Fixing a small chip in new finish
Discussion in 'Finely Finished' started by Jsil13, Aug 21, 2017.
  1. Jsil13
    Jsil13 Tele-Meister
    401
    Feb 14, 2017
    Boston, MA
    So I made a dumb @$$ rookie mistake while shooting my first clear coats. I got a speck of dust in it, and when I scraped it off it went through all of my color coats into the primer. I tried using a little brush to fill it in knowing it most likely wasn't going to work, and it didn't. So I'm guessing the only way to fix this would be to sand the whole area flat, spray the color again, and then reclear? Since there are already a few coats of clear would I need to mask off the rest of the body to keep the color off of it? I appreciate the help. You guys have been great with my stupid questions.
  2. Silverface
    Mar 2, 2003
    Lawndale CA
    Is it lacquer?
    If so you need to sand everything smooth - but not off. However, yes - you'll need to do a full application of color coats and clear again. Additional material will likely not be an exact match - there are "batch" differences every time a coating is manufactured. And trying to do any partial area will create a difference in depth between it and the already-finished areas.
    Good lesson - never use up ALL your material! Additional lacquer will melt in and touch-ups of the same batch, while not perfect, can be hard to see if done carefully.
    Jsil13 likes this.
  3. Jsil13
    Jsil13 Tele-Meister
    401
    Feb 14, 2017
    Boston, MA
    Thanks again Silverface. It is actually Rustoleum 2x paint and clear. I still have some of the color leftover. Since it isn't lacquer it won't be melting into the layers below it. This is another one of those firebird style bodies, so maybe I could sand down left of the raised center part to level it out while I mask the other 2/3 of the body? That way I can reshoot the color to get more of a match. In theory I guess. Haha.
  4. Silverface
    Mar 2, 2003
    Lawndale CA
    Yeah, with the enamel type finish it's probably worth a try! Enamel simply isn't forgiving and is not abrasion or impact resistant compared to good lacquers or polyurethanes. The impact issue is normally related to adhesion, which is where enamel is really weak.
    The biggest challenge will be blending the edges. It's really artwork in this case, and you'll need to thin the color coat quite a bit.
    Jsil13 likes this.
  5. Jsil13
    Jsil13 Tele-Meister
    401
    Feb 14, 2017
    Boston, MA
    Thank you. I'll give it a shot tomorrow and see how it looks. This is my second finishing job and unlike the first one I had avoided runs and did much better prep work so I was thinking it would go a lot smoother. Haha. I should have known better. If I can fix this though I'll be right back on track. You were actually giving me advice on another thread about my first decal application. I truly appreciate it. Here is the neck that got the decal as well as my first finish job. This surf green one is the same body shape. 20914488_10213930018988461_9098020050864965902_n.jpg
    DonM likes this.
  6. Silverface
    Mar 2, 2003
    Lawndale CA
    ^^^ That one looks tremendous!!!
    Jsil13 likes this.
  7. Jsil13
    Jsil13 Tele-Meister
    401
    Feb 14, 2017
    Boston, MA
    Thanks man. There are definitely some flaws on it, but I'm probably the only one that will ever notice them. I've been thinking about making the other one into a baritone since I already have two teles and then the telebird. I've definitely learned so much from this forum.
  8. user34603
    user34603 Tele-Meister
    396
    Dec 5, 2016
    Richmond VA
    ... I just happened to see this pic. As a guy who grew up in east Tennessee with really talented family members (my cousin was a top level pedal steel pro and brother was ready to try for a classical piano career)... my view is that " is a damm trashy guitar, son " ..as those fellows in Tennessee might say. Very nice.
    Jsil13 likes this.
  9. Jsil13
    Jsil13 Tele-Meister
    401
    Feb 14, 2017
    Boston, MA
    haha. Yeah. This one gets mixed reviews from some people. It's coral pink which apparently some people frown upon, but I spent my whole life going to car shows with my old man and I love all those 50's and 60's pastel colors. I ended up doing the seafoam one in satin. Mainly because I was having issues with the paint. The coral one looks almost like I reliced it now. Next time I do a solid color I'm going to shell out the cash to get some better quality paint and try to let it cure for a much longer time. This guitar doesn't see much action right now since I just picked up a Duesenberg Caribou and that might just be the best guitar I've ever owned, but it's the back up to my main backup.
