fret leveling tool-truss rod adjustment?
Discussion in 'Tele-Technical' started by guitarmoron, Sep 19, 2017.
  1. guitarmoron
    guitarmoron TDPRI Member
    46
    Jun 9, 2014
    arkansas
    ok I'm an idiot, I see all of these vids about using a slotted fret leveling tool to level frets, I get the idea, but how do you use for truss rod adjustment, I see reviews that it is a GREAT tool for truss rod adjustments, I don't understand:(
    thanks
  2. LutherBurger
    LutherBurger Friend of Leo's
    Oct 29, 2013
    NYC
    Notched straightedge?
    To check relief of the fretboard, place it on the board so the frets are in the notches, and use a feeler gauge between frets 8 and 9 to measure the gap batween the board and the straightedge. Then adjust the truss rod as necessary.
    I've never used mine to level frets, though, and I've only used it to measure relief a couple of times. I probably shouldn't have bought it.
  3. guitarmoron
    46
    Jun 9, 2014
    arkansas
    Thanks! I get it now
  4. Ricky D.
    Ricky D. Poster Extraordinaire
    Oct 22, 2006
    Raleigh, North Carolina
    You want the neck as flat as possible before you start grinding those frets. You can get by without the notches.
    The notched straight edge will tell you if the board is flat. If there's a problem there, that's a much bigger project. :)
    asnarski and LutherBurger like this.
  5. LutherBurger
    Oct 29, 2013
    NYC
    THAT'S what I've used it for. I'd forgotten. Thank you for reminding me.
    I need more coffee.
  6. Tommyd55
    Tommyd55 Tele-Meister
    293
    Sep 25, 2013
    Southern Missouri
    I would say you can check the frets with the notched straight edge as well. just move the notches off the frets and have the bottom edge sitting on the frets. The bottom of the notched is suppose to be level so no reason you can't check for fret level with it as well..
  7. Ricky D.
    Oct 22, 2006
    I use a fret rocker for that. A short straight edge to bridge three frets at a time.
