Fender Deluxe 5B3 Amp, What can you guy's tell me about it?
Discussion in 'Glowing Bottle Tube Amp Forum' started by Wicked-T, Sep 17, 2017.
  1. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    Cool amp! I have a TV front 5A3.
  2. archetype
    archetype Fiend of Leo's Ad Free Member
    Jun 4, 2005
    Williamsville NY
    What are those red/orange octal "cans?"
  3. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    They look like an adapter to allow use of a 12ax7 type tube.
  4. Wicked-T
    Wicked-T Tele-Meister
    486
    Apr 1, 2017
    It's for using 9 pin tubes.
  5. Wicked-T
    486
    Apr 1, 2017
    It's there I take a picture of it.
  6. Wicked-T
    486
    Apr 1, 2017
    I found by google it's a output transformer for a 40 watt 4 ohm amp like a
    Tremolux, pro reverb, vibrolux and the like.
  7. thegeezer
    thegeezer Tele-Holic Gold Supporter
    851
    Jul 5, 2010
    West Michigan
    Re: your O/T. That stinks. Needs to be 8 ohms, of course. I know they're slightly pricey but Mercury Magnetics is good about winding to original specs.
    Great amp, great project.
  8. Wicked-T
    486
    Apr 1, 2017
    Their a bit pricey I think Classictone.com are a bit better on the prices, but
    thanks
    thegeezer likes this.
  9. Wicked-T
    486
    Apr 1, 2017
    Here you go!
    robrob likes this.
  10. Wicked-T
    486
    Apr 1, 2017
    Maybe the amp is a transition amp, the 5B3 has .05uf in the first two caps
    mine has .1uf like in the 5C3 or I could be wrong.
  11. Wally
    The serial number indicates a production date of 1953. Is that a faded ink-stamped date code right above the 9 in the serial number. It appears that I can make out a 'C' for the first letter...which is 1953.
    It has been rather poorly recovered. The Cesar Diaz tag is kind of cool. Considering the recover, the OT, and the missing speaker; I would hope that the cost of the amp was appropriately adjusted. It is in the player category because of those 3 aspects. These can be great amps. I would suggest a P12Q or higher true Jensen. A P12P or N would make the amp 'bigger'.....a Weber Vintage series 12A150 for a new speaker.
  12. Wicked-T
    486
    Apr 1, 2017
    Thanks for the info, let's just say it was less than a kit you put together from Mojotone.
    I'll most likely use for now a 1990's Weber VST P12Q.
    Wally likes this.
  13. Wally
    Good buy....great speaker. Ime, those PIO caps...tone and coupling....have outlived their useful life. All of the resistors are suspect. I would suggest checking all of them. There is an electrolytic bypass cap that needs to be changed, Ime and imho.
  14. Wicked-T
    486
    Apr 1, 2017
    Would anyone know what the voltage's are at pin 8 and 3 on the 6V6's. I measured
    390volts and 340volts. I also measured the the bias resistor at 253ohm and it's
    dropping voltage as 19.55v in which using the bias calculator on the web (Rob's)
    it's about 12.4 watt's, If that's a bit high could I lower that by a higher resistor?
    I did have a bit of crackling noise but it was one of those 6SC7 tube and it was
    noisey.
  15. keithb7
    keithb7 Friend of Leo's
    Jan 9, 2010
    Western Canada
    I have yet to try or own any Deluxe earlier than a 5E3. I sure hope to find one some day! I did repair an old 40's Regal amp with octal preamp tubes. It sounded sooo good! I'd love to get my hands on a 5A3, 5B 5C, or 5D3.
    I'd love to slam my ES-335 thru it and hear that baby sing.
    Congrats on a great amp. I'm certainly covering it.
  16. Wicked-T
    486
    Apr 1, 2017
    It's sounding good but need to change the caps motorboating!
  17. Wally
    Any amp that is motor boating is NOT sounding good. It is on the verge of failure and cannot possibly sound as it should. Once that amp is recapped and properly serviced, then one will understand that simply making some sort of sound come out of a speaker cannot be 'sounding good'. Even if it were not motorboating, thiose old electrolytics cannot provide voltage in such a manner as to allow the circuit to produce proper and good sonics, Ime.
  18. Wicked-T
    486
    Apr 1, 2017
    I ordered some F&T's 20uf and a few Sprague 25uf 50v today, should get them
    in a few day's
  19. King Fan
    Jan 1, 2013
    Salt Lake City
    Great amp -- congrats!
    In an amp that old, think of the electronics renewal as musical rescue and recovery, not museum restoration to display under glass.
    keithb7 and Bill Moore like this.
  20. Wicked-T
    486
    Apr 1, 2017
    There's a big thing about that in the guitar world don't change anything even if
    it's bad, but look a lot of these amps are pushing 60 years now and even if we
    would love to keep it all original sometimes you can't the caps really start to
    leak. In mine the volume was very scratchy sounded and it was the coupling
    caps which I replaced and it's better.
