Asher Guitars WD Music Products Amplified Parts Mod Kits DIY Nordstarnd Pickups
Fender Champion 20
Discussion in 'Modeling Amps, Plugins and Apps' started by dqami, Mar 5, 2018.
  1. dqami
    dqami Tele-Holic
    Feb 11, 2004
    Hi, after having tried one at a GC, I was blown away how good it sounded and the effects it had for such a small package. I have come to appreciate the clean tones from Fender solid state amps and currently play tube amps and a Frontman 25. I picked up a C20 on Cl last week and having spent more time with it, still feel it is a great amp. In fact, I have owned many Fender tube amps and feel it sounds as good if not better on the modeling of the Super Champs Xd and Xs.
    Anyone else have one and can share their experience or mods they have done? I have a few speakers I amp going to try this week and see if I can improve on the tone, though I must say, the stock speaker actually sounds good on this amp for everything except the metal (no biggie there)
    televillian likes this.
  2. Mickey slick
    Mickey slick TDPRI Member
    Jan 11, 2017
    I almost got one but I didn't like that the reverb are shared I have a mustang 1 v2 and for the same money I like it
  3. Mickey slick
    Jan 11, 2017
    Sorry I didn't prof read I was saying reverb and delay
  4. xafinity
    xafinity Friend of Leo's Silver Supporter
    Dec 24, 2015
    my Mom's basement
    I love my Champion 40 with the 12" speaker.
    I found mine nearly new for 100 a couple years ago.
    musicalmartin likes this.
  5. Geo
    Geo Friend of Leo's
    Hendersonville, TN
    I bought one recent for $88 delivered from MF. I had a 5 watt tube amp that apparently blew the transformer somehow so bought C20 to replace. Main use here is for a small guitar group which
    meets on a building 2nd floor via stairs. I think it weighs about 12 lbs and is small in size.
    It gets some home use here and there also.
    The amp does well and sounds very good considering. I use the green light Fender sound (Twin?)
    and generally very slight delay mainly with Telecasters. Right now volume levels are no more than 1/2 of max.
    I haven't used the other amp settings much but the Vox one is decent. I have to change the bass
    and treble settings with the other various amp selections.
    Slight downside is the inherent pop sound when turning the amp off. I read and tried placing an earphone jack just partially into the phone plug and it reduces the pop. For some reason now even when not placing
    the plug the pop is somewhat less loud than initially.
    All in all VG amp for its type and price. I wish it had a couple little things but hey for the price met
    and exceeded expectations.
  6. LutherBurger
    LutherBurger Friend of Leo's
    Oct 29, 2013
    I have one, too. That's the Deluxe. The red light in the "Blackface" range is the Twin.
    I really like the Blackface Deluxe model, too, but my favorite is the Princeton (amber light).
    Geo likes this.
  7. dqami
    dqami Tele-Holic
    Feb 11, 2004
    Yes, my fav also is the BF Deluxe. Quiet and clean chime with fat bass . I Ended up swapping the stock speaker with a Vox Bulldog I got from a nonworkinf Pathfinder. It seems to hold up the distortion better while keeping the chime. Handles the metal settings better as well though still noisy, even with the tone knob turned way down for the fat power chords. Not everyones thing but kinda fun for a change.
    Jim Dep likes this.
  8. Old Bill
    Old Bill Tele-Holic
    Jan 9, 2010
    Hartlepool, UK.
    Two together sounds incredible and for the price well....... .
  9. TeleAnthony
    TeleAnthony Tele-Meister
    Sep 13, 2010
    Maryland, USA
    Old Bill- How do you put two together? I have not seen or tried the champion series but am considering going solid state. Thanks!
  10. rave
    rave Tele-Meister
    Jun 17, 2011
    Los Angeles
    I had one when I got back into playing a few years back. I got it because it is less fiddly than a mustang. Easy to get a good sound quickly for practice. Gave it to my son.
  11. dqami
    dqami Tele-Holic
    Feb 11, 2004
    I would use an ABY pedal. You could set one up for clean and another for OD like switching channels or have both going .
  12. musicalmartin
    musicalmartin Poster Extraordinaire
    Aug 8, 2007
    Norfolk UK
    I have a champion 40 which is fine .I also have a Mustang 1 with a larger 10 inch speaker installed so maybe you fit a larger speaker better speaker in the champion 20 .I didnt open out the 8 inch hole to a 10 inch when I installed mine but it still sounded much better.Its worth pointing out that 8 inch is used to not make the amp too loud at useable room setting .My Champion 40 with a 12 inch is much louder at similar volumes as it moves much more air and carries further. I now use a DV mark Little jazz with a 8 inch neo speaker and thats fine for bar type jazz gigs I sometimes play and also less carried noise at home . Before that I used The Champion 40 which also was fine live .
    Fitting larger speakers is only worth it if you can use the better volume. Its not a given .
  13. dqami
    dqami Tele-Holic
    Feb 11, 2004
    The cab for the Champ 20 is small, like the Frontman 15 so no chance a 10" will fit. I also own the Frontman 25R which has a 10" and is a bigger cab. It sounds great and can be found used cheap. It is voiced to put out lots of bass with the sweet sparkle Fender SS is known for.
