Join TDPRI Today
Fender Wide Range Humbuckers
Discussion in 'Just Pickups' started by Telenator, Mar 27, 2008.
  1. Telenator
    Sep 19, 2005
    Vermont
    Does anyone know if the the covers on the new Fender '72 Thinline re-issue pickups are the same size as the originals?
    What I'm most interested in is the hole spacing for the magnet slugs. Is the spacing the same as the originals?
    I have found a source for CuNiFe magnets and need to have a few bobbins machined. I can extrapolate the bobbin size from the hole pattern on the original pickup cover, but sadly have no pickup to measure.
    If anyone wants in on this project, contact me. I'll be having some parts made and of course, the more parts I buy, the less each one will cost.
    Also, I'm looking for any leads of info on the magnet material that sits on the baseplate of the pickup. The "mystery magnet" material. Thanks.
  2. littlericky
    littlericky Tele-Meister
    183
    May 30, 2003
    LI,NY
    I don't have an original but I can tell you that the pole screws do not line up with the holes in the covers on the MIM RI. Looks the the originals were much closer but still off.
  3. Telenator
    Sep 19, 2005
    Vermont
    If I could just get the measurements of the pole spacing I can figure out the rest. I have tried to buy an original but can't seem to find one anywhere. It's just a matter of time.
    Thanks for the photos!
  5. braderrick
    braderrick Tele-Afflicted
    Sep 27, 2006
    Kentucky
    There's a buch of '70s thinline, customs, and deluxes on ebay. I assume most of them are authentic. You could do the "ask seller a question" thing. But like you said it's just a matter of time, I know there are tons of members on this forum that can help you out, and I'm sure they will.
  6. quartermiler45
    quartermiler45 Tele-Meister
    106
    Sep 11, 2007
    Indiana
    I'd be interested in hearing more about this project.
  7. lammy
    lammy TDPRI Member
    87
    Mar 7, 2008
    Brooklyn
    ooo. me too!
  8. Telenator
    Sep 19, 2005
    Vermont
    Well, I have a source for the CuNiFe magnets and since the MIM pickup covers are most readily available, I'll probably base the pickups on that hole pattern even though it's not exactly like the the original. The few thousanths of an inch difference in pole spacing shouldn't be a big deal.
    The one mystery remaining though, is the magnet material under the coils. I need to see an original pickup disassembled in order to to sort this bit out.
    Anyone with a WRHB that has photos of the innards would be very welcome to join in here. I have the parts for my 72 Thinline. Now I just need the p'ups!
  9. littlericky
    183
    May 30, 2003
    LI,NY
    I'm confused. Originals use threaded cunife magnets as the poles, there is no magnet underneath. RI pickups use "steel" screws for the poles, there not magnets, therefore there are alnico(MIM) or ceramic(MIJ) bar magnets under the coils. You need one or the other, not both.
    The simplest thing would be to have cunife screws made,threaded to replace the steel screws in RI pickups, just remember to make them the correct length as per the originals. You'll sell a truckload of them. It would be easy enough for modders to remove the bar magnets,use shims in thier place, and install the new cunife screws.
  10. jefrs
    jefrs Doctor of Teleocity
    Nov 20, 2007
    Newbury, England
    GFS do something like these 'Vintage Split Pole' about 8K, which sound authentic. I could not find genuine Fender WR either. This one is cheap enough that you could use it for parts. With it fitted it would be difficult to make measurements accurate enough for engineering work. The strings do pass directly over the poles on the 07 AmSer. The unit went straight into a stock pickguard, note single dog-ears. I've only made pickups from odd bits like re-winding big solenoids onto a bar magnet, so good luck with your project.
  11. Telenator
    Sep 19, 2005
    Vermont
    From what I've been told, there is a piece, or small sheet of magnetic material that the bobbins rest on. I have not been able to get my hands on an original WRH to take it apart and see this for myself.
    If it truly is a simple matter of replacing the threaded magnets, then I'm golden!
    Anyone care to take a guess at the gaussing spec? And polarity of the originals?
    I have the winding specs but don't know if the Re-issues match that spec. I'll have to pull one apart and see.
  12. TELE_BLUES
    TELE_BLUES Tele-Afflicted
    The p.u.'s i have from the 2005 mim '72 thinline reissue have an outside polepiece spacing center to center of 2.100"
  13. WrapAround
    WrapAround Tele-Holic
    989
    May 17, 2003
    I'm interested in WRs as well, so I have to ask this question. What does "sound authentic" really mean in this case? Did you A/B it with a real WR ('real' as in NOT a reissue one)? Or does it mean, "it sounds like how i remember old WRs sound like."?
  14. vikki
    vikki Tele-Meister
    400
    Dec 7, 2003
    Is this the same Humbucker as in the 72 Custom, if so i have an original and a modern Japanese copy. I have digital calipers...if you need measurements let me know.
    Regards
    Vikki(uk):lol:
  15. TELE_BLUES
    I have a rewound WRHB i don't remember if it's a mij or mim.I had OWEN (OWEN DUFFY, O.C. DUFF) rewind it for me,he suggested alnico II and i'm real happy with it.
  16. boneyguy
    boneyguy Doctor of Teleocity
    Mar 31, 2007
    victoria b.c. CANADA
    If it turns out to be as simple as threading the CuNiFe rods then you might consider selling just the threaded pole pieces to those who already have the RI pickups??!!
  17. quartermiler45
    106
    Sep 11, 2007
    Indiana
    If this project is successful you will be the most popular man around, I might name my first born after you. :lol: Please keep us up to date on this project.
  18. Telenator
    Sep 19, 2005
    Vermont
    Thanks vikki. Yes, the '72 Custom pickups are the same as the '72 Thinline.
    What I really need is to see how the pickup is put together. How the bobbins sit on the tray and if there is any material between the bobbins and the tray.
    I am going to base my dimensions on the MIM pickup covers since they're most readily available.
  19. yegbert
    yegbert Poster Extraordinaire
    Sep 28, 2004
    Maryland (US)
    With the same spacing for the bridge and neck? Or are they wider on the bridge?
    I wonder if either the CIJs or the originals are spaced differently on the bridge compared to the neck?
  20. RumorsofsurF
    RumorsofsurF Tele-Meister
    427
    Mar 19, 2007
    Independence, OR
    You found a source for CuNIFe?!?!?!:eek:
    Outstanding. I want in! My MIM Tele Deluxe needs some CuNIFe M@J@!!!
  21. Telenator
    Sep 19, 2005
    Vermont
    I'll keep you guys up to date on the progress.
    I just need to see one of the originals in pieces and I'll move forward with this.
