Join TDPRI Today
Experimental Hollowbody Build
Discussion in 'Tele Home Depot' started by Elias Graves, Oct 14, 2012.
  1. Elias Graves
    Elias Graves Friend of Leo's
    Apr 27, 2010
    Oklahoma
    After the success I enjoyed making my first guitar last year, I've decided to get a little more complicated this time around. Hollow bodies are my true passion, so I'm going to take a stab at one, though my construction will differ from the traditional acoustic style build with bent sides and such.
    Much of my inspiration for technique is drawn from this old Gibson.
    This particular example is walnut, with a carved top and back joined together clamshell style. The technique was pioneered by Orville Gibson himself and is the basis for his one and only patent.
    I will also use walnut, though Orville used spruce for the top. Since I'm aiming to tame feedback and am not worried about acoustic volume, I will used walnut for the top as well.
    Much of the construction will be done with hand tools and I'm finding time to work on it when I can, so it will likely be a slow build, so bear with me.
    You wont see me making a whole pile of templates, either, so the machinists among us will probably cringe. Im more an artist and a wood carver than i am a builder, so i tend to jut do things with measuring tools and marks more than templates. I view templates as preparation for production work...for the sake of repeat ability. Since I have no plans to ever make a second one of these, I don't much care whether I have tools on hand to make copies.
    I'll bring you all up to date to current status.
  2. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    Your first build is so beautiful that I just have to follow this one too!
  3. Elias Graves
    Apr 27, 2010
    Oklahoma
    Beginning with the neck. This will be the blank for it.
    The lumber is American Black Walnut from Missouri, harvested about 25 years ago. It's good wood, though much of it is "B" grade as far as appearance goes.
    Here it is after the first face is cut. I wet it down to show the grain. As you can see, the grain is all over the place. It's not flat sawn or quarter sawn, but looks more like it can out of the center of a branch or trunk. This may increase a tendency to warp, so I'll take some extra precautions to ensure that it stays straight.
  5. Elias Graves
    Apr 27, 2010
    Oklahoma
    Thank you. The tele has become my #1. It really is a nice guitar.
    Here, I've marked for thickness with some masking tape and begun cut #2.
  6. Elias Graves
    Apr 27, 2010
    Oklahoma
    After cut 2. This side really shows the appearance defects. There's maybe a worm hole or something that resulted in some serious black streaking as well as a knot.
  7. Elias Graves
    Apr 27, 2010
    Oklahoma
    Also revealed is some checking that runs down in pretty deep. I have enough length to slice this off, though. It won't cause a problem.
    After trimming.
  8. Elias Graves
    Apr 27, 2010
    Oklahoma
    The wormhole left some seriously nasty black streaking. Most of it will go when I carve the neck. I have plans to deal with what's left.
  9. Elias Graves
    Apr 27, 2010
    Oklahoma
    The walnut has some very deep grain!
  10. Elias Graves
    Apr 27, 2010
    Oklahoma
    And now the neck blank after going through the planer. That's one power tool I DO have! Thank goodness!
  11. Elias Graves
    Apr 27, 2010
    Oklahoma
    Setting the neck aside, I decided to go ahead and plane up my body wood since I had the tool set up. I'm doing a three piece back. Walnut does have a bit of a tendency to warp, so I don't want to risk a one piece back.
    Here are the boards I've chosen for the main body, planed to 1 15/16" thick.
  12. Elias Graves
    Apr 27, 2010
    Oklahoma
    And the boards for the top. These are about 1 1/2" thick.
    When complete, my goal is to have a total body depth around 3" and a little under 2" at the rim.
  13. Elias Graves
    Apr 27, 2010
    Oklahoma
    Turning back to the neck for a moment, I want to try my hand cutting a fret slot and setting the wire. Here, I just used some scrap walnut to test.
    Looks good, but if you observe carefully, the fret wire isn't snug on the left side.
    And it pops right out by hand.
    So much for my miter saw.
    Looking around, I decided to try the smaller fret saw.
    Nice and snug!
  14. Elias Graves
    Apr 27, 2010
    Oklahoma
    Now beginning to work on the nut. Cutting my blank to length.
  15. Elias Graves
    Apr 27, 2010
    Oklahoma
    As I mentioned earlier, my wood has some cosmetic defects I wish to hide. Here's how I plan to do that.
    Walnut, along with a few other woods, is very high in tannic acid content. Tannic acid, when exposed to ferric oxide, causes the wood to turn black through a chemical reaction. The grain remains visible but it's all a deep purplish black.
    Not all walnut is equal when it comes to tannic acid content, however, so each piece needs to be tested to make sure it stains correctly. I figured I ought to go ahead and test my boards to make sure.
    Looks pretty good.
  16. Elias Graves
    Apr 27, 2010
    Oklahoma
    Last post to get us caught up. Here is the neck blank now with the angle cut into the headstock.
    And the neck blank all sanded smooth. I had to get the black off so I can see my layout lines!
    That's where it sits right now. The neck is on hold now til I get some parts ordered.
  17. Elias Graves
    Apr 27, 2010
    Oklahoma
    I guess I should do a little rundown of what this thing is intended to be!
    As I mentioned in the first post, a lot of my inspiration comes from that first Gibson archtop. If you notice, the carve is a different shape than you see on a modern Gibson. This one is more like a PRS carve.
    Kinda flat across the face, then dropping off.
    The sides, I plan to do a little rounder. Look at these and you'll see what I'm aiming for. Maybe not exactly the same as either, but in this vein.
  18. Elias Graves
    Apr 27, 2010
    Oklahoma
    Other specs include:
    24.5" scale
    10" fretboard radius
    Wood base archtop style bridge with a roller top
    Short trapeze tailpiece
    Antler nut
    Tru Oil finish
    Open gear tuners
    Pickups are still under consideration, as is wiring.
    There will be an access panel in the back
    Size, about 14" inches wide and 3" thick at the center
    Tapered headstock, tilted back
    These are the headstocks I'm stealing from.
    Gibson Marauder
    Snakehead telecaster prototype.
  19. Bentley
    Bentley Friend of Leo's
    Jul 25, 2012
    Kelowna B.C, Canada
    I love that walnut!
  20. maxb
    maxb Tele-Meister
    207
    Jul 31, 2012
    Denmark
    Looking good! Walnut always comes out pretty. Some beautiful guitars you've posted. I especially like the white one with golden hardware!
  21. Elias Graves
    Apr 27, 2010
    Oklahoma
    That one is quite striking, isn't it?
