First post and first scratch build.
Discussion in 'Tele Home Depot' started by 1bad914, Jan 31, 2017.
  1. 1bad914
    1bad914 Tele-Meister
    183
    Nov 10, 2016
    Michigan
    I will take more pictures of the other template tomorrow. Fun so far.
  2. RickyRicardo
    RickyRicardo Friend of Leo's
    Mar 27, 2012
    Calgary, Alberta
    If you can make copies of those so you'll always have masters. Just in case...
  3. 1bad914
    183
    Nov 10, 2016
    Michigan
    I guess I should explain the strat template on a tele forum. I built the strat template first as a test. The tele template and eventual build are the end goal. So since the end state is a tele build! Works for me.
  4. 1bad914
    183
    Nov 10, 2016
    Michigan
    Thanks for the advice, I will make copies of both.
  5. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Oct 23, 2011
    Lynchburg Tennessee
    Looking good so far! Keep it going.
  6. 1bad914
    183
    Nov 10, 2016
    Michigan
    I decided to cut the block of African Mahogany down to a more manageable size and made the router planing sled. I will plane it tomorrow. I made a couple of test runs and it worked well.
  7. Macrogats
    Macrogats Tele-Afflicted
    May 15, 2017
    Auckland, New Zealand
    That's a very cool router planing sled. I need to rig one up myself, and this design should work perfectly on top of my old table saw stand.
  8. 1bad914
    183
    Nov 10, 2016
    Michigan
    After 3 full passes. Worked well.
  9. 1bad914
    183
    Nov 10, 2016
    Michigan
    The lines are machine marks. Can barely feel them. A pass of 80 grit will clear them up. I will flip it over and do the other side next. This wood was 2 1/8 inches this. I have some work to do.
    Daniel94 and callasabra like this.
  10. Daniel94
    Daniel94 Tele-Meister
    144
    Oct 31, 2016
    Odessa, MO
    Just saw this thread, lookin good! I'll be following!
  11. 1bad914
    183
    Nov 10, 2016
    Michigan
    Done. The sled worked well. The only thing I might change is to make the side rails from a hardwood instead of MDF. This is after a quick 5 minutes sanding with 80 grit. Exactly 1.75 thick now.
  12. 1bad914
    183
    Nov 10, 2016
    Michigan
    The other interesting thing about the sled was the depth of the cut. Most of the references I found said to take paper thin cuts and make many cuts. I started that way then kept trying more. The last cut I made was a touch over 1/8 inch. I just took my time and it worked great.
    Daniel94 likes this.
  13. 1bad914
    183
    Nov 10, 2016
    Michigan
    I need to take pictures of the tele template I built and put them on. Now that the blank is ready I should be moving quickly now. I hope.
  14. 1bad914
    183
    Nov 10, 2016
    Michigan
    I finally took a picture of the tele template. I still need to cut the neck pocket out. Will do that soon. The will rough cut the body.
  15. Daniel94
    144
    Oct 31, 2016
    Odessa, MO
    I would leave the neck pocket on there like it is and rough cut and shape the body, then make a separate neck pocket template to rout the pocket.
    guitarbuilder likes this.
  16. brookdalebill
    Nov 15, 2009
    Austin, Tx
    Howdy, great concept!
    I'll be watching.
  17. 1bad914
    183
    Nov 10, 2016
    Michigan
    @Daniel94 I did that for my strat template. I will most likely do the same for this. I did not cut the horns, I went straight up. Thx for the reminder though.
  18. 1bad914
    183
    Nov 10, 2016
    Michigan
    Decided to rough cut the body and start the routing. Not super happy with it, but nothing that some sanding won't fix.
  19. 1bad914
    183
    Nov 10, 2016
    Michigan
    You like my bench? I have a wonderful shop in the basement, but no dust collection system so the deck works great and is easy to clean up.
  20. coonhollow greg
    coonhollow greg Tele-Meister Platinum Supporter
    138
    Jul 19, 2014
    roseburg,oregon
    Are you taking all of that off in one pass? I think you would be happier with the results doing it a little at a time. I like to sand to about 1/16" from the line, then router the rest.
