Eyelet board do-over on a '63 RI reverb unit
Discussion in 'Shock Brother's DIY Amps' started by JBennett, Feb 1, 2012.
  1. JBennett
    JBennett Tele-Afflicted
    Jun 23, 2008
    Cold Spring, NY
    UPDATED. Thanks. Now, what exactly is a 100r resistor? Ah, I see. It's how those "across the pond" say 100 Ohms.
    So, with the reverb unit with the three prong chord grounded, will I get a ground loop when using it with a three chord grounded amp?
  2. milocj
    milocj Friend of Leo's Ad Free + Supporter
    Aug 21, 2005
    Michigan
    I haven't had any ground loop problems with the Revibe that I built. I always plug them into the same outlet which should guarantee the wiring is correct, so I haven't tried it other ways that may potentially cause a loop. The original reissue that you started with had a three-prong cord, correct?
  3. JBennett
    Jun 23, 2008
    Cold Spring, NY
    Yes, and I plan on reusing the same power chord. Thanks. I'm going to stick with the three prong grounded for safety.
  4. JBennett
    Jun 23, 2008
    Cold Spring, NY
    Made two of my boards today...
  5. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Nice job and good photo details. I made a full wave rectifier with four 1N4007 diodes in just the same way you have detailed.
    I made mine for a Champ which has a repurposed Fender 600 PT (which used that type of rectifier on it's PCB). Works like a champ.
  6. JBennett
    Jun 23, 2008
    Cold Spring, NY
    Hackworth. Thanks. Do you have photos of your champ rebuild? I'd love to see.
  7. JBennett
    Jun 23, 2008
    Cold Spring, NY
    Dog house layout...
  8. JBennett
    Jun 23, 2008
    Cold Spring, NY
    New (old) meter on the way...
  9. tubeswell
    tubeswell Tele-Afflicted
    Jul 1, 2008
    NZ
  10. JBennett
    Jun 23, 2008
    Cold Spring, NY
    Meter arrived this morning. Put in some fresh batteries, works like a charm! Very cool old machine. Cost me less than a chinese radio-shack meter. Might make for a nice book-end too... solid block.
  11. JBennett
    Jun 23, 2008
    Cold Spring, NY
    Still waiting on components, but this Meter is keeping me occupied. Cool guts...
  12. JBennett
    Jun 23, 2008
    Cold Spring, NY
    I've started in on my board. Still waiting on a few straggling components...
    I know, I'll now need to de-solder a few points along the way, but I could use the practice anyway.
  13. EdMax
    EdMax Tele-Meister
    273
    Mar 18, 2008
    Northern Illinois
    I have 2 of these, one was my dads and one I grabbed for 5 bucks at an auction. At one time, back in the 50's/60's I bet there wasn't a TV/Radio shop around that didn't have one of these.
    Simpson back then was what Fluke is today, the go to device.
    I have the optional 653 ac ammeter add on for mine as well.
    http://www.simpson260.com/accessories/add_a_tester/add-a-tester.htm
    I rarely use these anymore though, kind of keepsake /collectable now.
    You might like this site.
    http://simpson260.com/
  14. JBennett
    Jun 23, 2008
    Cold Spring, NY
    Thanks. Yeah, I found that site. That's where I stole the photo from, mine is just like it though, and downloaded the manual.
    Fun device. And it works well.
  15. JBennett
    Jun 23, 2008
    Cold Spring, NY
  16. JBennett
    Jun 23, 2008
    Cold Spring, NY
    Rectifier:
    Main board:
    Electrolytics:
  17. andyfromdenver
    andyfromdenver Friend of Leo's
    Dec 21, 2011
    grandpa's
    Coming along so well. Anxious to hear your before and after impression!
  18. JBennett
    Jun 23, 2008
    Cold Spring, NY
    hackworth. I guess mine is more recent since I just threw it together... If I have trouble, I might use the weber plan for alternatives.
    Andy, thanks. I've been testing all my connections with my meter. All the resistors are still reading properly and all my connections seem to be conducting solidly.
    That Watts yellow wire is kind of a pain to work with. It's really thick. I guess that is what is needed for the voltage in an amp. I'm used to the dinky 22ga stuff for guitars.
    Plus, this is teflon coated AND cloth coated. I had to re-drill my wire holes to accommodate it, and it's not as easy to push back. Oh well. It seems to be getting the job done and seems to be pretty rugged.
  19. JBennett
    Jun 23, 2008
    Cold Spring, NY
    So. I'll need a capacitor cover "doghouse". I'm not against buying a nice one for 15-20 dollars, but it feels like a lot for a pressed plate of aluminum.
    Anyone have any tips on alternatives? I looked at a bunch of electrical outlet covers/boxes/housings at home depot and none of them were right. But maybe there is some other source for a simple aluminum box with tabs? I could also buy a sheet of aluminum and cut/fold my own, but with limited time for this project I might just order one at that point.
