First post and first scratch build.
Discussion in 'Tele Home Depot' started by 1bad914, Jan 31, 2017.
  1. 1bad914
    1bad914 Tele-Meister
    183
    Nov 10, 2016
    Michigan
    I have not routed the edge round over yet. I am also going to buy a new and better bridge with string through holes.
  2. richa
    richa Tele-Afflicted Ad Free Member
    Apr 23, 2016
    That's a good look'n build.
  3. 1bad914
    183
    Nov 10, 2016
    Michigan
    The fluorescent light really washes the color out. The mahogany is a really rich color. Slight orange tint. Gone in this light. Look at the previous outdoor pics in this thread.
  4. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    Feb 17, 2009
    London, UK
    Make sure you route the roundover before you drill the jack hole - this is a piece of advise given on this forum regularly: the cutter bearing rides on the body perimeter and will dip into the jack hole if drilled first - a nasty mistake
  5. 1bad914
    183
    Nov 10, 2016
    Michigan
    Oh my, good call. I almost drilled it today. Had the bit in my hand. Whew.
    Mat UK likes this.
  6. 1bad914
    183
    Nov 10, 2016
    Michigan
    Thank you!!
    Mat UK likes this.
  7. Mat UK
    Feb 17, 2009
    London, UK
    Ha, no worries - glad you caught it in time. On the list of common mistakes that come up on this forum regularly, that is right up there!
  8. 1bad914
    183
    Nov 10, 2016
    Michigan
    I decided to just hand sand the edge round over. It came out okay.
    This is also after all the finish sanding.
    John Nicholas likes this.
  9. 1bad914
    183
    Nov 10, 2016
    Michigan
    I decided to try wipe on poly for a finish. I sanded on the first two coats to act as a grain dealer. Then will wipe on 10 or do coats sanding between each. Then I will wet sand, rub and polish. This is after 1 sanded on cost.
  10. 1bad914
    183
    Nov 10, 2016
    Michigan
    This is after the 2nd sanded coat and one wipe on. A few more to go. My end goal is a high gloss finish.
  11. 1bad914
    183
    Nov 10, 2016
    Michigan
  12. 1bad914
    183
    Nov 10, 2016
    Michigan
    Wow, I need to proofread more. Sorry.
  13. richa
    Apr 23, 2016
    That's very nice. Like it.
  14. coonhollow greg
    coonhollow greg Tele-Meister Platinum Supporter
    138
    Jul 19, 2014
    roseburg,oregon
  15. AlabamaOutlaw
    AlabamaOutlaw Tele-Meister
    482
    Feb 20, 2011
    Alabama
  16. John Nicholas
    John Nicholas Tele-Afflicted
    Jun 26, 2014
    Poughkeepsie, NY
    I really like the way this is coming along.
    My only suggestion is to drill for the string through holes before completing the finish.
    Looking forward to seeing this completed!
  17. 1bad914
    183
    Nov 10, 2016
    Michigan
    I debated on the the string through holes, but I do not have a drill press. Doing that free hand is not a pleasant thought. I have a non-string through bridge I can use. I still may attempt it anyways since I like the look better.
  18. 1bad914
    183
    Nov 10, 2016
    Michigan
    Have not posted in a while. I had some issues with getting the grain to flatten out with the wipe on poly. Ended up with about 20 coats on it. Today I wet sanded from 600 through 2000. I was very careful until I hit 1500, I lost my mind for a minute and sanded through. I decided to go ahead and take it to 2000 and machine rub it and polish it. I wanted to see how it shined up. I was impressed. The good news is that it is super flat now. I will let it settle for a week, then hit it with 0000 steel wool and put 8-9 coats on. Then start at 1000 and make it really nice. I learned a few lessons that I already new from painting cars, but suddenly got a case of amnesia. Still happy with this wipe on poly, since I can do it in my basement. You just have to know it will take time.
  19. 1bad914
    183
    Nov 10, 2016
    Michigan
    The light spots are the sand through areas.
    John Nicholas and callasabra like this.
  20. richa
    Apr 23, 2016
    That's gorgeous!
