First post and first scratch build.
Discussion in 'Tele Home Depot' started by 1bad914, Jan 31, 2017.
  1. 1bad914
    1bad914 Tele-Meister
    171
    Nov 10, 2016
    Michigan
    It is about 1/8 except for a couple of areas. It seems to be cutting it fine it is just my twitchy router handling that is causing most issues. I can Sind it down more before I continue.
  2. richa
    richa Tele-Afflicted Ad Free Member
    Apr 23, 2016
    Nice. Free is a great price for wood and covers a multitude of evils. :)
  3. Macrogats
    Macrogats Tele-Holic
    733
    May 15, 2017
    Auckland, New Zealand
    Yeah m I hear ya mate. You should see where I have to work! I also move it outdoors when the weather allows! (Winter time here atm.)
  4. DrASATele
    Jul 6, 2012
    North of Boston
  5. MM73
    MM73 Tele-Afflicted
    Feb 24, 2015
    South Lyon, MI
    Well, if you ever wanted to get really good at sanding stuff, this is a pretty good hobby for learning it.
    If you are into self punishment, it can be pretty good for that also.
    OK, then, looks great!
  6. 1bad914
    171
    Nov 10, 2016
    Michigan
    My other hobby is Porsche restorations. This includes all the paint and body work. The sanding required for guitars is minimal compared to cars.
    reddy2300 and DrASATele like this.
  7. 1bad914
    171
    Nov 10, 2016
    Michigan
    I have not been working on the tele much. We had to concentrate on our daughters wedding. That and the 40k bill is in the past now so I decided to work the router.
  8. 1bad914
    171
    Nov 10, 2016
    Michigan
    I have not had much time to work on the guitar lately. Had to marry the daughter off. Decided to get busy today. Made a couple more passes around to edge and cut all the pockets. Then took the template off and took a couple more cuts with the top bearing bit directly on the guitar. Lesson learned, take the darn paper off the template. Much smoother. I then flipped it over and made one pass with the bottom bearing bit. I am happy. I still need to cut the neck pocket.
  9. 1bad914
    171
    Nov 10, 2016
    Michigan
    I will need to sand a little, but it turned better than I expected.
    Daniel94 likes this.
  10. NotAnotherHobby
    NotAnotherHobby Tele-Afflicted
    Oct 27, 2015
    Da' Magic Mittin'
    beautiful body you got there.
    The guitar, that is...
  11. Robert.II
    Robert.II Tele-Meister
    160
    Feb 25, 2013
    Victoria, BC
    Looks real clean, nice job with the router.
    richa likes this.
  12. Macrogats
    733
    May 15, 2017
    Good stuff. Looking good.
  13. 1bad914
    171
    Nov 10, 2016
    Michigan
    I finally took the time to make a neck pocket template. I used a method that was on the forum.
  14. 1bad914
    171
    Nov 10, 2016
    Michigan
    This picture does not show the ruler for centering the area by the bridge.
  15. 1bad914
    171
    Nov 10, 2016
    Michigan
  16. 1bad914
    171
    Nov 10, 2016
    Michigan
    Very snug fit. The next picture is the end result of using the template.
  17. 1bad914
    171
    Nov 10, 2016
    Michigan
    Of course I have to do some test fit pics.
    mux164, fenderchamp and Mat UK like this.
  18. 1bad914
    171
    Nov 10, 2016
    Michigan
    Nothing is holding the neck up. I am very happy with it. Now I have to bolt the neck on and set the bridge. Then I get busy sanding. Biggest decision I have is whether to cut a belly and arm cut. Going back and forth. The finish will be just clear over the unfinished wood.
  19. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    Feb 17, 2009
    London, UK
    Nice job - real clean
    I'm a fan of a belly cuts for comfort. But visually arm cuts don't do it for me on teles - I like a flat top.
  20. 1bad914
    171
    Nov 10, 2016
    Michigan
    Thanks. Kind of got the bug this afternoon so I drilled and bolted the neck and set the bridge. Also drilled all the other pieces. I have to drill the jack hole and all the wiring hold between the cavities.
