First partscaster build... the suspense is killing me!
Discussion in 'Tele Home Depot' started by bassderek, Sep 18, 2017.
  1. bassderek
    bassderek TDPRI Member
    16
    Sep 18, 2017
    Sacramento, CA, USA
    My bank account is weeping, but I'm like a kid near Christmas time waiting for all these parts to arrive. Hopefully I haven't bitten off more than I can chew for my first build (have only done wiring/setup in the past).
    Shopping list incoming:
    • Warmoth swamp ash tele body with shoreline gold satin finish (picked this up as a screamin' Deal!)
    • Warmoth modern/vintage tele neck maple with slight birdseye, satin nitro finish
    • Seymour Duncan Hot Rails bridge
    • Seymour Duncan Hot Tele neck
    • CTS/Alpha Pots/Orange Drop/Switchcraft
    • Parchment pickguard
    • Fender brushed chrome locking tuners
    • Fender USA 3 saddle compensaded tele bridge (ashtray)
    I had the pickups and electronics in my squier affinity as a project, but decided it was finally time to build a real axe instead of a hatchet. I may eventually phase the pickups out for something more vintage, but it's one expense I don't have to foot right now.
    Things I'm most nervous about and can use advice:
    -Drilling out the 2 guide pegs for the fender/schaller style tuners (the tuner hole itself will be correct from warmoth) and making sure the tuners are lined up.
    -Drilling the string tree hole
    -Drilling the strap lock holes
    -Basically any drilling :eek:
    -Filing the nut properly
    Everything else I think I'm ok with.
    Cheers!
  2. acrylicsuperman
    acrylicsuperman Tele-Holic
    852
    Nov 17, 2010
    Arizona
    The guide pegs will be easy, and so will the string trees.
    For the guide pegs, loosely attach your tuners to the headstock, line them up even, then tighten them at the top. The guide pegs will dig into the wood a bit. Loosen the tuners again and drill in those spots. Just make sure you mark your bit with tape so that you dont go through your headstock.
  3. BorderRadio
    Apr 2, 2014
    Phoenix, AZ
    Nice, post up when you're done (or if you run into trouble). If you're hesitant to drill, get a piece of scrap and start getting comfortable. Fit a tuner on a piece of pine, learn how to control your angle (assuming you don't have a drill press), and how to stop at the proper depth (I use a sharpie mark around the bit and my good eye). The nut will be the biggest challenge, especially without files. There will be others here that might give you some DIY pointers there--my only 'tip' is to get the files, but it's kinda pricey.
  4. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    I did pick up a cheap set of nut files on Amazon. We'll see how they hold up, the reviews were hit and miss, but for $8 I'll give it a go. I can have access to a drill press if need be. Test installing a tuner on some scrap wood might be a good idea though, thanks!
  5. BorderRadio
    Apr 2, 2014
    Phoenix, AZ
    Cool, I been thinking about trying those, the 'keychain' one, right?
    I have an 'ok' drill press and table, but setting up a job kinda sucks to tell the truth. The tuners you have could benefit from the precision, but you're gonna want to do the string tree after you cut the nut and slap some strings on it. It's an easy job but I use a hand drill and eyeball it carefully. Also put some chap stick or paste wax on the threads of any screw being installed for the first time.
  6. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    Yeah, I picked up these: https://www.amazon.com/gp/product/B01LQO3GGS/?tag=tdpri-20 consensus seeming to be they are slow and may not be good for many uses, but I think the Warmoth neck comes somewhat pre-slotted so I may only need to do some fine tuning?
    Ekko and BorderRadio like this.
  7. fenderchamp
    fenderchamp Tele-Holic
    802
    Jun 17, 2008
    omaha
  8. BorderRadio
    Apr 2, 2014
    Phoenix, AZ
    Going slow is a good thing for fine tuning. Never used Warmoth, so not sure if it's pre-slotted. My best guess is 'probably'.
    You know, this thread could use some pics :D
    Ekko, acrylicsuperman and fenderchamp like this.
  9. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    It could! But everything is in the mail!! Here's what it will sort of resemble when finished (but with less relic going on):
    I promise I will document the process well and post a build thread!
    Ekko, kkphoto and BorderRadio like this.
  10. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    I'm just gonna stare longingly at the stock photos till the parts arrive!
    Ekko and kkphoto like this.
  11. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    *Possibly* dumb question: Does this style bridge need to be slotted?
  12. acrylicsuperman
    852
    Nov 17, 2010
    Arizona
    Nope.
    bassderek likes this.
  13. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    Thursday is parts day! Just waiting on the bridge, straplocks (both arriving tomorrow), and then the neck and body from Warmoth. Hoping they ship soon, but I'm not sure how quick their processing time is. EDIT: Wamoth site showing shipped! Hoping to get all the parts next week and put it together that weekend.
    imploration, Ekko and BorderRadio like this.
  14. Snook
    Snook Tele-Meister
    344
    Sep 17, 2015
    Ohio
    I would have bought an electrosocket instead.
    Grux likes this.
  15. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    It's not too late to change. I was previously unaware of that style.
  16. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    Pulled the trigger on the electrosocket. All the parts in as of last night. Build and pics to follow.
    Ekko and Grux like this.
  17. sammy123
    sammy123 Tele-Meister Gold Supporter
    387
    Jul 25, 2011
    MKE
    Congrats on progress. The electrosocket is a really nice upgrade.
  18. Grux
    Grux Tele-Holic
    710
    Jan 10, 2017
    Clarksville, TN
    That electrosocket is the most exciting upgrade you can do to a tele. It doesn't seem like much until you've been through several switch plates and had to endlessly tighten them!
  19. Billnchristy
    Billnchristy Tele-Holic
    744
    Sep 21, 2017
    Georgia
    I put one in mine and wouldn't go any other way. They don't cost any more either.
  20. bassderek
    16
    Sep 18, 2017
    Sacramento, CA, USA
    Time for the build pics!
    Warmoth day:
    Test fit/layout:
    Bonus Birdseye:
    The end of an era/parts donor:
    Went for a brushed/satin look to match the tuners and satin paint job. WD-40 and green scotch brite!
    TigerG and Ekko like this.
