.
    How long does this process take you?
  11. Ronkirn
    Jacksonville, FL
    'bout 10 minutes...
    rk
  12. nadzab
    New England
    Thanks for the reply, Ron.
    BTW, my cards won't be maxed until I order that RK custom Strat I've been pining for! :D
    fortj3 and RevBillyG like this.
  13. Heritage
    Heritage Tele-Meister
    Washington, DC
    Thank you very much for taking the time to write and photograph the process in such detail. This will be invaluable in the months ahead and I really appreciate your having taken the time to do this.
  14. birddog01
    birddog01 Tele-Afflicted
    Michigan, in the palm of the mitten
    Wow
    AS one of those "newer" members a big thank you. Being a professional your generosity never ceases to amaze me. These threads you do are great, much better visual and understanding than those email newsletters give me from those places trying to sell you over priced tools.;)
    Wally
  15. Pepi
    Pepi Tele-Afflicted
    Indiana
    Very nice write-up Ron :eek: And please, use all the 3M stuff you can, I've got stock ;)
  16. rainedave
    rainedave Tele-Holic
    NC, USA
    Thank you Ron! I have been thinking about trying this on one of my necks. Thanks to your thread, all of the questions I had and gaps in my understanding have been cleared up. I think I can pull it off now.
    I feel like a selfish person to ask this, but maybe down the road you could do a nut tweaking thread.
    RD
  17. 4string
    4string Friend of Leo's
    Central California
    Hey Ron, its me Marty 'the countertop guy'. I'm just glad to be of help to the guitar builders out there w/ "the stuff". I thought it might be helpful to give the background on quartz poly, I'm getting about 20 question/day '....is it flat? How flat?' '...do you make a radius tool?' etc...........
    I am a stone Fabricator, not a luthier. I've basically just started building, and had never fret leveled until after talking to Ron. In my world, everything is not only flat but is required to be. If you have a polished surface reflecting light, you either get a nice clear accurate reflection, or you get the 'old float-pane glass look' commonly seen on houses built 100 years ago. When you try to seam together two 8' panels of polished granite, the panel faces are either perfectly flat, or you get what's known as 'lippage' where the one panel sticks out more than the other. We get a whole .03075" (1/32) in 8 ft of tolerance! Flat is required...............
    Quartz polymer resin aka Engineered Stone aka Quartz Surface. Invented and patented by Breton s.p.a. Italy(a major heavy-hitter in the high-end CNC machinery industry), manufactured under license by several companies. Silestone, Cambria, "Zodiquack",______________ (the one I'm using; the original and best of the bunch).There's a few more.......to fabricate this stuff or even buy it requires authorization/license (=$$$$) by the individual manufacturer. I am not allowed to advertise in any format as a condition of license. We don't do the ones I named other than zodiquack, and DuP's not so up tight about it. Wholesale on the lot runs $20-30/sf, one sheet is 43 to47 sf depending on manufaturer.
    Quartz poly is 93% quartz, the rest is polymer resin/colorants. Quartz is a by-product of granite processing; those smart Italians figured out something to do with it.:idea: What-a u got, it-sa countertop made-a out of stuff-a that used to-a get thrown a-way. But what they ended up with is something nature couldn't even produce:
    Density: 150 lbs/cubic foot (aluminum is over 200)
    Hardness: 7 on the mohr scale (granite is a little lower, steel is in the 5s)
    Absorption: <.1% (impervious)
    Highly resistive to all chemical groups
    Five times the impact resistance of granite
    100% stable molecular structure (natural stone is considered alive and is a constant state of molecular change albeit very slowly.....):does not warp
    Qurtz poly has flexural resistance approaching that of steel the same dimension, but will not bend as a result and returns to the original orientation (unlike steel)
    The only weakness is heat, but it will withstand a constant 300 degrees. Flame-on @ about 900 degrees.............(polymer resin)
    Flatness:"shop grade". Honed/polished to +/-.0005"/foot The only difference between shop grade materials and a certified granite surface plate is certification. The final step is to rub two surface plates together face-to-face w/ some abrasive compound in there........this is called 'lapping'......which shows any high spots, meaning they need to be re-honed/polished. Surface plate certification can be .0001" (one ten-thousandth)...........so, it,s REAL FLAT..........
    Now, you can run down to your local countertop guy........if he's anything like us he's GLAD to get rid of the small pieces. But if you ask him to cut it to THIS size..........bend over. He's busy and that requires effort. If you have access to a tile saw, do it yerself. Or I'll sell ya one.............
    DO NOT (I repeat) DO NOT try to cut this stuff w/ a dry diamond blade on a 4 1/2" grinder unless you know what you're doing! This stuff binds REAL EASY!(remember heat?) Wet cut only...........or plug in at your local hospital so when that blade shatters they can get some blood in ya before it's too late..........
    Thanks Ron............always the teacher. Great thread..............:D
  18. stephent2
    stephent2 Poster Extraordinaire
    Georgia/Minnesota
    Very nice.
    One step I take before taking a swipe at the frets is making certain the neck is as straight as possible. I made my ruler, but here's one to illustrate from Stew Mac.
    Before leveling it's good to know your doing it on a level plane, slap one of these on and adjust the truss rod to level the fingerboard as much as possible before cutting down frets.
  19. Ronkirn
    Jacksonville, FL
    The Stew Mac tool Stephent is illustrating is a great addition to any shop...But you must be careful, it requires certain skill, the neck has a natural curve due to the radius. If the tool is not set exactly down the center, at the apex, it can make the neck look arched when it's not.... If you use the tool when the guitar is strung, the strings tension is affecting the "bend". This should be done with the tension completely released or better yet... un strung.
    just know what yer dooin...
    Ron
  20. 3 Chord
    3 Chord Friend of Leo's
    Billings MT
    Very nice of you to take the time to pass this knowledge on.
Thread Status:
